Z120 upgraded to Z130: bypass doesn't work?
By bones302 · Jan 30, 2012in Problems/Troubleshooting💬 10 posts👁️ 2,366 views
Posted Jan 30, 2012 · 13:32 UTC#1
Hi guys, don't know if this has been covered, but I searched.
I have the Z120BT and did the bypass on it with no problems.
Yesterday I upgraded the software to a Z130BT with 2011 maps and updated the bluetooth firmware as well. Now, on start-up I get a notification that it has detected a problem with the parking brake wiring. I also can't search for an adress while I'm moving but it wil let me search POI.
I know the Z130 has a different harness than the Z120 and I'm thinking this may have something to do with it. When I went to connection status, it's showing that parking brake is on. I don't want to deal with this notification every time I startup so I have 2 questions:
Is anyone aware of a fix for this situation?
If no, can/how do I revert back to Z120 to clear the update and have it work the way it did before?
thanks in advance.
Edited Jan 30, 2012 by bones302
Posted Jul 04, 2012 · 20:47 UTC#2
What was the outcome? Thanks.
Posted Jul 04, 2012 · 20:50 UTC#3
If the bypass doesn't work then it is defective. It has nothing to do with the software upgrade. And who told you the harnesses were different?
Posted Jul 04, 2012 · 21:20 UTC#4
Okay, good to hear, and the logic seem to make sense.
That's what i thought until i saw this in YouTube showing the connector. And the placement of the mute wire seem to be different in the X930/Z130 models than say, the Z120.
Posted Jul 22, 2012 · 02:54 UTC#5
I have the exact same issue after the upgrade.
Posted Aug 05, 2012 · 18:43 UTC#6
This thread would seem to indicate that the harnesses are different,
http://avic411.com/i...130bt-bypassed/
So where does the mute pin need to move to on a 110 to 130?
Edited Aug 05, 2012 by dallas5cowns
Posted Aug 05, 2012 · 23:38 UTC#7
All the harnesses are the same as well as the bypass proceeders in this series of units.
Edited Aug 05, 2012 by VBLUE42
Posted Aug 06, 2012 · 01:47 UTC#8
okay, then I don't understand why the bypass is no longer working. As soon as I hit 5MPH I get the message that the parking brake is not properly connected, but the connection status shows the parking brake is "ON".
I understand the harness is the same, but are the wires in the same position? Does the mute wire go to the same pin location and then to ground?
Edited Aug 06, 2012 by dallas5cowns
Posted Aug 06, 2012 · 13:28 UTC#9
All bypasses are the same means the answer to your question is yes. Your relocated mute wire is not seated properly or is otherwise defective. Get in there and start wiggling it around until it starts working again.
Posted Aug 07, 2012 · 04:31 UTC#10
Working now in original location.... What can I say, you're right again. :)
