PLX Kiwi or GoPoint BT1 worth it?
By s84kam · Mar 24, 2013in AppRadio, AppRadio 2, AppRadio 3💬 44 posts👁️ 15,974 views
Page 1 of 2
Posted Mar 24, 2013 · 20:57 UTC#1
So I'd like to tech up my car this summer and I was thinking about buying the PLX kiwi with the dash command app. Now its kinda pricey and there isn't a huge fan base for this, so i wanted to ask a specific quesion.
Can the dash command be used at the same time WITH radio or ipod music? this is obviously a make or break it deal. I really want to see all my engine parameters and fuel economy, it would just be better with music :mrgreen:
Posted Mar 25, 2013 · 01:43 UTC#2
Yes you can.
Posted Mar 25, 2013 · 02:08 UTC#3
Yes.
Posted Mar 26, 2013 · 04:35 UTC#4
I currently run my AppRadio2 with DashCommand.  The program is pretty badass overall, and it does work with music playing.
Is the PLX worth it....absolutely not.  Go to amazon and find an ELM 327 Wifi OBD2 Car Diagnostic Reader.  It does the exact same thing and costs like 15 bucks.  Look for the blue and orange one, it works wonderfully with the IPhone.
Good Luck,
Jeff
Posted Mar 26, 2013 · 04:38 UTC#5
If you have an IPhone, you need to make sure you get the Wifi version, not the Bluetooth one.  If you have an Android, you can use either I believe.
Posted Mar 26, 2013 · 10:43 UTC#6
I have a bluetooth one that works more than fine. I don't remember off the top of my head which I got but my bluetooth OBD-II works great with my iphone.
Posted Mar 26, 2013 · 12:56 UTC#7
I was reading the Kiwi description and it says:
"The Kiwi 2 Wifi incorporates a new advanced power saving circuit, designed to shut off power to essential functions of the unit allowing the Kiwi 2 Wifi to be permanently installed in your vehicle without draining your vehicle's battery. After 5 minutes of inactivity, the Kiwi 2 Wifi automatically enters a low power sleep mode. To turn the unit back on, a simple press of the soft switch wakes the device back up."
If you were to install an ODBII sensor in your car permanently is battery drain something you need to worry about? I would rather pay $30 for the ELM 327 Wifi but I don't want to worry about battery drain.
Ian
Posted Mar 26, 2013 · 20:28 UTC#8
I had one of the off brand Chinese wifi modules that was always powered that ran for two weeks and it never drained my battery. Unfortunately sense it was off brand made in China it only lasted for two weeks. It is now on its way back to Amazon and I am awaiting my Kiwi 2 now. Also I would recommend staying away from any of the wifi modules that are sold for under 100 bucks. Many or all are counterfeit made in China and will fail in no time and the reviews on Amazon will reflect that reality. If you are going to go cheap just read the reviews before you buy.
Posted Mar 26, 2013 · 20:30 UTC#9
So the iPhone is able to connect to the OBD2 module and hands free calling without conflicts? Don't think the iPhone can connect to more then one BT device at one time.
Posted Mar 27, 2013 · 14:57 UTC#10
The iPhone should have no problem connecting to both, I just connected mine to a Bluetooth keyboard and headset and both worked at the same time. You might have issues if you try to connect it to 2 hands free units at once though.
I was looking at the GoPoint BT1, it's apple certified and works with DashCommand.
I wonder if using a Wifi module prevents your iphone from using the cellular network since it's trying to use the wifi connection instead.
Posted Mar 27, 2013 · 17:07 UTC#11
Mine lives in my car nonstop. I have the GoPoint BT1. Autoconnects right away, doesn't interfere with the AppRadio bluetooth, turns off the second the car does and turns right back on when you turn the car back on. It was worth every penny. I've had it in the car for a good few months now with zero issues.
Posted Mar 27, 2013 · 20:20 UTC#12
No, it works without issue.
Posted Mar 27, 2013 · 21:07 UTC#13
Well having the same issues with the KiWi 2 as I did with the Chinese module. Its having problems connecting consistently. Need to do more testing but if I cant get it to connect on a consistent basis I will be exploring the BT options.
Posted Mar 27, 2013 · 21:14 UTC#14
Which iPhone do you have?
Posted Mar 27, 2013 · 21:47 UTC#15
iPhone 5.
Posted Mar 27, 2013 · 22:01 UTC#16
And you are not seeing any interference or conflicts between the two BT devices?
Posted Mar 27, 2013 · 23:28 UTC#17
Does the BT module auto connect to the Dashcommand app when you launch it and does it ever loose connection?
Posted Mar 28, 2013 · 02:30 UTC#18
I use dashcommand and have no issues. Everything works flawlessly when I use my BT1. Bluetooth is very much able to connect to multiple devices at once. This is perfectly within its range of capability.
Posted Mar 28, 2013 · 02:47 UTC#19
So you turn the unit on, the phone connects to the module, you launch dashcommand and everything connects automatically, right? I am looking for specifics before I return the Kiwi for the BT1.
Posted Mar 28, 2013 · 09:47 UTC#20
Yep. I put it in my car 6 months ago and haven't touched it or thought about it since. Only exception to this are the handful of times I put it in a different car to get info from them, and when I switched to my 5 from my 4s. Although with the switch I didn't have to touch it, I just had to re-pair it.
Posted Mar 28, 2013 · 13:02 UTC#21
Thank you. I returned the KiWi and am awaiting the arrival of the BT1.
Posted Mar 28, 2013 · 17:39 UTC#22
Glad I could help. Just make sure to follow the instructions when you get it.
Posted Mar 28, 2013 · 20:56 UTC#23
VBLUE can you update us on this once you get it. I would really like to know
edit -
Hi there VBLUE can i please change my Title of my thread from PLX Kiwi - is it worth it to
just so others can easily pick it out
Edited Mar 28, 2013 by s84kam
Posted Mar 29, 2013 · 01:51 UTC#24
Done. And yes I will certainly update this thread once I get rockin and rollin again.
Posted Mar 30, 2013 · 19:14 UTC#25
I just came across this kickstarter project today. It's an OBDII reader that connects through bluetooth 4.0 to iOS (Android coming later this fall), it lets you configure custom gauges to display, has fuel tracking, error codes and it runs in the background. All data is uploaded to your online account which they say will be free.
http://www.kickstarter.com/projects/shred444/drive-with-dash
Page 1 of 2
