Is there a 940bt bypass
By ibdrinken · Apr 05, 2012in Hacks/Mods💬 38 posts👁️ 19,220 views
Page 2 of 2
Posted May 13, 2012 · 14:45 UTC#26
even if you break the white tab off aslong as you don't damage the plug to much it will be fine
mine snapped off i pulled up to hard on it but i was able to push it back in to the plug harness and it works fine
i know when i or if i upgrade to the 940 and don't wait for the update to come out
or if this time next year when they pull out wit a 950 or waht ever model might be next i hope the harness will be the same so i don't have to mess with the bypass or anyting
Posted May 17, 2012 · 05:45 UTC#27
Dude- check out the second youtube video on the first page. He sticks a straightened-out staple in the tiny hole on the opposite side. You just stick it in there about a quarter inch or so and it releases the wire. Comes right out.
Posted Jun 11, 2012 · 01:46 UTC#28
Bypass works great on my 940BT. Followed the directions from the first video.
Edit: Bypass stopped working due to navigation picking up current speed. I am going to play around with it tomorrow at best buy and see if I can find a way to tap into the navigation antenna to turn it on and off when needed instead of unplugging it all together.
Edited Jun 16, 2012 by giggitygoo123
Posted Jun 17, 2012 · 22:46 UTC#29
Works like a charm!!! Thanks guys..
Move the yellow pin up one, ground the yellow,green wires, and ur bypassed!!! Easy peazy
Posted Jun 23, 2012 · 17:34 UTC#31
I just registered here because I installed a x940 last night and can confirm the videos are correct. On my harness, I just had to move the yellow wire up one notch.
Posted Jul 06, 2012 · 20:01 UTC#32
I am going to get 940 installed tomorrow. can you please also clarify if you also had to ground the other wires as mentioned in some videos OR just had to move the yellow wire up one? Thanks!
Posted Jul 08, 2012 · 18:50 UTC#33
I got the 940BT installed yesterday but the bypass is not working. The bypass was done using the steps in Video 1..it cuts off video after 40-45 speed with an attention message. anyone else had this issue after the bypass and suggestions to fix it?
Posted Oct 18, 2012 · 23:06 UTC#34
I got the bypass working for the 940bt the first time... using this...
http://www.ebay.com/...984.m1436.l2649
I went ahead and bought an extra wire, because I didn't want to remove the mute wire and re-use it. I wanted to keep the wire where it was, and just add an additional one. This kit was all hooked up with the proper connector and ready to go. Basically plug and play.
On the other end of the wire... I joined the Parking brake wire (green) + this bypass wire + pioneer ground (black) + harness ground (black) together.
Edited Oct 18, 2012 by soze
Posted Oct 26, 2012 · 15:09 UTC#35
does moving the mute wire pose an issue for the bluetooth on the radio?
Posted Oct 28, 2012 · 10:18 UTC#36
No.
Posted Dec 26, 2012 · 23:33 UTC#37
I hate to bring up an old thread but thought it be better than starting a new one on this topic. With the bypass can I grab any extra wire and use it bc I have to use the mute wire for my truck.
Posted Dec 27, 2012 · 02:34 UTC#38
I believe using the hack posted on this forum, you lose Mute. However, I know I had a pro install done and they used a microbypass and I still have mute. If you search on youtube, there is a video for the other method using a microbypass, which I believe you can do yourself.
Page 2 of 2
