Other interesting news: USB Mouse is working!!!...no pointer though but I can click an navigate menues.
haha good one
try also usb keyboard. until we've got not working control panel we cant change options of mouse and keyboard.
somehow we should be able to enable the pointer..
Confirmed that is exactly what was wrong!!! I have a z110 with the shortfuse upgrade and i had the PRG.FLG file did exactly what garrettoomey did and works like a champ now! Thanks man! Now where is everyone getting the igo8 software from?? Where can i get a copy?
Glad that at last you've got working hackmode
about iGO8 - there is no working/free gps port - for now.
[HKEY_LOCAL_MACHINE\SOFTWARE\Information]
"ProgramDrive"="USER"
"ProgramDir0"="PRG0"
"ProgramDir1"="PRG1"
"ProgramFlag"="PRG.FLG"
"ProgramVolumeFile"="VOLUME.DAT"
Its the same, so PRG.FLG is some kind of 'switch' from PRG0 to PRG1, and it runs PRG1 apps.
I think that I will make some script, which will check for PRG.FLG - if yes, then it will run PRG0 av.exe, also user will have to copy prg1 as prg0, and hackmode file to prg1. Little twisted thing
Hey Condi excelent work here! I've tried this on my Z120BT and was able to follow your steps, however, I am not able to copy and paste USER file to the SD card. The selection is greyed out, unless I open USER and select all then copy. But when I move back to SD it will not copy to the root of SD even after the unit says that it is pasting the files. I have even made a "save file" folder on the SD to save to and it still didn't work. Am I missing a step or has Pioneer put a block on this?
I wrote all the description from my memory, there could be some mistakes
Condi,
There is a button for GOOG411 where the phone number is now inactive. BTW I don't have any programming skills, but I do have a question. Would we be able to reprogram the phone number? Using notepad I am able to open the file. The following phone number is inside 14252964544. Would it be as simple as just editing the phone number to a desire number?
Thank you very much.
NDATA\TEL\GOOG411.DAT file contents:
14252964544
BTW I'm referring to the Z110bt/z120bt model.
Make backup of the file, modify, and copy via file explorer or pioneer testmode
If that .DAT file is with plain text, then it should work.
Just try
But what about inactive button? Its because of that number? I will check it also, but after my work, later this day.
Great video
thanks for making and posting, it will help some user to see how testmode ui works!
Can I add it to first post into description?
br
condi
