Condi's HACKMODE v2.2 - AUTOINSTALL! working also with F40BT, X940BT etc! [updated: 27.09.2012]
By condiczek · Apr 25, 2011in Hacks/Mods💬 1,207 posts👁️ 757,721 views
Page 25 of 49
Posted Jan 16, 2012 · 00:33 UTC#601
New X940 and Z140 annonced. I hope it will be update for our "previous" models.
I hope updates will have new maps- from Navteq.
http://avic411.com/i...__fromsearch__1
Edited Jan 16, 2012 by Ralpharn
Posted Jan 26, 2012 · 11:55 UTC#602
DEAD TOPIC ???
Posted Jan 29, 2012 · 17:52 UTC#603
Hi,
I'm new on this topic. I just bought a used f920bt and it has the original sw/map on it. I'd like to install the new maps. My friend has a new f930bt with a newer map on it. Is it possible to copy somehow the maps from the f930bt to my f920bt?
Any help is appreciated.
guszti
Posted Jan 30, 2012 · 00:23 UTC#604
...Is it possible to copy somehow the maps from the f930bt to my f920bt?
1. Make an backup of your complete NDATA folder in case if something will go wrong.
2. Then copy NDATA folder from newer unit and select folders called like 00, 02,03... 1A, 1B... ect. (theay are all numbers in hex representation!) and folder L3D and copy them to your unit. Do not copy folders AV BG BT FE INIDATA SDUSB SKY SOUND SYMBOL TEL TTSData VBT. Only copy them if you have problem.
Posted Jan 30, 2012 · 03:07 UTC#605
and share copy ndata (f930bt) for us =)
Posted Jan 30, 2012 · 05:29 UTC#606
Hey Fellas, what's going on? I see there were some high hopes for hack n modding. Well I hope you don't give up, take a break, but don't give up. Good luck either way, and thnx for trying.
Posted Jan 30, 2012 · 14:10 UTC#607
Hi. I have. Avic f30bt. And I have map for Qatar. Can I Put or replace the orgnal maps
Posted Jan 31, 2012 · 04:41 UTC#608
What original map your F30BT has?
Where is this Qatar map came from? (other F30BT I hope)
Edited Jan 31, 2012 by Ralpharn
Posted Jan 31, 2012 · 14:03 UTC#609
Hi the original map its for europ
The map is for medal east. It's came from mi. Avic f500bt.
Posted Jan 31, 2012 · 15:12 UTC#610
Regret to say that but:
F500 uses IGo as navigation software.
F30BT uses something Pioneer's homebrewed - so no joy, that Qatar map wouldn't work on your F30...
Only hope is to hack F30 but GPS port is still locked.
Posted Feb 04, 2012 · 22:39 UTC#611
i am very glad to find that hack here. gives me the hope that there will be the time that i can use igo primo on my new f-30bt.
will have a look at your hackmode next week.
Posted Feb 14, 2012 · 08:52 UTC#612
Hi..I have a f20bt...
Last years I update to the 2011 map...
I havn t understood if with my avic is possible to put alternative navigators or not....
Posted Feb 16, 2012 · 18:09 UTC#613
Hi,
I was playing with my f920bt on desk for almost a month. I was succesfull with the upgrade to cnsd-210fm. I had some problem with bt but I used the wrong loudspeaker output, so it was my fault. Finally yesterday I installed into my car and was able to test it in car. Now I understand why did you guys try to put on some other navi sw. I did not want to believe that Pioneer released a modell with so clumsy, navigation software. I have in my other car an f900bt which is slow at start but the navigation software - based on igo - is a way better then this one. So now I'm waiting also for you to be successfull with your hack to get install a much better - I think there are only much better - navigation softwares.
I wish you a good luck with your effort.
gusztim
Posted Feb 21, 2012 · 00:01 UTC#614
is it possible to make changes to original pioneer UI ? to play with original skin ? im looking to reposition the confirmation window once you search for address, is that possible or not ?
Posted Feb 22, 2012 · 03:34 UTC#615
If someone need Australian map (or explanation how to run different map on our units using Australian map as example) please take a look here
Here is little "How To" set different language for menu and AV part in your unit:
For instance I have X930BT that made for US and it has only English, French and Spanish languages in menu, But I want it to use Russian. It is possible because in \USER\PRG0\Apl\LANGDATA\StringData\ I have list of 21 languages, I just select language from selectable for instance French (Sorry guys I can't speak French!) I move UCCAFRC.LNG somewhere safe and rename EURURUR.LNG to UCCAFRC.LNG
Then select French in menu and ...Ta-dammm... I have Russian menu.
How to select rigt file? just open file that you suspect contains language you need in text editor and you will see plain text. Enjoy!
BTW if your unit have been updated you have chance that you need make changes in \USER\PRG1\Apl\LANGDATA\StringData\
Posted Feb 24, 2012 · 11:47 UTC#616
Hi,
I have problem.My devise is avic-z120bt upgraded to z130bt with shortfuse hack. and is this possible to change region settings my devise?,because i get it in US,but live in Europe .For example, the radio frequency settings, I cant get radio stations that are even, only odd stations are set on the radio.I don't think i can over-write the same version level. AFAIK, US and EU are the same version number - just different maps and other stuff.There may be some way to hack the HU using TestMode to set the version number. Or it might be possible to hack the version number in the EU CNSD-210FM upgrade to be greater than 3.0. But either of those could be dangerous - could brick the HU if done incorrectly.How can i back to the original (factory) software."Real" hackers help me with the on this thread.
Posted Feb 25, 2012 · 09:30 UTC#617
X930BT here, any updates or news on any hacks that are useful? Will it ever happen?? Will we with the 930s ever officially (or through a hack) ever be able to get 2012+ map updates/other gps software?
Posted Feb 26, 2012 · 14:32 UTC#618
Found my notes on setting up a Windows + Cygwin + CEGCC Haret build environment, was in Feb 2011 so there may be some drift and updates required.
9. Copy out/haret.exe over to your Testmode SD, eject, boot to test mode and run haret.exe from your SD card.
can u share this haret.exe to try at my z120bt ? i need a compile a kernel or your file have a linux distro included?
I compiled haret (Thanks to FourG for the good tutorial) and started it in Hack-Mode on my F930BT but the result was disappointing: Nothing happened.
Does somebody know which type of processor is inside the F930BT?
Posted Feb 27, 2012 · 00:40 UTC#619
Um why can't I get to the last two pages? It always says "There appears to be an error with the database."?
Posted Feb 28, 2012 · 07:22 UTC#620
I can only see the last posts by hitting reply on a random page and then scrolling down below the reply box..
Someone gonna fix the last 2 pages?
Posted Feb 28, 2012 · 20:06 UTC#621
Topic has been fixed.
Posted Feb 29, 2012 · 03:49 UTC#622
You can create an empty text file in the same directory as haret.exe which will cause HaRET to log a lot of information about its discovery process. From http://htc-linux.org...n#Early_logging:
The easiest way to enable logging in HaRET is to create a file "earlyharetlog.txt" in the same directory as the haret.exe program. The next time one runs HaRET, it will create a file "haretlog.txt" with logging information.
The resulting "haretlog.txt" file contains information on the device and the actions that HaRET performs during startup. It will also record all commands executed by HaRET.
When reporting an issue, please create the "haretlog.txt" file as described above and forward it (with a description of the problem) to the HaRET mailing list.
That same page has some pretty good info about HaRET in general, with some HTC-specifics mixed in.
In your haretlog.txt, look for something resembling this:
Trying to detect machine (Plat='PIONEER' OEM='Handheld Reference Board BSP version:TitanHHV1.0.47')
Wince reports processor: core=ARM1136JF-S name=TN2X0A cat= vend=Centrality
That will give you a good start on your search for more documentation on the processor.
Posted Mar 03, 2012 · 12:43 UTC#623
@FourG Thank you, I will try.
Do you know if system libraries like COREDLL.dll are used? The COREDLL.dll of the system is limited some way and for other programs a file COREDL1.dll in the same directory is needed.
@Condi What is the best way to change the references of a program from COREDLL.dll to COREDL1.dll? Hex-Editor?
Posted Mar 14, 2012 · 09:52 UTC#624
Hey guys,
So back near the beginning of this thread, I saw some people talking about uncompressing image.img to get the image files out, but noone seemed to be successful. I managed to do it, but I posted it over in the X series forums because I'm working with an X930BT. However, I think it should be similar, if not exactly the same for you guys. If anyone's still interested, have a look at my writeup here.
Posted Mar 16, 2012 · 13:36 UTC#625
Hi for all.
I'm new in this forum and we've tried to hack a Z130BT for a long period of time with no success. Someone can help me how to crack this version and change the navigator to iGO?
Page 25 of 49
