2012 US/CAN Maps - CNSD-310FM/UC upgrade (updated to supereasymethod - beta)
By pionara · Sep 20, 2012in Hacks/Mods💬 645 posts👁️ 199,662 views
Page 17 of 26
Posted Feb 20, 2013 · 07:46 UTC#401
Hi! Would love to download the upgrade but it appears there are no seeds for the TPB torrent. I've had it up leeching for a few days and I'm still at 0%.
Is there a static place to download the file?
Or should I just wait a while until a seed appears?
Just found you guys. Thanks for all the hard work!:)
Posted Feb 20, 2013 · 20:45 UTC#402
Succesfully updated my AVIC F30BT with the EU version. Everything went smoothly. Thnx for the post!
Hello sorry if I ask you.
I have your same unit, and I'm using it in Italy.
Could you tell me the version of Update to download right?
I do not want to make mistakes difficult to repair.
Thank you very much.
Bye and sorry for my bad English.
Posted Feb 26, 2013 · 23:35 UTC#403
Does anyone know whats the difference with the US English and US English (Samantha) TTS in the Voice selection?+
edit: I figured out that i can change the voice selection in the settings.
Edited Feb 27, 2013 by xxxclusive11
Posted Mar 03, 2013 · 07:42 UTC#404
I just updated my Z120BT with the instructions provided (and reading the complete thread) and had no issues.
I then proceeded to update my X930BT in my daily driver, and again had no problems.
Thanks for providing the information.
Ian
Posted Mar 07, 2013 · 13:31 UTC#405
I tried to use the condi update and now my unit is locked up. I went to get this torrent but it seems like no one is seeding it anymore where can I download the new stuff for X920. Please Help!!
Posted Mar 12, 2013 · 13:01 UTC#407
Thanks for all the info.  Worked on my 920 that had 3.0 already installed.  I needed to change the two files on the first post. All is good.
My favorite thing about the update is that I now have current XM channel logos.  Its been a few years since I've had them all correct.
Thanks again
:mrgreen:
Posted Mar 13, 2013 · 00:35 UTC#408
Z120
Everything seemed to update properly until I tried to use the navigation. It shows the map and the route but doesn't zoom in at the turns and where there is suppose to be voice guidance she says "due to limited data guidance cannot be provided in this area"
I checked my service info screen and noticed there is a ---------- next to CAN Version:
Any ideas?
Posted Mar 13, 2013 · 04:21 UTC#409
darkzide, are you in canada?
that can version is for canbus, not canada. If you dont have an oem installed radio (like subaru or volkswagen) then you wont have a version for that. Try a reset and resetup.
Posted Mar 13, 2013 · 06:42 UTC#410
So im new to this group and trying to update my z110bt to the newer map pack. Any tips/tricks and advice on how to do this without any complications?
Suprised someone hasnt made a video yet for this.
Posted Mar 13, 2013 · 06:56 UTC#411
I seem to be having trouble downloading using my mac, I have downloaded the torrent and tried to open up documents but it says its not supported. I saw a post between rons, and drpaul84 talking briefly about it maybe either one of you could help me out i would appreciate it thanks!
Edited Mar 13, 2013 by yngfr3sh
Posted Mar 13, 2013 · 12:38 UTC#412
darkzide, are you in canada?that can version is for canbus, not canada. If you dont have an oem installed radio (like subaru or volkswagen) then you wont have a version for that. Try a reset and resetup.
I am in the US. The map shows all the street names and plans the route correctly, just no voice guidance.
Do you mean reset as in disconnect battery?
Posted Mar 13, 2013 · 18:36 UTC#413
buana sera. sono nuovo su questo forum, e siccome sono italiano volevo sapere se questo aggiornamento e compreso la lingua italiana e le mappe italiane.possiedo un avic f930bt.
ps:complimenti per il forum mi aiuto a leggere con il traduttore
Bwana evening. I'm new on this forum, and since I'm Italian and I wanted to know if this update including the Italian language and maps italiane.possiedo a avic F930BT.
ps: congratulations for the forum helped me to read the translator
Posted Mar 15, 2013 · 00:50 UTC#414
I disconnected the battery, reinstalled the update but she still gives me that same message "due to limited data guidance cannot be provided in this area"
Posted Mar 16, 2013 · 00:29 UTC#415
Other than content, is there a big visual difference between the old and new maps?   I've looked around for photos but they are hard to find -- especially ones showing comparable routes.
Thanks.  John
Posted Mar 16, 2013 · 17:50 UTC#416
Hey everyone! It seems as if the torrent file is dead. Does anyone have an alternate link to download (i.e. dropbox or similar)? I would definitely appreciate it!
Posted Mar 17, 2013 · 16:26 UTC#417
Can i do the update from USB?
Posted Mar 17, 2013 · 21:55 UTC#418
I see around 16 seeds on this torrent.  No you need to use the SD card.
Posted Mar 19, 2013 · 04:48 UTC#419
For some reason, I cannot get the torrent to download no matter how many trackers I add to it. Anyone have another link to download?
Posted Mar 22, 2013 · 01:32 UTC#420
I did the supereasy mod and it seemed to work fine.  Only problem is the GPS says im in a differant state than I'm in.  I disconnected the battery for 30 minutes in hopes to reset with no luck.
Any ideas.
Posted Mar 25, 2013 · 16:17 UTC#421
You have to fix GPS signal, to show your current location, until you don't fix gps signal, it will show different state than you are.
Posted Mar 26, 2013 · 00:44 UTC#422
ran update from http://www.pioneerelectronics.com/PUSA/Car/GPS-Navigation/AVIC-X920BT?tab=firmware tried replacing files as mentioned here http://avic411.com/index.php?/topic/35230-2012-uscan-maps-cnsd-310fmuc-upgrade-updated-to-supereasymethod-beta/?hl=%20920bt%20%20firmware and basically stock now with "insert correct SD card" message ..... any way to revert? this is avic-920bt not the x920bt ... any thoughts?
thanks !
update, followed this post http://avic411.com/index.php?/topic/35230-2012-uscan-maps-cnsd-310fmuc-upgrade-updated-to-supereasymethod-beta/page-21?&do=findComment&comment=259388 and was able to update with updated cardinfo.cif
AVIC-X920BT purchased in june 2010
version 04.0000
Edited Mar 27, 2013 by vnikulin
Posted Mar 26, 2013 · 20:14 UTC#423
I have loaded the new maps 2012 as per fist post, everything loaded fine however once I took it out for a test run I noticed that my deck , z130bt, would map the road correctly but not give voice direction.  instead it told me insufficient data for this area...  I read other having the same issue but no answer to the problem.  If you could help I would be grateful and to make clear I have read all post thus far.  If I missed a solution  your direction would be great. thanks all and great site.  by the way I used the auto method for the update as per this thread.
Posted Mar 27, 2013 · 20:30 UTC#424
I posted a problem that I had while I attempted to remove the nag screen here: (by the way the nag screen is gone now) :mrgreen:
http://avic411.com/index.php?/topic/35523-remove-caution-nag-screen-bypass-hack/page-6
But it seems that after many attempts to repair this and reload the upgrade, the only problem that I have now is it is stuck in a reboot loop.
It boots, radios work and I can navigate screens briefly  until it reboots again.
Just begging for help but I will buy the beer.
Z130BT upgraded to Z140
Posted Mar 28, 2013 · 00:24 UTC#425
After reading all the posts in the thread, the one suggestion to resolve this issue is to remove power from the unit by pulling the fuse or disconnectng both the red and yellow power wires for at least 30 minutes and then try it.
Page 17 of 26
