iPhone & iTouch IOS 5.0.1+ Wifi-sync to Pioneer!
By RiccoFX · Dec 08, 2011in General💬 32 posts👁️ 5,817 views
Page 1 of 2
Posted Dec 08, 2011 · 06:03 UTC#1
This is AWESOME! If you leave your iPhone or iTouch in your vehicle, and if you have IOS 5.0.1+ on your device, and have WIFI-Sync turned on, you can sync music and videos to it wirelessly from inside the house! (as long as it is in range of your wifi)
I can add/change songs, videos, playlists, and then press the sync button to my iTouch or iPhone thats been left connected to my pioneer deck, and it'll sync wirelessly while I'm in the house and my truck is outside! How awesome is that! No longer needing to bring the iTouch in! I just leave it, if I find a cool tune or vid, I just add to iTunes, and sync, and voila its in my truck!!!
Have fun!!!
Edited Dec 15, 2011 by RiccoFX
Posted Dec 08, 2011 · 13:09 UTC#2
Cool, I didn't even realize theat my iTouch could sync over WiFi. Since I only ever remove it from the car to sync w/iTunes, I can now hide it more securely in a hidden spot under the dash.
But are you sure the USB is still powered? How did you verify this? I'm not sure if I like that it is still drawing power. My make of car already has lots of power-drawing features that make it difficult to leave it un-attended from more than a few weeks (without a trickle charger). Oh, and here's a great "feature". The battery is in the trunk, but the trunk release is electric. OK, there is a manual way, but you need to remove a wheel and fender liner to get to it. And guess where the jack and wheel lock key are stored?
Anyway, my point is that I'm not crazy about the idea of the iPod charger being energized with the ignition off. I also wonder about overcharging and the affect of constant charging would have on the iPod's battery life.
Posted Dec 09, 2011 · 00:50 UTC#3
This is AWESOME! If you leave your iPhone or iTouch connected to your Pioneer AVICZ130BT or AVICX930BT, the Pioneer deck will keep the USB powered when you shut off your vehicle, as long as its been connected
That is likely very vehicle specific or your head unit is actually connected to the vehicle's power incorrectly.
Posted Dec 09, 2011 · 04:05 UTC#4
Nope, I have confirmed
Nope, I have confirmed it, when I shut off the truck, the deck shuts off, and I look at the iTouch and it shows that its connected to power. But once I disconnect it, and then try to connect again, there is no longer any power. Its similar to the XBOX360 USB charge port, as its still connected while shutdown, the USB is still powered after shutdown until the device is disconnected. My Truck shuts off, my pioneer deck shutsoff, the screen folds back in (from being angled out) and nothing is on except power to the itouch, which is in standby. I go into my house, check my iTunes, click on the iTouch, it'll then search for it, find it and sync to it. And it is NOT connected incorrectly! I am a Master Car Audio Installer and the Constant is tied to Yellow and the ACC is tide to red.... I'm not dumb! Epecially when I shut the truck off the deck and all amps shut off! Obviously its turned off! Just not the USB, as long as its still connected.
Edited Dec 09, 2011 by RiccoFX
Posted Dec 09, 2011 · 04:07 UTC#5
I'll make a vid of it as soon as I can!
Posted Dec 09, 2011 · 04:13 UTC#6
The iPhone/iTouch has its own built-in charging system, you cannot overcharge it! As soon as the battery is full, it'll stop charging and just stay on standby... which uses soo little amount of power, you won't notice it! Heck I see alot of ppl with their satellite radios plugged in power all the time and left on, even after leaving the vehicle, which draws 10 times the amount of an IPOD charging and especially standby!
And obviously if you're gonna leave it and un-attended for a few weeks than more likely you should disconnect it! This is great for the daily commute and I even parked it over the weekends for 3 days and still have plenty of power to start my truck. If I'm going away then definetely be removing it, plus if I do go away for long periods, more likely I would be taking my iTouch anyways!
And I know theres power still after shuttinf off becuase on top of my iTouch and iPhone it shows the charger symbol, plus if it wasn't I wouldn't be able to SYNC it by WIFI! I'll post a video as soon as I can...
I have the AVIC-Z130BT, iPhone 4S, my wifes iPhone 3GS, my iTouch 4G and my wifes iTouch 3G, which ALL works on my deck, so I can confirm it works on this model, unless I got a special one!
Posted Dec 09, 2011 · 04:22 UTC#7
If you guys don't believe me, If you have the AVIC-Z130BT, and iPhone or iTouch running on IOS 5.0.1+, with WIFI Sync enabled... why don't you try it! Or atleast while your iTouch or iPhone is connected, shut off your vehicle, watch as your deck shuts off, and look at your iPhone/iTouch screen! (u may have to press home or power key to wake the screen up) You'll see the charger or plugged in symbol on the battery indicator!
I found this out by browsing my iTunes, and normally will see my devices that are plugged in in the usb charger, and one day I left my iTouch in the truck. As I was browsing iTunes, I noticed that my iTouch was connected and syncing, and was going WTF? My iTouch is in my truck! So I went on and created a new playlist, and synced it again, went to the truck, and the playlist was there! then I was wondering how is that possible, WIFI sync only works if its plugged in for power! So I checked it out, and to my surprise my iTouch shows being plugged it while my truck and deck is off! But as soon as I disconnect it, the USB power drops, and I try to reconnect, and now nolonger any power on usb unless I start up the truck again! I have checked everything out and confirmed it that it all works, I have being doing this for over a week now, and I know for a fact my deck is OFF, I even confirmed the ACC power going in, deck is off, screen is off, amps are off, truck is off!
I just posted this to let you guys know, if you doubt me, I don't care, all I know is that THIS WORKS FOR toME! If it doesn't for you, TOO BAD FOR YOU THEN!!!
Posted Dec 09, 2011 · 13:59 UTC#8
RiccoFX,
Hey, I wasn't doubting you, but was trying to understand any possible down side. I'll try some experiments when I get a chance - need to upgrade to iOS 5.x first. I leave my 3rd Gen iTouch in the car all the time except when I feel like adding songs or editing playlists - which isn't too often. I don't remember what OS version I'm at. Also - I wonder if this applies to all of the Z1xx series - or just the z130 hardware? I've got an upgraded z110.
I still want to verify that the USB is actually powered. I've got a USB powered accessory LED light that will allow me to quickly test this. If it does stay ON, I want to understand the effects and limits. For example - if, as you say, the iTouch charging logic senses it is fully charged and shuts down, does the HU quit feeding power and shut down? Or maybe will continue to provide 5VDC forever until the device is unplugged? There must be active circuits on the HU to sense the demand and do the 12V -> 5V step-down. That would probably draw more car battery current than the actual iTouch charging. What happens over an extended period of time? Does the iTouch WiFi still work after a couple days in standby?
BTW, you've just presented observations and a hypothesis - which seems logical based on what you report. But the same could be said for the notion that the Sun orbits around the Earth. I'm just saying there may be other things going on here.
Posted Dec 09, 2011 · 14:35 UTC#9
The sync over wifi option is great primarily for those who use an updated iPod touch and leave it in their car. If this worked for my 160gb iPod Classic that I just leave in my car I would be so happy. I realize that isn't possible because it doesn't even have wifi but it was a nice thought none the less.
Posted Dec 10, 2011 · 04:31 UTC#10
Then show this working on the next 5 installs you do on different vehicles then Ill believe you have confirmed it. Saying you've confirmed it on one car that may have something unique going on is not confirmation.
Edited Dec 10, 2011 by VBLUE42
Posted Dec 10, 2011 · 20:51 UTC#11
Well it doesn't keep the power on with my Z110 with CNSD-210FM upgrade. USB power stays on about 5 seconds then turns off. Tried with iTouch and a USB powered LED.
Can anyone w/Z130 test this? Simple - get your iTouch/iPhone out where you can see it with the car on. Turn off your ignition. If your iThing display turns off - just press the center button to turn on the display. Watch the battery/charging icon in the upper right corner. Does it stay charging for more than a few seconds? Yeah I didn't think so.
BTW, RiccoFX, thanks for the tip about WiFi sync. I hadn't followed the new features in iOS 5.x since I only use the iTouch in the car through the HU. However, after a few hours, I see from my PS that the iPod is no longer visible from iTunes. Maybe it times-out - or it goes into some power-saver mode to preserve battery life.
Edited Dec 12, 2011 by RonS
Posted Dec 13, 2011 · 00:30 UTC#12
Well as soon as I can get a video up I'll post it, besides, even if you don't have power, you can STILL sync to your iPhone/iTouch Device regardless of being plugged in, as long as WIFI Sync is Enabled and is within range! Maybe my deck has a defect (a good one for me) or whatever but mine does still show power connected, but besides the point, mine and my friends iPhones they can sync anytime as long as they are within WIFI! So still if you wish leave your iTouch 3G or 4G or newer with IOS 5.0 or newer with WIFI sync on, and still get the same results!
My main point was to let eveyone know you can leave your idevice (That supports IOS 5.0+ and WIFI SYNC) in the car and update it wirelessly without having to remove it!
Edited Dec 13, 2011 by RiccoFX
Posted Dec 13, 2011 · 02:53 UTC#13
I understand your intensions and certainly appreciate them. I just wanted to make it clear that this may not be a feature that everyone can take advantage of if its only unique to a certain vehicle or install. Also, per the iOS5 wording for the settings for WiFi Sync, it only works if powered and plugged in. Again, if power is not retained for most people this wont work.
Posted Dec 13, 2011 · 05:41 UTC#14
Actually the wording is MISUNDERSTOOD! The wording is for "AUTOMATICALLY SYNCing" when connected to a Power Source, but you can SYNC at ANYTIME!!! Why don't you try it or check this out...
http://forums.macrum...d.php?t=1249199
http://forums.tipb.c...connection.html
Keyword here is "Automatically"
You can manually inituate the SYNC if your iDevice is not connected to power, otherwise it'll do it for you "automatically" when plugged in.
Works on my Wife's 3GS, my 4GS, iTouch 3G and 4G... I know for a fact because I have tried it! My iPhone is next to me right now, not connected at all, and its syncing right now as we speak thru wifi, not plugged in! 3 of my friends confirm it as well with theirs...
Just wondering if anyone on here even has an iDevice that has IOS5.0 on it, or am I the only one using an iDevice (with IOS5.0.1) on my Pioneer!
Posted Dec 13, 2011 · 13:27 UTC#15
I updated my OS last Saturday so I could try out your tip. And, yes - I noticed that it also worked without being connected. However, the only way I found to get my iTouch to show-up on the PC iTunes was to have it connected/charging. After it shows up in iTunes, I can disconnect it.
When you manually sync (not connected), are you initiating it from the iDevice? Must be - cause it doesn't show up on the PC so you can't sync it.
BTW. I also finally installed Pandora on the iTouch. Kinda nice, but it required manually starting the app on the iTouch b4 you can use it with the HU. Not very practical if you are driving, and the iTouch is hidden in a storage compartment. I guess I'll try it as a novelty, but I'll probably mostly just play music off my iTouch.
Posted Dec 13, 2011 · 15:24 UTC#16
This is actually what I was referring to. I get the same thing.
Posted Dec 13, 2011 · 20:02 UTC#17
Then obviously you guys have something set up wrong because I can do it as well as many of my friends can without having power/plugged in. Also its on those LINKS I've provided plus even google it, it DOES work, otherwise there is a setting your missing or your WIFI setup is not working properly.
My phone shows up all the time and only disappears when I'm either too far away from the WIFI or I Eject it manually, otherwise its always showing on my itunes, all of my devices too, my iPhone4S, wife's 3GS and both of our iTouches 3G and 4G...
Posted Dec 13, 2011 · 22:11 UTC#18
Obviously - Nothing happens automatically - unless you are always running iTunes on your PC. So don't assume we're idiots. And it sounds like we are all agree, iDevice needs to be powered on - one way or another.
However, since it isn't always charging - like you claimed - the iTouch eventually shuts down WiFi.
Basically, it works sorta like you say if I start iTunes within a short time (maybe a few hours) of shutting down my car. If I wait too long, the iPod isn't visible in itunes. Then, all I have to do is go turn on ACC in the car for a short time. Then go inside and voila - ipod is there in iTunes.
Edited Dec 13, 2011 by RonS
Posted Dec 14, 2011 · 01:34 UTC#19
According to the following article, you can not WiFi sync from iTunes without the iDevice plugged into some type of power source. You can only do this if you initiate the sync from the device. And sense only you have power always to your iDevice even when your car is turned off, only you can enjoy this. If you can initiate sync from itunes with you iDevice unplugged to a power source please demo this on Youtube for everyone else to see.
http://www.tipb.com/2011/10/24/daily-tip-set-itunes-wifi-sync-windows/
Posted Dec 14, 2011 · 01:50 UTC#20
Obviously the link you sent me, you DIDN"t READ all of it. It merely says the AUTOSYNC will not work without it being plugged in, but you can sync manually without power. I have confirm with 5 friends with iphones and they all can do it!
Taken from the link you sent:
"That’s it, now as long as iTunes is open on your PC, as soon as you plug your iPhone, iPod touch, or iPad into the power outlet, it should appear in iTunes and sync over Wi-Fi.
(Yes — It has to be plugged in to the power for this to work, so you are really just cutting the cord to the PC not to the wall!)
If you want to initiate a sync manually, you can do this from your iOS device and you don’t need to be plugged into a power outlet."
And I can sync from both my phone or by iTunes, at anytime, I did it at 2am in the morning, not connected to power on the coffee table, and still showed in my itunes.
Also Read the comment quote #4
I'll upload a video of it as soon as I get a chance to show you.
While your at it why don't you check this link:
and this one
http://forums.macrum...d.php?t=1278650
Edited Dec 14, 2011 by RiccoFX
Posted Dec 14, 2011 · 07:06 UTC#21
Here is the video you all been waiting for!
I have my older 3GS (if 3GS works so should 4 and 4S, which I left at work - oops!) sitting here in standby, for about a few hours without being plugged in or touched or turned on (just standby), and then I go onto my laptop, start up iTunes, wait for my iphone to show (takes a few secs to a minute depending on your network), it then pops up, does its startup/pre-connection circle thingy until it connects and shows the Eject button, then I press the sync button, it'll search for my iPhone, connect and start syncing, all from within my iTunes on my laptop...
Also check your virus programs, firewalls, and network connections from blocking any incoming/outgoing connections to your iPhone/iTouch!
5 other friends of mine do the same thing, this all works for them too! 2 have the AVIC-930BT and a iTouch 4G, so they love this leaving in the vehicle, the other 3 just have it hooked up as an AUX input to there deck, but don't have to bring them in anymore!
I hope you guys that are having problems can solve the issues you are having, maybe firewall, network/router settings? I can access my phone or touch at ANY time, there is no timed-out or anything, unless your router's wifi settings or some other setting is causing it to disconnect (maybe some type of idle mode/no activity autodisconnect option).
Because when it works, its so great and convenient! It was always a PAIN to remember to bring in the iTouch or forget the iPhone in the car all the time! I usually leave my iphone in my truck connected for netflix and never really use my phone in the house often anyways, just take it out during the day while im out and about and when I'm away from the truck, but leave it in the truck overnight, except tonight I left my 4S at work! So my old 3GS is shown here doing what I mentioned! I'll post a video of my deck retaining power which is not necessary or required anyways for alot of ppl since you can SYNC regardless!
If still no go, try this,
Open the windows firewall settings, and look if "SyncServer.exe" is allowed. I'm gonna guess it isn't even listed silly.gif
Instructions (Windows 7 x64 - Vista is probably similar):
Open "Control Panel"
Select "Windows Firewall"
Click "Allow a program or feature through Windows Firewall"
Look for "SyncServer" in the list. It won't be there.
Click "Add program" or "Change Settings" then "Allow another program"
Click "Browse..."
Find "C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\SyncServer.exe"
Restart iTunes and your iPod/Phone/Pad should appear in iTunes even when disconnected. If not, try rebooting to make sure everything is reloaded properly.
Also you can try to reboot your device too, don't just put it to sleep, actually power it off fully and power it back on... that seems to solve alot of issues such as 3G connection, WIFI connection, etc.
Posted Dec 14, 2011 · 15:19 UTC#22
Just did it again this morning, not plugged in on the coffee table since 2:30am, its now 9:17am, went on itunes, it pops up, and still can sync! No timed-out or wifi shutdown at all! Like I said in the last post check your syncserver.exe in your firewall settings!
Posted Dec 15, 2011 · 02:20 UTC#23
I agree with that works only on ios 5.0.1
Posted Dec 15, 2011 · 02:32 UTC#24
So this is a 5.0.1 thing or what?
Posted Dec 15, 2011 · 04:58 UTC#25
yes. It is 5.0.1 and the ios 5.0 only works if the idevices plugged into the power source but the ios 5.0.1 doesn't need to be plugged into the power source.
Page 1 of 2
