The Pandora thing is kind of a PITA as far as i'm concerned. I have 2 iPods connected to my head unit. 1 for music and 1 for Audible. And i have my iPhone 5 using BT for Siri (sending emails and texts) and for phone use (i don't want all my music on my smaller 32GB iPhone as it stores lot of apps, some basic music, pictures i take, etc... wouldn't be enough room for the music i want to have access to in the car). I don't use the AppRadio stuff nor anything else. My iPhone is not plugged in, in any way, to my head unit (8000nex).
My idea was the following:
iPod1 (iPod touch 64GB all my music)
iPod2 (iPod touch 32GB with my audiobooks)
iPhone via BT for Pandora
I originally had my smartphone setup as Other -> USB (when i initially tried to set it up as iPhone/iPod->AV or USB, etc.. it wouldn't do anything the way i wanted). However i couldn't do any Pandora or aha. However iPod1 and iPod 2 ALWAYS remembered the correct spot when i switched back and forth or after power cycles (leaving for work in the morning, or back home after work, etc...)Then i changed my smartphone back to iPhone/iPod -> USB. And Pandora and aha was now accessible. I was told that Pandora uses iPod1 and must be USB AND BT (Pandora uses the BT and the Music app uses USB)
I still have my Siri, both iPods work. The Pandora label is there. I can click on the Pandora button and it launches Pandora on my ipod1. Now, if i'm at home or near a totally open wifi and my iPod1 connects to wifi Pandora will play. If i turn on Local Hotspot on my iPhone and connect my iPod1 to it, then Pandora will work no problems too. Awesome right? Wrong. Once "Pandora" is allowed it now decides that it is the DEFAULT action of my iPod1. So i get in the car, turn it to iPod1 (from SiriusXM) and it jumps to playing Pandora (not using the Pandora feature of the 8000nex), but it tells my ipod1 to start playing the Pandora app and it plays over USB. I then have to click on the categories button and choose a playlist for example. Listen to some ACDC as i jam to the store. Turn the car off, grab some gas or food or whatever and then get back in the car. Crank up the car and bam! it's back in Pandora Mode. Totally ignores that i was listening to the Music App and some play list.. I have to go back to the categories and choose the playlist again and start the song all over again.
So i have 2 options. Don't use Pandora at all (and possibly redo my smartphone setup to Other -> USB so it's not even an option - which worked amazingly well), or deal with the fact that it's gonna want to select Pandora and lose my playlist every time i choose iPod1. I'm hoping this is some kind of glitch and Pioneer will fix it. But i'm not holding my breath on that one. I would love to use Pandora, but i have plenty of music on my iPod so it's not a deal breaker. The only other thing i can think of is to grab my iPod1 after i do enjoy some Pandora and possibly kill the app on the iPod and hopefully when i switch back to iPod1 the 8000nex won't decided to try and start the Pandora app. Not really sure what's best here. Need to do some more testing tonight at home.
I always have the option i guess of connecting the iPhone to iPod1 via USB and using it that way, however i like to jump in my car and just drive. I don't want to have to always plug my phone in just to go down the street or to the gym, or even to work, simply to have some music. I could indeed put some music on my Audiobook iPod2 but i like the ability to switch between Music and my Audiobook i'm listening too, without having to pull out my iPod2 from the console and navigate around the thing choosing a different app and such when theoretically i can do this from the head unit by having 2 different iPods.
So even though they are trying to allow you to do some stuff from the head unit, you still have to be willing to grab the phone and change apps. Even in the traditional setup with 1 iPhone in USB 1 with USB setup in the smartphone setup, you could launch Pandora from the head unit, but if you wanted to go back to your music, you would then have to select USB1 on the head unit, then on the phone switch over to the Music App and choose a playlist and a new song (both of which is starting from scratch again). So even in the most basic of setups, it appears something isn't right in Kansas with the programing, and you can't just switch easily between music and Pandora. Maybe if you were ONLY a music person or ONLY a Pandora person this might be satisfactory. But heaven forbid if you actually enjoy both.
Anyone else out there have similar experiences or gotten something to work properly (completely properly) in the scenario i'm trying to setup?
