I have the AVIC f900bt that has come up with (system is starting up please wait) at first I tryed up dateing the fime ware. When this did nothing I called the place that installed it for me and they told me it had to go back the Pioneer. I have been told that it has a problem on the Nav board and that it most be replaced at a cost of £270.00 plus VAT is there any thing I can do so not to have to pay out more money on this unit I have only had it for 3yrs. Any help GREATLY APECIATED
AVIC-F900BT System starting up..please wait
Your in UK correct? You need to do the reboot loop fix but with Euro files
Hye why the link cant be open. I need the flask disk backup.
please i need to dowload My flash disk back up for euro unit (avic f900bt )but this link http://webdesignsfor... Flash Disk.rar no more valid there is another link???? please i need your help
Hello, Guy's have a Avic-f900bt, and i am trying to download the reboot fix, link is dead, pls help to get files. thanks in advance
Одна проблема Ñтоит где Ñкачать файл HTTP: //web design for...lash%20Disk.rar
ÑÑылка не дейÑтвует
Hi all
I have found the solution of rebooting.
First of all, you must have your avic on 2.09 version.
Then, you download the 3.021000 version, you dezipe it and you take the LPUE080 and you put it on a sd card which is formated by fat 32.
After this,you go back to LPUE080,you open it, into it you find a PLT file, you open it and you find two files named winceimg.bin and winceimg.cks ,you copy them(don't cut )and you paste them into the sd card with the LPUE080 folder.
Now,you go ahead to your car. You put the sd card into the avic ,and with a stylet in reset and fingers on eject,menu,map,you push at the same time. After 7 secondes, you take off the stylet and you continue with the others. When you see the screen becomes blue, you take off fingers .
At this moment, you must enter this pastword with a joystick :
up,up,down,menu bottom, left,right. (You must see a star for each action )
When you have finished with password, you will see a menu at the screen center up.you push the joystick center to valid .It takes you to a new menu.With the joystick, you go down to the second line and you valid.
Let's the avic read the sd card, when you see "restart your device"at the center down of the screen, you turn off your car, keep the sd card into the avic. Wait at least 10 secondes and turn on your car ,20 secondes at least after ,the screen goes to the white and deletes all the wrong folders and files in the avic after it finishes ,the avic automatically copies the new folders which are in 3.021000 version.
After 100%,turn off your car ,take off the sd card.And enjoy:your avic will be perfect.
NB:I have used this procedure to fix my avic f700bt European version and it works fine.
i have this problem too ...i tried with official update, but at 70% has error and after this the test mode doesnt work anymore ![]()
any ideea?
