To get around the password,
Download the official firmware from Pioneer, Download AVIC-Z120BT Firmware Update Version 2.003
Then download the firmware hack, AVICZ110BT-2.004.zip (25.75K)
Extract both .ZIP files. You will now have one folder called " AVICZ110 " this is the official update, and you will have two files " EU090APL.VER " and " RenewalIFLib.dll ".
Cut the " EU090APL.VER " file and past into the " AVICZ110 " folder replacing the original file. Now cut the " RenewalIFLib.dll " and paste into " AVICZ110/APL " folder, again replacing the original file.
Copy the " AVICZ110 folder to the root of you SD card.
Insert the SD card into your 120 and let the unit update.
To update maps,
Assuming you are in the US, download this torrent, " http://thepiratebay....M_US_CAN_UPDATE "
Extract the .rar. You will have two folders called " SD1 " " and SD1 ". Open the " SD1 " folder and copy the contents, 2 folders and 1 file, onto a blank SD card.
Insert the SD card into your 120. You will be asked for a password, type in " PASSWORDPASSWORD ", then let the unit update. This will take around 15 min. This will update maps and apps. Remove the SD card.
Clear the SD card and open the folder " SD2 " copy the folder called " FIRMWARE ", to your SD card.
Insert the SD card into your 120 and let the unit update. This will update the Bluetooth. Remove the SD card.
That should be it if I didn't forget anything.
