Pioneer Z2 Ejecting Problem
By icatc · Sep 23, 2011in Problems/Troubleshooting💬 3 posts👁️ 2,951 views
Posted Sep 23, 2011 · 15:24 UTC#1
Hi guys,
I am new here, and was trying to research a topic but to no avail. I have had Pioneer Z2 for a few years with no problem. 2 weeks ago I replaced my battery and when I went to eject my CD from the unit it would tilt about half way and not fully open. I am hearing the motor and everything working. I then have to close it by tilting the screen back into the normal position. I tried everything to fully eject the CD but nothing works. Do you guys have any idea? Thanks. Also the CD still plays perfect. Thanks again.
Posted Sep 23, 2011 · 15:29 UTC#2
The part you need is called RACK and the part number is CZN7014 and cost $16.95.
http://parts.pioneerelectronics.com/par ... um=CZN7014
Here is a link to a post by member Toro34 showing how to disassemble and replace the RACK (great write up):
viewtopic.php?f=19&t=23674
I have repaired 2 of these by reusing the existing RACK with 2 of the 4 'tabs' broken. I am not a repair shop, but just helping friends. Taking it apart and reinstalling the broken RACK has worked in the past, so you may give it a shot as a temp fix until you can get the part.
Edited Oct 31, 2011 by garrettoomey
Posted Apr 08, 2012 · 18:38 UTC#3
Thanks for the info Garrett! My Z3 has had issues with the screen tilting 1/2 way when the car is turned off and then either not wanting to tilt properly after or not tilting at all when turned on. Hopefully this will fix it.
