🔒 Locked
AppRadio Extensions 2.0 Beta - Full iPhone control
By mikedecaro · May 06, 2012in AppRadio, AppRadio 2, AppRadio 3💬 2,444 posts👁️ 945,070 views
Page 57 of 98
Posted May 14, 2013 · 17:35 UTC#1401
in my case the touch signal is like if they would run on full screen.
Which iphone you own? In my case the problem appears with iphone 4.
Posted May 15, 2013 · 20:25 UTC#1402
I've got an iPhone 4s.
Mike, yesterday I installed Dimmer (http://phoenix-dev.com/cydia/dimmer/) and it broke my video signal from appex. Maby you can add this to the first post.
Posted May 15, 2013 · 21:04 UTC#1403
Hi, I am also new to the site and would like to know if its possible to use the app extentions on the new pioneer 8500BHS. I have the app radio app, Jailbroke iphone 5 running version 6.1. If it s not available now, Mike do u see it being possible in future?
The HU is great but would like to be able to use more of the unsupported apps from the phone. Right now I can mirror anything through the display but have no touch functions on the HU other than the basic supported ones like pandora.
Not sure that this HU has advanced app mode?
Thanks in advance
Posted May 15, 2013 · 23:25 UTC#1404
Thanks in advance
Yes works with 8500 and iPhone 5. Touch works too with newest appex version. If you install let me know if you run into an issue with appradio crashing after 20 seconds of not touching the screen. I have your same setup and everything works except that.
Posted May 16, 2013 · 12:40 UTC#1405
Thanks for the reply Aznluder. I read through most pages of the post. I think i'm still missing something. I downloaded all dependencies and the 2.0.0-173 in cydia. I dont know how open an unsupported app. I'll read back through the post to see if i missed something but any advice is appreciated.
Posted May 16, 2013 · 13:27 UTC#1406
You mean you don't see any unsupported apps in the head unit?
In settings -> appex, make sure unsupported apps is enabled and you have each app you want shown turned on in "show in menu"
And do full reboot if you haven't already.
Posted May 16, 2013 · 13:33 UTC#1407
Yes make sure you check in the STOCK Settings app and then scroll down to AppEx settings.
Posted May 16, 2013 · 15:12 UTC#1408
Yes didnt see any unsupported apps on the HU or the phone. Doing a reeboot now.
Are the settings you refer to on the phone or HU ? I dont see App Ex settings in either location. Thanks for replies and please overlook my ignorance on this.
Posted May 16, 2013 · 16:08 UTC#1409
As I just stated in the post above yours, it's in the STOCK settings app. The silver icon with the gears... :P
Posted May 16, 2013 · 17:20 UTC#1410
LOL. ok ok. after the reboot and knowing to look in the STOCK settings. Everything is working. Thanks again for your help...
Only glitch i had at first was with lanscape lock on and text message being visible was when i disconnected the iphone from the lightning connecter all my text were still showing in lanscape even with the phone upright. I removed the txt message from being shown in the menu and toggled lanscape lock on and off and its working fine now.
Glad I found this forumn
THANKS!
Posted May 16, 2013 · 17:40 UTC#1411
THANKS!
LoL you're very welcome kind sir. :P Glad you got it sorted out. :)
Posted May 16, 2013 · 18:02 UTC#1412
THANKS!
That happens to me too but what's weird is this happens even when I'm not connected to the lightning cable. Just being connected to Bluetooth makes my text message to landscape when I'm holding it portraits. In a way that's good so that I'm not texting and driving.
Sorry I wasn't more clear regarding where the settings were. I'm guessing you're not having any of the appradio crashing issue I'm having. I can't think of any other Cydia tweak installed that would cause it.
Posted May 16, 2013 · 20:05 UTC#1413
no crashes so far. fingers crossed.
However when i installed tvtuner out a few weeks ago every app i had on my phone crashed. I know this is pointed out as a known problem on the first page, but was a big problem for me for an hour or so before i figured out what was going on.
Posted May 16, 2013 · 21:19 UTC#1414
Mine too. Messages.app rotating even without the cable connected.
Posted May 17, 2013 · 07:55 UTC#1415
Hi, I´m a new user of pioneer SPH-DA02. I´m from Spain and my english is not good, sorry...
Ok I´m Working in a hardware adaptor for iphone/ipad lighting to de DA02 head... BUT I need the pinout funtions in a wire from 30 pins to pioneer unit... (i´m looking for pins audio and video)... anyone knows???
The idea is to use two adaptors from apple, one from iPhone 5 to vga and lighting (have and work very well over vga screens) and another to lighting to 30 pin (for audio) one by one... Ok, the vga out can use with adaptor via to rca composite... (have one and work well) now have audio and video from iphone 5 to tv (for exemple) and want to connect to pioneer head But I dont know the pinout....
I think it can work, someone has proven ???
THIS IS THE IDEA
Uploaded with ImageShack.us
Edited May 17, 2013 by ttupra
Posted May 18, 2013 · 13:27 UTC#1416
Hi, I am having trouble getting unsupported apps to show up in the iPhone appradio app. Here's what I have-
iPhone 4 6.1.3 (semi tethered 6.0)
Latest Appradio installed
Appradio Extensions 2.0.1-173
And I have added a few apps via iOS settings
Any help welcome
Posted May 18, 2013 · 18:58 UTC#1417
Any help welcome
Did you go into the phone settings and set what you wanted to show???
Posted May 18, 2013 · 19:34 UTC#1418
Thanks for the reply. Yes I added a few, but they don't show in the app on the phone, I tried a reboot too. Navfree is the only thing that shows up (green tick) the rest are just recomended apps
Posted May 18, 2013 · 19:54 UTC#1419
They don't show in the app, they show on the unit.
Posted May 18, 2013 · 20:06 UTC#1420
That explains it then, I'm a idiot lol. Thanks
Posted May 20, 2013 · 04:26 UTC#1421
Wasn't there a "Home" button on prior versions of AppEx to let you get to the Home Screen of the iPhone (not the Home screen for App Radio on the head unit).  I believe the icon was an iPhone that said Home under it.  I have the latest version of AppEx but don't see an option to add that.  I see the Home option for Pandora but nothing under show in menu either.
Edited May 20, 2013 by Preroll
Posted May 20, 2013 · 04:53 UTC#1422
It's already been discussed that it is not available in this version.
Posted May 20, 2013 · 05:57 UTC#1423
Ok thanks.  I was hoping to get control of the home screen's task bar (double clicking) via the head unit to kill all apps instead of doing it by the phone itself.  Although if it's really stuck, that probably wouldn't do much good anyway. :?
Posted May 20, 2013 · 17:28 UTC#1424
I managed to get all the apps I need up and running, but when I'm using any sat nav (TomTom, Waze, Freenav) I cant get the radio DAB or FM to work. I tried the double tap on the headunit and selected a source, but it just took me back to the sat nav with no sound.
Is it supposed to play the radio when using sat nav?
Posted May 20, 2013 · 17:42 UTC#1425
@mikedecaro I find the old voice control far better than Siri for voice dialling. Any chance you can update AppEx to launch voice control when Siri is disabled (at the moment, the button disappears)? Thanks!
Page 57 of 98
