2006 F-250 Information
By berrymj · Feb 13, 2007in General💬 4 posts👁️ 1,358 views
Posted Feb 13, 2007 · 16:22 UTC#1
I need to find the simpilest location for VSS, Back Up Light, and Parking brake. I understand the VSS is located in the Radio cavity as a gray black wire but there are two locations with the same color wire. What pin number is it? The reverse lights must be in the kick panel but I have not located them there and have to pull wire to the light fixture.
Can any body help me with reliable information?
Mike
Posted Feb 14, 2007 · 02:58 UTC#2
grab the metra or scosche wiring harness for your truck. one of those gray/black wires is going to match up with a speaker lead in the metra/scosche harness. The other one will not. That one is your vss. Of course you could grab a meter and test it too. As for reverse it's black/pink an 8 pin harness next to the parking brake assembly.
Now I'm sure there's more than a few people that can chime in here as far as the install in that vehicle goes. There have been by my count no less than a dozen people asking the same questions. Easy truck, have fun.
Posted Mar 17, 2007 · 09:11 UTC#3
Mike
here a link that may help you
http://www.fordf150.net/forums/viewtopic.php?t=42951
