Wondering if SDXC cards will work, or we limited to 32gb from a SDHC? Ive seen some micro hc cards in 64 and 128 formats any thoughts on those too? Also thinking of a usb flash drive. My goal is to elimiate the need for an ipod
SD compatability?
As long as it's a class 10 high capacity you should be fine. There's guys in here that use there HDDs
SDXC
SDXC is not listed on the card sold or in the manual? I need some one how has tried an XC or an high cap micro sdhc 64gb or more.
i know the micros work because im using a SDHC class 10 Micro SD
What capacity?
XC cards require exFAT. Unless the unit can read exFAT formatted cards it's a no-go.
BTW do not attempt to reformat one of those cards as regular FAT. It will appear to work but somewhere down the road the card will get scrambled with everything on it being damaged or destroyed. The card itself is not physically damaged however; it can be reformatted (exFAT) successfully.
The issue is that SDXC cards have a funky bank-switching and allocation system that is incompatible with pretty much all filesystem heuristics other than exFAT, and if you try to use them at some point the card's internal logic will go insane and scribble on the data.
Thats what I thought. How about these micro cards that have 64GB and say SDHC?
Looks like the largest card would be 32gb?
I think it cn handle 64gb. If some of these members are using there 500gb portable HDDs why not.
I have been using a 64 gig sdxc micro card that I formated to fat32. Its full with music, videos, and music. So far no issues.
Correct.
I have a couple of 128Gb SD/xc cards that I use in my camera; they're exFAT format. I also have attempted a MicroSD reformat to to FAT, run it for a while, everything appears to be ok for a good bit of time and then... oops.
If you write to it once and then never again you may get away with it, because the problem comes when you write to the card, not when reading from it. But I assure you -- if you reformat an XC card to FAT and run it for a while with actual writes going to it you're going to get a surprise, and it won't be a pleasant one.
Sandisc explicitly warns against reformatting their XC cards in other-than-exFAT and states that doing so "may" cause data loss and corruption. It's not a "may" -- it's a will, with the only variable being the number of writes you get away with before it happens. The issue has to do with how the cards handle addressing; "SD" used byte-level, SDHC uses block (or sector) level and XC is an extension of HC.
When expansion beyond 32Gb was first attempted the expectation (based on sector addressing) was that HC would work to a 2Tb capacity. In reality it didn't on a reliable basis, and so the XC derivative was introduced. At the core of the issue was a conflict between how FAT32 works internally and how the SD card's controller has to work in order to do wear-leveling and maintain data integrity. As capacity went beyond 32Gb the internals of wear-leveling and block management changed somewhat, and that was enough to cause problems with FAT32's I/O pattern.
So the bottom line is that if you reformat an XC card with FAT32 and manage to get all of your music and such loaded on it, and everything is there and works, you're probably ok -- provided you never try to change anything on the card. However, I assure you that if you start doing writes to it on any sort of a regular basis (e.g. to update music on your computer) you are very, very likely to get an ugly surprise.
Thanks so much for the replys but im still not sure about 64+ micro campatability. Ive seen some on ebay that say SDHC but cant find any in a retail that state SDHC only SDXC. Im thinking we are fixed at 32gb for the sd slot.
All you're going to find above 32 gigs is SDXC - Extra Capacity. SDHC stands for High Capacity and limited to 32gigs. I formatted to fat32 which is what the SDHC are basically formatted to. I haven't had any problems just yet with a couple of re-writes but tickerguy says I could or will. I had an extra card laying around and figured I'd try it. Its a class 10 and they aren't too much $$$. Eventually I'll try the 128gb SDXC but that would be a bigger risk. I have 3500 songs, something like 10 movies and maybe 20-30 music videos to go through before I get bored and feel the need to have more
Ok thanks. Here is what I'm thinking. I'll get one of these 128 gig micro SD HC cards on eBay that comes with a USB reader just in case I can't get it to work in the card slot
The 64g I have was originally for a cell phone. I haven't had any issues as I said but tickerguy says either I'm lucky or a problem waiting to happen. I also want to do a 128g and format it from exfat to fat but its a $$$$ gamble I'm not willing to take just yet. I'd like to know how it works out for you in a few months especially if you do a lot of rewrites to it. I haven't had any problems yet unless my MIXTRAX issue is because of the card. I had my computer analyze my music and tried to fill the card, which took overnight, and only a few albums were transferred even though the MIXTRAX program said my card was full. I had to copy and paste what I wanted to get it to work.
Be aware that the 4000-NEX does not dismount USB-attached drives when it goes to "sleep"; I get warnings when I pull my NTFS-formatted SSD out of the car and plug it back into my computer. It hasn't resulted in a trashed format yet but if it also mounts SD cards the same way one that has been reformatted from exFAT to FAT is just a matter of time (assuming it's updating access times or similar) before it goes "boom."
The 128gb card from my camera returned an immediate "Incompatible card" message when I tried to insert it.
I got the 64gb card and copied 30gigs on it and its NOT working in the sd slot, states incompatable card!!!!!!!!!!!!!!!!!!!!!!!
Inserted into usb two with the reader that came with it and its reading might take awhile it took about 12 hours to write 30 gigs
Yep.....
A hour later is says read format do not remove!!!!!!!!!!!!!!!!!!!!!!
12 hours to write 30 gig is way too long with today's pcs. I filled 2 32 gig cards one music and one with movies in about 2 hours on a 4 year old hp laptop. Not the best laptop either.
Put it back in my pc and states it needs to format. Shit card. I just got a refund from the seller this morning though
Some people are having positive results with 64gig sd cards even though they are truly not SDHC. I believe in another post someone said it world
S but after time or when you go to rewrite to it, that's when you can lose or corrupt your data when forcing it to work as a SDHC card.
Others are just using 32 gig SDHC and not having issues at all.
There are NO SDHC 64Gb (or 128Gb) cards. They are all SD/XC.
If you reformat one from exFAT to either NTFS or FAT32 it may appear to work normally but it will eventually get corrupted. That's virtually assured. It may be destroyed too at the same time although most (but not all) of the time you can reformat it back to exFAT and it will be ok.
These head units don't know how to deal with SD/XC cards. Trying to cheat is begging to have your data on the card disappear without warning. Use a 32Gb SD/HC (or smaller) card and all will be well. If you want more storage than that get a SSD and stick it in a USB enclosure, plugging that into the USB port on the unit. Those can be formatted either NTFS or FAT32 and will work fine (NTFS required over 100Gb.) Watch the power consumption; anything under 2 watts (with the enclosure) should be ok, so in practice ~1.5 watts for the disk is the limit.
Note that a spinning HDD will almost certainly exceed the power limit for a USB-attached device.
Ya, that's who said it in another post lol, I couldn't remember. Great job tic
