NEX runs Android, and other useless info
By bushing · May 13, 2014in NEX Series💬 53 posts👁️ 21,005 views
Page 1 of 3
Posted May 13, 2014 · 05:27 UTC#1
I'm doing a bit of reversing of my AVIC-5000NEX with the goal of eventually making my own update that disables the nag screen.  I'm still quite a ways away from that, but I wrote up a blog post that some of you might find interesting.
Posted May 13, 2014 · 08:49 UTC#2
Dude - as I read your blog it felt like I was there trying to hack the AVIC with you.
I'm digging the full story, assembler output and all. No matter how it turns out; It's already very interesting.
WTG!!!
Edited May 13, 2014 by highctech
Posted May 13, 2014 · 12:48 UTC#3
Keep up the good work!  I love seeing projects like this... maybe once you knock out the 5000 you'll be willing to take a look at the 8000?  :)
Posted May 13, 2014 · 13:53 UTC#4
I don't speak programmer, but what caught my eye was the 8 GB SD card. Is it that simple to upgrade a 7000 to an 8000? I wouldn't think that the disassembly required to reach the SD card would be too onerous.
Could this be adapted to the NEX series?
Fascinating work. I'd be willing to buy one if the modding work is this easy.
Posted May 13, 2014 · 14:15 UTC#5
You are bushing from failoverflow? I highly respect you and your work!
Thanks for the extremey interesting blog!
I'm a software developer myself but don't have experience at the low-level systems like you using.  I've used JTAG interfaces before but still don't really have much experience with them.
I'm really, really looking forward to see what progress you make!
It sounds like you might even be able to root the device and/or modify the Pioneer menu systems to install other Android apps, etc.
Edited May 13, 2014 by sofakng
Posted May 13, 2014 · 14:36 UTC#6
Well this is an interesting turn, from all I had read and heard it looked like the NEX was powered by QNX instead of Android or the former units ancient WinCE. Seeing the SD Card inside, knowing the NEX8000 has 16GB inside, leads me to wonder if additional space (or a faster card than the mid pack Trancend card) could lead to some marginal performance and space upgradability in the future. Once all of your hard work pans out into something for the commoners to handle that is... ;)
Posted May 15, 2014 · 11:00 UTC#7
Possibly; there's a lot of parts missing on my 5000NEX compared to the most expensive models (e.g. HDMI input, internal (visible SD slot), CAN bus interface of some sort?   What specific features would you like to try "upgrade"?
Thanks for the kind words! Sometimes you just need to find a project that annoys you enough to make it worth the time.  This counts, for me.   In principle, there's nothing keeping us from rooting these boxes, though more research is necessary to figure out how to e.g. enable ADB.   (There seems to be a hidden debug menu that will allow this, but I haven't been able to find it yet.)
Posted May 15, 2014 · 13:16 UTC#8
The biggest issue on a starting point is unlocking that storage card so you can get to it in other devices.  I can understand why you didn't post the password, but that remains the key....
Getting root is easy once the card is unlocked -- mount it on another unix-style machine, stuff "su" in the /system directory and flag it SUID, then stick it back in the head unit! :D
That also leads to another interesting thought -- if you stick a file manager in the system directory along with /bin/su, you should be able to navigate to an attached device (e.g. SD card in the front, attached USB disk, etc) and install APKs!  Whether they'll run given what are probably a number of missing sensors and I/O points, however, is a different thing entirely.
A real hoot would be if it will attach to a WiFi USB adapter; suddenly you have a device that can hit your tether-enabled phone.
Note that "Android" isn't descriptive enough by itself.  It is the frameworks that make Android useful, and who knows what's on there unless you go through the storage.  One thing that's almost-certainly NOT is GAPPs.
Edited May 15, 2014 by tickerguy
Posted May 15, 2014 · 18:15 UTC#9
Interesting thread.. .can't wait to see where this winds up.
Posted May 19, 2014 · 21:46 UTC#10
Yeah, the SD card password just isn't useful for most people because it's pretty difficult to use -- and I'm not even sure it's the same for all units!  More useful would be a dump of the SD card, because any(?) system will boot an unlocked card; I can't release my image, but hopefully I've provided enough information for someone else to reproduce this and post an image.
No need to "root" the thing, it's pre-rooted, if you can manage to turn on ADB or find the correct serial port and enable it (I believe that both of these are possible by pressing hidden buttons in the display, much like the "bypass").
I've posted another blog post about patching the software -- TL;DR is that I've successfully patched out the nag screen on my own unit but I would have to solder JTAG up to someone else's unit if I wanted to repeat the task.  I'm trying to now make an update that could be applied with a USB stick or SD card.  I'm having trouble putting all the correct files in place for the system to recognize my update as valid (it tries to install it and then gives an uhelpful error message).  I also accidentally got my unit stuck in a Recovery mode with this TESTMODE_N.KEY file, and it took a lot of nerve-wracking fiddling to get it to boot back into the normal mode.  (Fortunately, it's possible, but more research is necessary to make this robust.)
I haven't given up on making my own update, but if Pioneer releases the CarPlay update, I should be able to use that as a template to make a nag screen update with just a day or two of work. We'll see who releases an update first.   I just need to resist the urge to actually put this thing in my car (right now, it's sitting in pieces on my floor "workbench") -- if I do, I'll have to unsolder everything and probably won't ever get back to hooking my debug stuff back up to it.
Posted May 20, 2014 · 11:35 UTC#11
@bushing:  You mentioned that you think a secret debug button exists similar to the parking brake bypass.  Did you try reversing it from the standpoint of searching for the "SET ON" message that is displayed during the bypass?  Maybe if you found that then you would find the code containing other secret bypass buttons, etc.
Also, I really appreciate and enjoy reading your blog posts.  I'm glad that you are describing everything instead of just saying "I'm working on it"!  I just hope that Pioneer doesn't change the system after the update disabling some of the methods you are using to reverse engineer everything.
Posted May 20, 2014 · 18:56 UTC#12
Yes, I did try going back from the "SET ON" message.  Someone with more practice reversing Android apps could probably find this in five minutes, let me know if anyone wants the APK / ODEX ...
But if I'm doing it on my own, here's what the layout for the AV "Off" screen is (when you're in the AV screen, but all sources are off) -- http://pastie.org/private/z0brsx08glku0erwteuvg
After staring at that for a while, I boil that down to
<CTL_Control_ViewGroupBase layout_width=fill_parent layout_height=fill_parent>
    <CTL_Control_ImageViewBase width=267 height=144 marginLeft=63 marginTop=24 />
    <View width=fill_parent height=fill_parent />
    <CTL_Control_ViewGroupBase width=fill_parent height=fill_parent>
        <CTL_Button_SingleImage id=off_debug_1_button
            width=200 height=200 marginLeft=50 centerVertical=true />
        <CTL_Button_SingleImage id=off_debug_2_button
            width=200 height=200 marginLeft=300 centerVertical=true />
        <CTL_Button_SingleImage id=off_debug_3_button
            width=200 height=200 marginLeft=550 centerVertical=true />
    </CTL_Control_ViewGroupBase>
    <CTL_Button_SingleImage id=off_videoCheckMode_button width=100 height=100
        alignParentLeft=true alignParentBottom=true />
I read that as -- the text "OFF" 267x144, located at 63,24 from top-left of screen.  The hidden "videoCheckMode" button, 100x100, on the bottom-left corner of the screen.  Three debug buttons, 200x200 each, centered vertically on the screen, at offset 50, offset 300, and offset 550 from the left side of the screen -- if the screen is 800 pixels wide, then that would place debug_2 at the very center of the screen and the other 2 buttons on either side at the edges of the screen.
I tried tapping them, I tried "long-pressing" them (like the "SET ON") button, nothing.  I don't know if they need to be pressed in some particular order.  There's notes in the code about a "debug password input" but I think that's a separate screen that should pop up once the debug mode is triggered (and we should be able to reverse-engineer the password without much trouble).  Really, it's just this GUI stuff that's hard :)
The screen in question is:
Posted May 20, 2014 · 20:26 UTC#13
I can decompile APKs down to Java (really .smali files, but close enough.)
The problem would be a potential missing set of frameworks, but I can certainly try it.
Posted May 22, 2014 · 18:25 UTC#14
Just wondering, but is anybody making any progress on decompiling the APK?
The possibility of having a secret debug menu that enables USB OTG and a ADB console on one of the exposed USB ports is very exciting.  Having access to a full android system and adding custom applications (Google Maps, etc) would be fantastic!
@bushing:  I'm just wondering, but are you an electrical engineer?  I'm a "lowly" software developer and only know the very basics about UARTs, JTAG, etc, and I've love to learn more about reverse engineer and that field of electronics.  Your posts have really inspired me to learn more... :)
Edited May 22, 2014 by sofakng
Posted May 31, 2014 · 03:27 UTC#15
Hi guys! I already have the apk / odex files disassembled to .smali, I can share them if anyone else wants to look at them
Sofakng, yes, I have some background in EE, glad you like the blog posts! :)
I have a crafted "update" that you can apply using one of the test modes that can patch the PLCaution nag screen out. It also offers a couple different ways of backing up your internal SD card to external USB or SD; you can use a built-in EasyRecovery mode to re-image the internal SD without opening up the case (or you can use the image to restore the internal card manually if that doesn't work and you can open the thing up.
You can also use the image to reverse-engineer the thing.
The thing is, in order to get the modified system to boot, I have to turn off Warp!!, which makes the system take longer to boot (26 seconds vs 13 seconds); I'm working on that right now (but that's a whole other task).
Posted May 31, 2014 · 03:32 UTC#16
I'm beginning to wonder if I could fix the sort order problem in the music app..... it would be somewhat of a bitch to do from .smali (maybe more of one than its worth) but.....
Posted May 31, 2014 · 07:17 UTC#17
Come on, if we're going by how much this stuff is worth doing now ... :)
Posted May 31, 2014 · 12:41 UTC#18
Oh no, none of that has a dollar amount.  Being both a coder and electronics dude (I have surface-mount rework gear, do my own boards for some projects, etc) I often take on something "just 'cause" :D
I'd be very interested in a non-destructive way to dump the firmware (without opening the case) and even more interesting (if I manage to hack it) to reload it.  I have a tablet here that I almost-never use and it would be very interesting to grab the APK files involved and attempt to run them on that -- it would make for a very nice debugging environment as there's no challenge getting into ADB on that one.... :)
Posted Jan 08, 2015 · 21:38 UTC#19
@bushing - where you able to get Warp! to turn off? I am really curious about using the method you discovered to patch some other items on the unit. Would you mind supplying an update?
It seems like the progress just cut out a few months back.
Looking forward to hearing back. :)
Posted Jan 09, 2015 · 16:37 UTC#20
+1.
I've actually been following the failoverflow blog since it was first brought up in this thread. While mostly over my head, it's interesting stuff!
Posted Jan 09, 2015 · 23:36 UTC#21
May the force be with you on this.  Coding out that damn nag screen would be epic.  Please don't give up!
Posted Jan 10, 2015 · 00:41 UTC#22
I'm hoping that this kind of development would open the door to transplanting the new 8100's firmware to our 8000s.
Posted Feb 21, 2015 · 16:04 UTC#23
Hey guys, is the set on/off button you are looking for is this one ?
It looks like this is the same exact screen posted earlier.
Anyway just to confirm the SPH-DA120 model is quite similar to the NEX5/6/7/8 series .... Firmware is even named NEX5000 and it does include a 4GB SD card inside ...
Didn't unlocked mine yet (not sure I can recover the password yet) ...
Will follow this theard anyway.
Oh, and for those who wants to build/rebuild apk, this kitchen is very nice !! http://forum.xda-developers.com/showthread.php?t=1736409
Posted Feb 22, 2015 · 06:12 UTC#24
Fantastic work by Bushing, thanks!
SPH-DA120 and 5000NEX seem to be very similar software wise. A firmware update came out for both late last year:
I've got a SPH-DA120 so I'm going to be focusing on that (wrong forum, I know).
This firmware zip contains a bunch of stuff, notably two file types in a few directories:
$ tree AVIC5000NEX
AVIC5000NEX/
├── BLUETOOTH
│   ├── PJ140BTHBTL.PRG
│   ├── PJ140BTHSAF.PRG
│   └── PJ140BTHUDP.PRG
├── BOOT
│   └── PJ140BOT.PRG
├── HIBENDIR
│   └── HIBENDIR.PRG
├── HIBENDIR.VER
├── PJ140BOT.VER
├── PJ140BT.VER
├── PJ140BTL.VER
├── PJ140DAT.VER
├── PJ140ERY.VER
├── PJ140OPN
│   └── PJ140OPN.PRG
├── PJ140OPN.VER
├── PJ140PLT.VER
├── PJ140REC.VER
├── PLATFORM
│   └── PJ140PLT.PRG
├── RECOVERY
│   └── PJ140REC.PRG
├── RECOVERYEASY
│   └── PJ140ERY.PRG
├── SNAPSHOT
│   └── SNAPSHOT.PRG
├── SNAPSHOT.VER
└── USERDATA
    └── PJ140DAT.PRG
9 directories, 21 files
This is from the SPH-DA120, 5000NEX is similar but the images have different contents.
VER files appear to be pointers to PRG files for the different functions or subsystems.
Turns out the PLATFORM & USERDATA PRG files are just EXT volumes with a header, can discard the first 512 bytes to get a mountable image.
e.g. using DD.
dd if=PLATFORM/PJ140PLT.PRG of=PLATFORM/PJ140PLT.img bs=512 skip=1
From there you can mount the EXT images, inside we've got some stuff:
$ tree app
app
├── Av.apk
├── Av.odex
├── DataLinkInfoCollector.apk
├── DataLinkInfoCollector.odex
├── DrmProvider.apk
├── DrmProvider.odex
├── FusedLocation.apk
├── FusedLocation.odex
├── JupiterHome.apk
├── JupiterHome.odex
├── LatinIME.apk
├── LatinIME.odex
├── Launcher.apk
├── Launcher.odex
├── MediaInfoProvider.apk
├── MediaInfoProvider.odex
├── MediaProvider.apk
├── MediaProvider.odex
├── MixTrax.apk
├── MixTrax.odex
├── MixtraxProvider.apk
├── MixtraxProvider.odex
├── Mode.apk
├── Mode.odex
├── Notepadv3.apk
├── Notepadv3.odex
├── SettingsDevelopment.apk
├── SettingsDevelopment.odex
├── SettingsProvider.apk
├── SettingsProvider.odex
├── SystemUI.apk
├── SystemUI.odex
├── SystemView.apk
├── SystemView.odex
├── TestMode.apk
├── TestMode.odex
├── UIService.apk
└── UIService.odex
0 directories, 38 files
I've patched my Av.odex, JupiterHome.odex and SystemView.odex to always return true for InfoManager::hasConfirmedPLCaution() (as Bushing did) and repacked the platform image.
However I don't have access to my unit right now so I can't tell whether I can actually update the firmware.
I'm unsure what kind of signing there is to ensure the integrity of the update.
I also need to check on how to mitigate a bad flash, as that's a very real possibility!
Posted Feb 28, 2015 · 08:24 UTC#25
Quick update.
I got the head unit and managed to bypass the SD card password to take an image - just opening it up and swapping the powered SD card into a computer to then read the data off - the HU unlocks the card then I whip it out (powered) and the card stays in an unlocked state.
I then started information gathering in the various the filesystem images and discovered how to access several of the TESTMODE's
I've bricked and recovered my unit about 5 times today, the final time it's stuck ironically on a programming screen (but not responding to touchscreen input) and unless I can thinking of something out of left field I'm going to have to follow in bushing's footsteps and get JTAG on the device to reset the BSP boot mode back to normal.
I have not found a non-rooting way of getting ADB console or an access point for /dev/ttymcx0 (that'd be really nice right now).
Page 1 of 3
