[BOUNTY] Full Android Control with the Appradio 2 $600 so far!!
By Spike98 · May 24, 2012in AppRadio, AppRadio 2, AppRadio 3💬 80 posts👁️ 18,230 views
Page 3 of 4
Posted Oct 01, 2012 · 18:16 UTC#51
Awesome! The only reason I bought my APpradio 2 is because I saw this app.
Downloading it now, guess I should get my cable and root my phone.
I'm new to Android and just got an S3. Does it neeed to be rooted in order to use ARLiberator?
Posted Oct 01, 2012 · 18:37 UTC#52
Yes you do need root access to use the ARLiberator app :)
Posted Oct 01, 2012 · 18:49 UTC#53
Thanks! AppRadio2 is on order, just got my S3, have the Samsung adapter and car charger ready. Now to read up on rooting :)
Posted Oct 01, 2012 · 19:48 UTC#54
Yep all your going to need is root and your on your way it's really awesome your going to love it.
Posted Oct 02, 2012 · 06:09 UTC#55
I'll be testing it out next week some time. Hopefully the phone doesn't get too hot.
Also, guys: "Your" != "you're" in any situation.
Posted Oct 03, 2012 · 22:16 UTC#56
I have found the phone doesn't get anywhere near as hot with ARLiberator as it does with Pioneers app.
Edited Oct 03, 2012 by 400ixl
Posted Oct 04, 2012 · 23:42 UTC#57
Agreed. I don't think it places anywhere near the same load on the phone that appradio did.
Posted Oct 05, 2012 · 01:29 UTC#58
That is fantastic news, guys! Perhaps the battery will at least trickle charge then.
Posted Oct 05, 2012 · 02:35 UTC#59
I've been saying for a while that my phone charges fine with mhl.
Ever since ARLiberator became my primary means of using the radio I can't keep the phone charged.
The only thing I can think of as a culprit is the fact that the phone has to use it's internal GPS for mapping now.
Posted Oct 05, 2012 · 03:30 UTC#60
Can anybody reccommend a Root program that a "Everyday Jim" can use? I'm not the best with this stuff, and I don't want to end up destroying my phone trying to root it.. Thanks
Posted Oct 05, 2012 · 03:53 UTC#61
It really depends on what phone you have. If you head over to XDA to your phone forum, look for a tool kit. It makes most rooting chores easy.
Edited Oct 05, 2012 by outcastrc
Posted Oct 06, 2012 · 13:48 UTC#62
It varies by phone. You would need to do research to find out.
Posted Oct 09, 2012 · 13:14 UTC#63
Ok, I'm stupid but I can't find a donate link. I want to send my $50 as promised....not cheap out and get it from the store.
Posted Oct 09, 2012 · 13:31 UTC#64
You'll want to purchase it from the store and then send the rest via donation. That way you get stable releases. Go over to Appradio forum . com and pm stackTrase who is the developer.
Edited Oct 09, 2012 by outcastrc
Posted Oct 09, 2012 · 13:48 UTC#65
Thank You!
Posted Oct 13, 2012 · 14:19 UTC#66
Just a heads up I just noticed this thread over on XDA, don't know if it'll work with this but some one should try it
http://forum.xda-developers.com/showthread.php?t=1927547
[APP] Turn screen off while MHL / HDMI mirroring / Downloading data
Posted Oct 13, 2012 · 21:24 UTC#67
http://forum.xda-dev...d.php?t=1927547
No different to any of the existing apps. Switches off the backlight. Fine on an LCD, but on AMOLED it doesn't blank the screen.
Posted Oct 14, 2012 · 03:47 UTC#68
Says it works with all devices including the Galaxy Nexus (AMOLED), by just turning the screen brightness to 0.
Better link: http://forum.xda-dev...d.php?t=1934495
Edited Oct 14, 2012 by EvanVanVan
Posted Oct 14, 2012 · 13:37 UTC#69
I finally got a chance to test it, and turns off the screen on my Galaxy Nexus...
Can't test with the AppRadio though because I don't have an MHL cable (I returned all the cheap ones I bought and cant decided whether to buy the official connectivity kit or modify a cheap one as kagronick suggested.)
Posted Oct 15, 2012 · 02:54 UTC#70
Anyone have any luck using ARLiberator on a rooted Razr running ICS with the AppRadio 2? I still seem to have the BT issues and ARLiberator never connects to the head unit.
Edited Oct 15, 2012 by gbcobra
Posted Oct 16, 2012 · 12:13 UTC#71
There's a couple of threads on this topic at appradioforums.com. The app named tasker can be your friend. Either I have no memory left or my method of pairing changes each time, but I have the best luck connecting the phone (both hdmi and usb) first, then starting ARL, then starting the vehicle.
texbuck
Posted Oct 17, 2012 · 07:16 UTC#72
Turning the brightness to 0 on an AMOLED screen does not blank the screen, just turns off the backlight. There have been apps out that do that for a long while. There is someone developing a new method of switching off the voltage to the screen which should blank it properly.
Posted Oct 17, 2012 · 11:56 UTC#73
It's in the same link that you quoted. It's working on amoled phones, but some of them are having issues with turning the display back on. I think that issue is resolved as well
texbuck
Posted Oct 17, 2012 · 15:11 UTC#74
Ok, but turning off the backlight saves battery and keeps the phone from over heating, the main problems when trying to mirror MHL for long periods of time.
Posted Oct 18, 2012 · 04:17 UTC#75
There is no backlight on an AMOLED screen. The pixels themselves light up. It turns the brightness down to 0, which isn't the same as shutting off the backlight.
BTW, this does not work on my S3. If the screen brightness is turned to 0, the phone goes into standby mode.
Page 3 of 4
