Full AppRadio2 control via Android phone via ARLiberator App
By kman1971 · Oct 21, 2012in AppRadio, AppRadio 2, AppRadio 3💬 57 posts👁️ 60,935 views
Page 1 of 3
Posted Oct 21, 2012 · 22:36 UTC#1
Finally!!!!!!!
Just released on Google Play, the ARLiberator App gives you full control of your Android phone via the head unit. I just got done testing it and it worked like the appradio2 should of when it was released. The app is $29 but worth every penny. Best app I have ever purchased so far.
I have the Motorola Droid Razr Maxx. I had to root my phone with a free droid razr root utility 1.81 via my computer, just do a google search, and then uninstall the appradio app from my phone. Connect the phone via hdmi, launch the ARLiberator App, pair via bluetooth to your phone, go through the head unit onscreen calibration where you touch 4 red dots..... and then you have full control of your Android phone via touch screen on your head unit. Simply awesome!!!!!
Sorry if this is old news, but I couldn't be happier right now and had to share the news.
Posted Oct 22, 2012 · 12:52 UTC#2
Also, the free Screen Standby app in the google play store works great with the Razr Maxx too, so you can turn off your phone screen when it is docked to the head unit.
Posted Oct 22, 2012 · 14:01 UTC#3
OK, so what am I doing wrong? I've rooted my phone, un-installed appradio- app from my phone and cleared the previous bluetooth connection. I now connect my phone, and immediately get a pairing request. I hit pair, open up the app and all I get is "connecting". No dots, no connection. I am using a Motorola Driod Razr on 4.0.4. I've gone to the developer's site and can't find line by line instructions on how to do it, so I hope I'm just missing a step or something. Was I supposed to take out Car Keyboard or Car Media Player?
Edited Oct 22, 2012 by westchesteraudio
Posted Oct 22, 2012 · 15:10 UTC#4
Have you tried going into the arliberator app and the far top right settings tab, click it and click the calibration tab, this should bring you to the red dot calibration on your head unit.
Also, hit the ? on the arliberator app and check the superuser tab, this will check and see if your phone is rooted and working properly.
Posted Oct 22, 2012 · 15:17 UTC#6
I hope that works, but if not, they have full support at the following forum, just register for free and put up a post under the help desk topic and they will respond with a solution pretty quick....
http://appradioforums.com/Forum-Help-Desk
Posted Oct 22, 2012 · 15:18 UTC#7
Thanks Kman. I did what your first post says, I got the red dots but from the radio I can't tap the dots. Let me try your utility, I'lll get back shortly
Posted Oct 22, 2012 · 16:59 UTC#8
Yea, I had the same problem at first, I used an older version of the utility that did not root my phone properly, once I used the 1.82 version, it worked like a charm.
Posted Oct 22, 2012 · 23:09 UTC#9
OK, so your root program worked. I guess that was my problem. Now I can get the app to work, but it takes quite a bit of fiddeling. I still have to pair it every time I power the car off, and I've found I have no audio (on App Audio Sources) UNLESS, I turn the bluetooth connection off, in that specific app. For example, Pandora had no audio, I went into Pandora's settings, turned off Bluetooth Audio, and now I have sound. Same with my music gallery. Is this normal?
Posted Oct 23, 2012 · 09:20 UTC#10
Does not seem normal to me, I didn't have any issues with the sound on any app. I would check with the appradio.com forum help desk if you are still having issues.... wish i could help more
Posted Oct 23, 2012 · 11:55 UTC#11
Do you still have the appradio app installed? If so, just uninstall it. It has been known to cause conflicts with ARLiberator. Audio and video come through the hdmi port while bluetooth is for touch events and handsfree calling.
The pairing issue still continues, but the dev is working on it. Appradio needs to download your google contacts list every time it starts up, which is a royal pain. I think this will be resolved soon since this is the next priority item for the dev.
texbuck
Edited Oct 23, 2012 by texbuck
Posted Oct 23, 2012 · 14:19 UTC#12
The pairing every time is an issue and it seemed to start after the ICS upgrade. Hopefully it is just a matter of time for an upgrade to fix it so that once you pair, it does it automatically every time in the future. Having to wait for the pair request and then quickly touch the pair when it pops up before it disappears is a real PITA...
Posted Oct 23, 2012 · 14:51 UTC#13
I do have appradio un-installed, along with car keyboard. I can't find the trick to getting it to work, it seems totally random. When it connects it does work great! I've tried opening AR first then connecting to Appradio, pairing bluetooth first then opening AR and finally connecting to Appradio. There doesn't seem to be a way that works everytime. I've browsed all the forums, but I can't find anybody with the same phone having my exact issue. Thanks for the advice on the root kit though.
Posted Oct 23, 2012 · 16:30 UTC#14
yea, try the help desk, it is getting way better, you would think pioneer would have figured this out before releasing it...wtf..
Posted Oct 23, 2012 · 16:40 UTC#15
Pioneer isn't behind the AR lib..... Are they?
Posted Oct 23, 2012 · 17:58 UTC#16
i don't think so, but it wouldn't suprise me....any way to get a few more bucks out of us...
Posted Oct 23, 2012 · 18:06 UTC#17
I also put a help post on the re-occuring pairing issue with the razr's. Hopefully someone has a fix for it and if and when I find out, I will post it here too.
Posted Oct 24, 2012 · 03:08 UTC#18
No ARLiberator was reverse engineered by the dev. I don't imagine Pioneer condoning the app, so we'll have to be wary of firmware updates to the deck,
Posted Oct 24, 2012 · 04:14 UTC#19
That would be Pioneer. They won't fix it themselves but they'll probably screw who ever is trying to fix it.
Posted Oct 24, 2012 · 15:26 UTC#20
Man, wish we could have this for iPhone.
Posted Oct 26, 2012 · 13:46 UTC#21
If you jailbreak your phone you can download an app from cydia called appradio extenstions and it does the same thing arliberator. There are also videos on youtube. Check it out.
I have the Galaxy S3 and purchaed ARliberator to have full function of my phone. I use spotify all of the time and Google Maps/Navigation so being able to control my phone from the appradio for these two apps was fully worth the $29. Plus the dev is very active over in the appradio forums and provides betas and support to everyone that has issues so i'm not complaining about the money. Other HU's that have built in navigation cost at least $200 more than what the appradio 2 costs so I feel I techinically saved money. I also just downloaded an app called "screen standby root" from the play store and it dims the screen burightness down to zero when connected via mhl. I'll be testing that feature out later on today when I get in my car!
Posted Nov 04, 2012 · 21:58 UTC#22
Hi guys,
So Idelgado782, if I understood everything, with ARliberator, you got Spotify directly on your appradio' device and you're able to control the skip, pause, play, stop directly on the touchscreen ? or I'm wrong.
If I'm rightn are you also able to change and choose in your different playlist ? or you're oblige to do it directly on your phone ?
Do you have the skin album on the screen' device ? or just button to control the volume or the music command. ?
Thanks for your answer and It would be great a little video on youtube ....
cheers ;-)
Posted Nov 13, 2012 · 15:25 UTC#23
Does anybody knows if this also will work with the Avic-F940BT/Avic-X940BT, or similar HU's with firmware 4?
Posted Nov 14, 2012 · 04:19 UTC#24
Hey Pierre. Sorry it took me so long to respond. Yes I have the actual app on my phone and not a skin. I'll post up a vid on YouTube tomorrow. I've been meaning to do a review of the appradio with arliberator anyways so tomorrow I'll get to it.
Posted Dec 26, 2012 · 23:27 UTC#25
The Arliberator seems to have fixed the pair everytime issue with the razr max. Now I just have to popped my phone on the dock, hit the arliberator connect button and I have full touch screen control of my phone on the AppRadio 2. It only takes seconds now instead of minutes.
The best android app I ever purchased.
PERFECT!!!!!!
Page 1 of 3
