The issue im having now with ios 5 and the x920bt, with before and after the cnsd 210fm update is this battle between what source is actually active.
Example:
You plug your iphone 4 with ios 5 in to the unit via the cable.
Automatically the source switches to "ipod" and music starts playing
You select via the audio source selection menu on the unit, Pandora for example
Notice says to start pandora up on your device , you start pandora on the device
pandora info will show up on the screen, music will play from pandora for an instant, then pause.
You have to move to ipod source to get pandora to un-pause, (no tapping pause on ipod source necessary you just have to be at this source)
Go back to pandora after 5 seconds and it will remain unpaused and play normal.
I found out if you continuously pause/un pause pandora it will eventually stay un paused.
This same issue happens with aha as well, but hitting the pause button continuously doesn't help.
I am happy it works but it is frustrating.
The main issue is, when you have the 3.0 update for the x920bt, do we get bug fix point updates? Where would it be available under the x920bt page or the x930bt page.
I am really hoping its just iphone app updates that need to fix this and its not the x920bt needing the update.
ios5 is near final and its doing this, sounds like it might be an issue with the unit not knowing how to interact/control the iphone because of changes in ios.
Anyone else have ios 5 having this issue?
I guess we will find out when aha, and pandora are updated for ios 5. Hopefully the issues are fixed, who knows if 3.0 x920bt will be updated to fix it if that is in fact the problem.
