Downgrade Firmware ?
By Dejan · Feb 01, 2012in AppRadio, AppRadio 2, AppRadio 3💬 37 posts👁️ 17,368 views
Page 2 of 2
Posted Feb 11, 2013 · 11:31 UTC#26
The latest firmware of DA01 (also DA02 I think) allows to turn OFF auto launch. So you can avoid the automatic iPhone popup if you want, no need to downgrade firmware for that reason.
Also, at the moment apps don't work because they need iOS6.1 update. So downgrading firmware will not help for that problem.
Posted Feb 11, 2013 · 12:55 UTC#27
I want to downgrade to version 2.46 to install AppRadio plus
Edited Feb 12, 2013 by getafe83
Posted Feb 12, 2013 · 19:13 UTC#28
Appradio plus is full compatible with the last appradio firmware Check link in the topic jailbreak appradio
Posted Feb 13, 2013 · 03:04 UTC#29
Hi  I upgraded to 2.45 on my appradio and I am really regretting it since my bypass no longer works. I am new to this and would really appreciate it if someone could supply me with the 2.22 firmware for the "FIRST APP RADIO" SPH-DA02, and how to install it. Is it just like doing the normal firmware update. Any help would be greatly appreciated
Thankyou
Ron
Posted Feb 13, 2013 · 09:17 UTC#30
Hi Dejan!
thank you for your response, and thank your contributions to this forum :)
I tried to read the topic but I found no answer to confirm that the Jailbreak work in DA02 AppRadio in version 4.14. I read that someone did not work. I use google to translate and do not quite understand what I read.
  if you could tell me how to install Appplus in DA02 with 4.14 or where it gets. Thank you very much.
Posted Feb 13, 2013 · 10:30 UTC#31
Hello, sorry but appradio plus is only compatible with the first appradio spd-da01
All other appradio is not compatible.
Posted Feb 14, 2013 · 09:31 UTC#32
Can somebody help me downgrade pioneer firmware from 2.63 to 2.56 ?
Posted Feb 14, 2013 · 12:16 UTC#33
Why downgrade ? have you problem in 2.63 ?
Posted Feb 14, 2013 · 13:49 UTC#34
Yeah i have. my radio is very slow not responsive when iam on the app ex.
I tried everything except for downgrading that is my last hope i almost gave up.
Edited Feb 14, 2013 by funkystyles
Posted Mar 26, 2013 · 02:12 UTC#35
So let me get this stright app radio plus will not work on a SPH-DA02no matter what firm ware is installed ?
Is there that much of a change in hardware between the two units?
is anyone working on porting app radio plus to the 02 or is just getting left by the wayside?
Thank in advance for any info
Posted Mar 26, 2013 · 20:45 UTC#36
Does the 02 have an SD card slot?
Posted Mar 27, 2013 · 00:14 UTC#37
Yes it does seems to be allmost identical as far as apperances I know that the firmware updates are not the same .
when I try to load appradio plus it gives me an error message about expected 2.45 and then closes.
Page 2 of 2
