ipod touch 4G compatible...in stand alone gps app...
By yonel · Nov 14, 2012in AppRadio, AppRadio 2, AppRadio 3💬 37 posts👁️ 9,563 views
Page 1 of 2
Posted Nov 14, 2012 · 21:44 UTC#1
hi to everyone, i've decided to buy a second hand ipod touch 4g...
all works like the iphone 4...of course...no datas...
i've bought it, just in the idea to not disconnect and connect everytime de connecting plug wire....
i was expecting to use gps stand alone app, live navefree wich have all France map in 1gigabite memory on ipod...
i was expecting that my appradio gps antena will take control and nothing ????!!!! ( even on "airplane" mode...)
when i look in general setup, gps appradio device is ok with signal....so what to think about this appradio antenna ?
not worth anything ?
for info, i'm in last firmware both on ipod and appradio
Edited Feb 22, 2013 by yonel
Posted Nov 15, 2012 · 15:14 UTC#2
I'm very impressed with the antenna. When not in use, my phone would take anywhere from 30 seconds to 2 minutes to get a lock. With the antenna enabled, the satellite lock is almost instantaneous. Have you checked to make sure the antenna is plugged in all the way? If I remember, it slides in easily until about the last 2 mm or so. I hope this helps. Good luck.
texbuck
Posted Nov 15, 2012 · 20:26 UTC#3
thanks tex for your fast answer !! i confirm that's exactly what you say with the iphone4 , no problem on that point.
now you ask me if i cheked the gps antenna ?
physically no...because appradio setup says gps signal is "ok"
that's why i thought it will complete ipod gps app....( it's like a kind of gps port com not configured or something like that....or maybe the app itself can't make the link with appradio gps antenna )
do you mean something else ?
Edited Nov 15, 2012 by yonel
Posted Nov 20, 2012 · 19:09 UTC#4
don't ask me "how" but now it works.....even with waze gps...???
Posted Dec 30, 2012 · 12:05 UTC#5
sorry, i didn't have time to do the video...
I thought it could work correct, but to be honnest, not so much.
that depend how "important" it's for you...
I don't know if it's due to an update, but navfree gps on ipod touch shows me on appradio "no gps signal" !!!
it's completly crazy because we know the appradio gps antena is there...but don't work....
whereas if you use Waze gps, it works BUT .... if you begin your road trip from an available wifi internet ( in the idea of keeping the main datas in a kind of temporary memory in waze / ipod touch )
it can even sometimes show you warnings such as "police control, radars , etc..." it takes the info i don't know how during driving, but it works " sometimes" not all the time...
so i that config", i must say it works but approximative works....( keeping that way, it's better to share an internet connection from a main mobile phone so that the ipod touch runs correct with appradio, if you have no extra "cost" of sharing network, like here in france...)
or...the best solution...taking a "second hand" old iphone 4 ( when you compare the price between the 2 devices, better almost to buy an iphone 4 )
so here my opinion...
Posted Dec 30, 2012 · 14:32 UTC#6
Si g bien compris ton probleme afin de le resoudre c simple avant de lancer le gps tu dois lancer l application appradio cela active ton antenne gps :-)
Posted Dec 30, 2012 · 18:08 UTC#7
Dejan, ok, mais par défaut, je lance déjà "appradio" sur ipod touch...et navfree me dit " pas de gps"....???
une astuce ?
( even if i launch appradio first, i don't remember it says gps "ok" with navfree, anyway i have to launch appradio app )
Posted Dec 30, 2012 · 20:44 UTC#8
Vire navfree ? Et prend Igo ;-) navfree c'est tout sauf un gps...
Posted Dec 30, 2012 · 21:31 UTC#9
il faudrait voir comment igo reagit sur ipod touch4 avec le gps du sph-da100...
( must see how igo react in ipod touch on the gps of the sph....)
Posted Dec 30, 2012 · 21:48 UTC#10
Ba telecharge un ipa (ou une version gratuite genre une des US ou Hongry) et voie :-) en toute logique cela devrai bien aller puisque l'appradio prendra le relais...
Posted Jan 01, 2013 · 06:16 UTC#11
so have to try with jailbroken ipod and igo....je n'en suis pas là mais je garde ça dans les tuyaux...merci
Posted Feb 21, 2013 · 22:44 UTC#12
i get back to this topic...
i wasn't sure of all functions of the ipod, with gps issues...not sure, i've rebuy a new ipod 4G....
so with new ios 6.1.2...
i've tryed maps "native" app from appradio....the da01 gps works with maps and ipod touch 4G but without data connection, maps are not refreshed...so we see that we move with the bluepoint but no maps....(if anybody have an idea to keep maps in memory without data connection...)
i'wasn't sure if it would works the same with igo...but i was suprised to see that igo in ipod touch works well connected with the DA01 gps antena.....
so i can confirm that this solution have to work, but i didn't bought the igo appradio extension display...( have warning message on da01 )
i didn't try with waze yet, and any other like navfree....
see this week end....but i'm happy to let the ipod touch hiden in the car, use my other phone as a modem with shared connection to the ipod, and use the ipod without "connect and disconnect" physically...everytime...( connector is more and more easy to broke )
and with itune sync in wifi....that can be cool.
i just would like to thanks some great persons that helped me to be sure that can work...because nothing is said about this kind of setup ( ipod4G ), in both pioneer or igo side....
Edited Feb 21, 2013 by yonel
Posted Feb 22, 2013 · 16:32 UTC#13
Excuse me Yonel!
To clarify, I make sure that it works with an ipod4 an iGo? Work correctly?
Thanks in advance
Posted Feb 22, 2013 · 18:09 UTC#14
All apple device actived (4gt) works with all gps application (via appradio gps recever) must launch with appradio application
Posted Feb 22, 2013 · 20:28 UTC#15
Dejan helped me, confirming me that it must work because his iphone 4 didn't work with the gps iphone antena ( broken...)
so when i tried maps with my ipod 4G, i had the first sign that "maps" application use gps appradio antena....
i got chance to download igo app 2.4 and i just have to add the "igo appradio extension"  ( i don't have it yet ) but for now, as i launch igo, the ipod localize where i am with appradio da01 antenna !!!
So it's sure for 95% , just let me time to do a video démo this week end, videos talk better....
And i think Dejan is right, but i didn't believed, till i saw it myself. ( i wasn't sure if the igo app from the ipod 4G could make the "link" to the gps pioneer da01 antenna, but now, sur it is !!! )
( is it due to os 6.1 update, compare to my "old" os 5....i have to test other apps too, but igo, the main one, is good and "great" !!! )
Posted Feb 23, 2013 · 13:56 UTC#16
something curious.....if i don't launch maps before....igo gps signal won't work...????
if i launch maps, and close, and launch igo...gps signal is ok.... :?
Posted Feb 23, 2013 · 17:27 UTC#17
Je t'ai dis il faut absolument lancer igo depuis l'appradio afin d'activer la puce GPS si tu lance en direct l'appradii n'acrive pas son antenne gps deporte
Posted Feb 23, 2013 · 23:18 UTC#18
YA WOHL MEIN GENERAL, ABER j'avais oublié :P
j'ai completement zappé ça...et c'est d'ailleurs pourquoi waze marchait tres bien à mon retour de taverny en offline...
you're completly right, this info is very important to notice to every user....
seems we have to launch first appradio app from da01 first to "activate" it gps device...
Edited Feb 23, 2013 by yonel
Posted Feb 27, 2013 · 07:36 UTC#19
i completly don't understand , one hour before it connected perfectly with gps signal, and now, almost not.
is there something wrong ?
Posted Feb 27, 2013 · 07:41 UTC#20
  • the main difference was the wifi connection available due to the hotspot of my house... :s
Posted Feb 27, 2013 · 07:44 UTC#21
or problem to the connecting wire ???????? ( gps pins in 30 pins connector ? )
Posted Feb 27, 2013 · 23:15 UTC#22
i retry tonight, it connected me 1 minute....
the appradio igo addon doesn't make direct link with a kind of setup as external management gps device ( DA01...)
maybe my connector is wrong....
if i turn off localisation service, DA01 show me "your gps device is off"....
Posted Feb 28, 2013 · 17:01 UTC#23
I've tried the ipod alone today in paris, it connected me sometime a short moment, without any kind off connection....
so does anybody knows what is the gps DA01 used to do ?
Posted Mar 08, 2013 · 07:21 UTC#24
Confirm Completly compatibility:
iPod 4 Touch (firmw.6.1.2)
Pioneer AppRadio SPH DA01 (Firmw.:2.63)
and navigation software iGo Prime, Waze,Nav Free, Navigon, Sygic (Last two by AppRadio Extensions).
Ipod receive GPS signal from radio.IPOD NOT RECEIVED GPS SIGNAL FROM THE UNIT WHEN IT'S WI-FI LINKED WITH IPHONE!
in this mode not use the radio antenna but I think that of iPhone!
Edited Mar 12, 2013 by jones66
Posted Mar 21, 2013 · 05:26 UTC#25
Yesterday I had GPS signal problems now, I have risolved unistall and reinstall the appradio interface software utilitity on iGo store, but before link the radio I have disable wi-fi connection on iPod. Fixing signal immediatly!
Edited Mar 21, 2013 by jones66
Page 1 of 2
