hi sorry this is my first post
i have updated my f900bt with the wrong firmware update and now it keeps rebooting i have tried to load different firmwares onto it with no joy has anyone any idea of what i need to do.
​any info at all appreciated.
Sorry i dint search into this properly at the start i have now tried a number of things stated on this website
i am in Europe and still cant seem to get this working anyone with any help or advice id appreciate it greatly.
After i have done a few installs using the windows program that i downloaded my map version is 02.0000600
version 3.0210000 that means noting to me hopefully it means something to someone on here
yea i have tried that the end bit the link does not work should i be installing the newer version
So i installed the 3021000 update along with doing the steps using windows cm and still haveing the same problem
than you box is dead as i have done it on my f700bt a couple weeks ago and it work perfect...
The box only had the system is loading up problem when i updated it with the new firmware
bump anyone any ideas for how to fix this
Go into my flash disk folder and delete gpspara0-3. there will be 4 of them. Also go to the user folder and delete the Userdata folder. Reboot.
If that doesn't work, sounds like something is wrong with your ezrider/maps/license. I would suggest do a fresh install from any of the firmwares out there without any modifications or maybe get a cracked ezrider with a cracked license. The map update threads have all you need
