USA/Canada 2011 Q4 (2012) Navteq Maps - Complete Guide
By Bento · Oct 09, 2012in Hacks/Mods💬 11 posts👁️ 13,398 views
Posted Oct 09, 2012 · 21:48 UTC#1
Navteq 2011 Q4 (Released in 2012) Maps for the United States & Canada
For Europe see: European 2012 Q1 TeleAtlas/TomTom Maps - Complete Guide
I have not tested these maps as I live in Europe but they should work just fine. Please report so if it does work for you and which unit you use. This should also work for the F700 and up. Not sure about the F500.
I haven't updated to firmware 4 yet but this should work for firmware 4.x as well.
Instructions:
  • Download the files below
  • Extract them to the root of your SD card
  • Insert SD card with only the folders from the ZIP file in the root
  • Boot the unit in testmode (if you have the testmode folder in the root this will happen automagically)
  • Make a complete backup of the flashdrive! (Instructions)
  • Verify your backup is correct and copy this over to you PC so you have 2 backups.
  • Go into the iGo/CONTENT folder. On my unit this folder is located in the APL2 folder.
  • Delete the MAP, POI and LICENSE folders
  • Copy the MAP, POI and LICENSE folders from the SD card to the flashdrive of your unit
  • Copy the EZRIDER.EXE to the iGo folder, replacing the file already there
  • Now reboot the unit, remove the SD card and enjoy the latest maps smile.gif
Links are interchangable (parts are the same).
Rapidshare (Uploaded 9/10/2012)
https://rapidshare.com/files/1260645918/iGO US Canada Navteq 2011 Q4 (2012).zip.006
https://rapidshare.com/files/2980242128/iGO US Canada Navteq 2011 Q4 (2012).zip.005
https://rapidshare.com/files/3030705813/iGO US Canada Navteq 2011 Q4 (2012).zip.002
https://rapidshare.com/files/3635018613/iGO US Canada Navteq 2011 Q4 (2012).zip.001
https://rapidshare.com/files/897024168/iGO US Canada Navteq 2011 Q4 (2012).zip.003
https://rapidshare.com/files/2395614913/iGO US Canada Navteq 2011 Q4 (2012).zip.004
Usenet (Uploaded 9/10/2012)
Download the attached ZIP file for the NZB
If you messed up your unit just get back into testmode and restore the files you backed-up.
Enjoy your new maps :-)
Cheers,
Bento
testmode.zip
iGO US Canada Navteq 2011 Q4 (2012).zip.zip
Edited Oct 09, 2012 by Bento
Posted Oct 10, 2012 · 19:27 UTC#2
Hi.
Can you tell me what is (iGO US Canada Navteq 2011 Q4 (2012).zip ) for ?
Posted Oct 11, 2012 · 00:07 UTC#3
That's the NZB to download from Usenet.
Posted Oct 11, 2012 · 02:03 UTC#4
The PIO is not working in Canada . and who can upload the new BT firmware or cnsd-300fm for us ? THANKS
Posted Oct 11, 2012 · 02:04 UTC#5
Sorry is POI nor PIO
Posted Oct 11, 2012 · 15:39 UTC#6
Is the folder called PIO? If that's the case I made a slight mistake :-) If it's not working then I can't help you, I'm not running these maps on my unit.
Posted Nov 28, 2012 · 21:42 UTC#8
Download not available
File owner's public traffic exhausted.
Posted Dec 23, 2012 · 02:07 UTC#9
if anyone gets the error about exceeding the traffic limit just wait till 6pm eastern standard time and you should be able to download the files.
Edited Dec 23, 2012 by ws6nightcat84
Posted Mar 11, 2013 · 21:12 UTC#10
The instructional link to make a back up copy of the flashdrive does not work. Keep getting a Can't be Found error message.
I have an AVIC-F900BT with Map Version 01.000600 and Version 2.008000.
Thanks.
