cnsd 130fm firmware update
By navalion · Aug 21, 2011in General💬 42 posts👁️ 26,179 views
Page 1 of 2
Posted Aug 21, 2011 · 13:11 UTC#1
:unsure: :unsure:this is a cnsd 130fm firmware update files but when the update is starting devise want a administrator code(password for update cnsd) is need a crack or patch for this update can anybody help us???????????????????????
http://www.4shared.com/file/w_uO6zHt/CNSD_130FM_firmupdate.html
Posted Aug 29, 2011 · 10:20 UTC#2
Nice work, navalon! I think, this password is must be send by pioneer.
Posted Sep 11, 2011 · 18:51 UTC#3
can the update be done by replacing files manually through test mode?
Edited Sep 11, 2011 by epa
Posted Sep 11, 2011 · 18:53 UTC#4
no i have try but the device wouldn't run
Posted Sep 11, 2011 · 20:10 UTC#5
I tried replacing the shortfuse hack from the other updates, didnt work either.
Maybe if the same process they used to create the shortfuse hack on that firmware was used to create a similar hack based off of our firmware...........
Posted Sep 12, 2011 · 07:18 UTC#6
try to replace renewallflib.dll in prg0 and prg1 after starting in test mode with this file
RenewalIFLib.rar
Posted Sep 12, 2011 · 22:35 UTC#7
doesn't work, needs password
Posted Sep 13, 2011 · 07:24 UTC#8
yes but u can put in field of password a lot of symbols and push ok
Posted Sep 13, 2011 · 08:46 UTC#9
I try to replace renewallflib.dll in prg0 and prg1 after starting in test mode with this file and after reboot, the updade starts but when i put a number in the password field it doesn´t work.
Posted Sep 13, 2011 · 10:00 UTC#10
insety only a letters no numbers
Posted Sep 13, 2011 · 10:40 UTC#11
Thanks it worked
Posted Sep 13, 2011 · 11:37 UTC#12
Another problem!! Now the system doesnt show de progress bar (numbers)the progress bar turns blue and the information "updating" and does nothing! I tried to reset but no results, and now the system keeps asking for the sd card.
Posted Sep 13, 2011 · 12:40 UTC#13
how to reverse the process?
Posted Sep 13, 2011 · 12:59 UTC#14
I cant go test mode also
Posted Sep 13, 2011 · 15:06 UTC#15
http://www.4shared.com/file/2qgNQLpp/TestMode_by_charlie.html
http://www.4shared.com/file/dSd-mvLh/My_Flash_Disk.html
download this archives decompress on sd card 512mb or smaller put in face plate of device and press reset is mus t go a test mode after you enter in my flash disc select all and delet after enter on sd card/my flash disck select all and copy to the memory of device extract a sd card and push the reset button device is must run
Posted Sep 13, 2011 · 15:13 UTC#16
Thanks but I deleted a file and the system is runing again, i manage to run test mode.
I could'nt manage to install cnsd 130fm, what seems the problem? Did you install the cnsd 130fm sucefully?
Regards
Edited Sep 13, 2011 by rodinhas
Posted Sep 13, 2011 · 15:50 UTC#17
no is an update from service site of pioneer is for a few types of troubles of this device but if the device is runing normal the update does not start, i do not know why
Posted Sep 13, 2011 · 16:00 UTC#18
This update is for changing the firmaware from 10004 to 20003. The F310BT apearence change to F320BT. Its strange the update don´t start
Posted Sep 13, 2011 · 16:04 UTC#19
no is changing to 2.000101
and is only a part of cnsd130fm only the firmware for reinstall a firmware when the device gane a problem with a bluetooth and phone software i have take them from service pioneer on chisinau r. moldova i have a friend working there
Posted Sep 13, 2011 · 16:08 UTC#20
Ok. So doesn´t work on ours! They have no problems!
Regards
Posted Sep 13, 2011 · 16:09 UTC#21
yes
Posted Sep 13, 2011 · 16:10 UTC#22
Can you take the entire cnsd130fm ?
Posted Sep 13, 2011 · 16:12 UTC#23
yes the next week i must go to buy them if u want we can put a money with other 2 my friends a take a card with firmware and install them without a password
Posted Sep 13, 2011 · 16:12 UTC#24
where are u from?
Posted Sep 13, 2011 · 16:13 UTC#25
because a update is different for regions like a USA europe and Australia
Page 1 of 2
