Galaxy S3
By jhanson999 · Jun 18, 2012in AppRadio, AppRadio 2, AppRadio 3💬 65 posts👁️ 27,454 views
Page 3 of 3
Posted Aug 15, 2012 · 22:15 UTC#51
Yes you need to use the official adapter. I have both the full mhl adapter and the adapter time that will allow you to use an older adapter and both work well.
Mine charges the phone as well. Make sure you're using a decent charger that puts out at least 1 amp.
Posted Aug 16, 2012 · 07:46 UTC#52
Thanks for the confirmation. I cant wait to get my unit in.
Posted Aug 16, 2012 · 08:54 UTC#53
A bit off topic, but do any of you guys experience cut off pixels on the left and right edges of the screen when you hook it up to your TV? It does on my Sony 32" XBR4 (720p), and I can't figure out why since I'm on the full screen setting on the TV. I am assuming it works properly on the AppRadio 2 since it resizes the image anyway.
Posted Aug 16, 2012 · 15:39 UTC#54
It happens from time to time on my appradio 2 as well but isn't really too noticeable.
Posted Aug 17, 2012 · 16:25 UTC#55
looks like tasker is too slow on the dpad again? anyone else having this issue?
Posted Aug 21, 2012 · 12:26 UTC#56
Hi to all,
I have read the entire post and i have some dudes.
I'm going to acquire a Z140BH and i got a Galaxy S3... I know that this is not the AppRadio2, but I think that problemwould be similar in both models, because I want to connect them to use the Z140BH AppRadio mode..
Please, can someone tell me what do i need to connect both, for using for example appRadio???
I don´t know if I have to buy the "Android Connection Kit" , or if it could be enough with the "Samsung Galaxy S3 MHL/HDMI Adaptor"... Or if I have to buy both...
Thank you so much ;).
Posted Aug 21, 2012 · 14:14 UTC#57
Only the AppRadio2 supports Android devices. Any other radio with advanced app mode will only work with iPhones/iPods.
Posted Aug 21, 2012 · 20:44 UTC#59
FYI this doesn't work for the US phones so be careful.
Posted Oct 15, 2012 · 23:33 UTC#61
Correct
Posted Dec 24, 2012 · 06:00 UTC#62
I already have a pioneer android cable installed is there a converter for the new MHL port on the S3 to save replacing the entire cable?
Posted Dec 24, 2012 · 14:30 UTC#63
Yes there is, but be sure to get the samsung branded one. People using the cheap counterfeit adapters are experiencing video snow and are attributing that issue to the adapter.
Posted Apr 19, 2013 · 07:12 UTC#64
What adapter is needed if i already have pieonner Android cable?
Posted Apr 20, 2013 · 13:59 UTC#65
Yeah, I get the same annoying bluetooth pairing request everytime. I've scripted around it using tasker. Heres what I have:
TASK 1: "Pairing Request" - Event -> UI -> New Window: Label: Bluetooth pairing request, Window Type: Dialog
Actions:
1) Input -> Dpad -> Button Down Repeat 2 Times
2) Input -> Dpad -> Button Right 1 Time
3) Input -> Dpad -> Button Press 1 Time
4) Variable -> Variable Set -> Name: ¬ceptBluetooth To: true
TASK 2: "Bluetooth Accepted" - Event -> Variable -> Variable Changed, Variable: ¬ceptBluetooth Value: true
Actions:
1) App -> Load App -> AppRadio
2) Display -> Auto Brightness -> Set: Off
3) Display -> Display Brightness -> Level 0
4) Task -> Wait, 10 Seconds
5) App -> Load App -> AppRadio
What task manager u using?
Page 3 of 3
