Hi all,
I was able to start igoprimo on my AVIC F550BT, simply just rename folder Primo in Mobilenavigator and Primo.exe in Mobilenavigator.exe, but the audio does not work does anyone know help me?
Hi all,
Hello. I just bought this model f550bt but unfortunately I realized that lacks the micro sd and then the maps do not work. Could you give me directions on what guide to follow to install the browser?
you have a link where to download the firmware update? 1:40 has my thanks
try this
http://www.pioneer.eu/eur/support/software/AVIC-F550BT/page.html
for gps you need igo primo v2 on micro sd card (8gb class 10)
if you downioad from internet ,you must rename folder igo primo to Mobilenavigator and igo primo.exe to Mobilenavigator.exe
for software http://www.gpszone.ro/infusions/pro_download_panel/download.php?did=53
for maps http://www.gpszone.ro/infusions/pro_download_panel/download.php?did=695
you must create an account first for software and maps
hope this help you sorry for my poor english
I have a f550bt but is missing my harness for reverse camera hand brake etc I have only power harness ,can you take a picture with all your jack and wire please ? thank you
ok thanks for your quick reply.
but link for software not work. have you one active?
how you coonect f550 with pc and naviextras?
thanks
ok here is the original software (copy of sd card) for europa just copy in to your sd card , go to naviextras download program and follow the steps
https://thepiratebay.se/torrent/11015270
here is igo primo v2.0 software only so you need maps poi etc but whit this version you can use the last maps (don;t forget to rename igoprimo to Mobilenavigator and igoprimo.exe to Mobilenavigator.exe
https://thepiratebay.se/torrent/11015417
here you have the last maps for europa ,pois and buildings
https://thepiratebay.se/torrent/11015449
if you have the jack with wires for reverse camera please take a picture for me( with jack and wires in the same picture ) or if you don't use it those wires I'd like to buy from you, just let me know the price including delivery for Romania ,I will pay you with paypal
thanks and hope this help you
sorry for my english
I read the post on Saturday afternoon ... and the link is no longer already. Monday morning i call to dealer pioneer of Rome and let you know the cable requested.
greetings
Please send me name of file that i search.
thanks
here is all you need I cecked and is works
http://www.sumotorre...r RTNavi .html
http://www.sumotorre...ls_8164283.html
http://www.sumotorre...0x4800.rar.html
but the name is
igo primo for software
maps Q4 2014 for maps
original software name is RTNavi
but I did not find enywhere you can find in first link (http://www.sumotorre...r RTNavi .html)
you can find on sumo torrent pioneer RTNavi for original software and after this just click on uploader name (the same like here kadet18) and you will find everything
ok goodmorning.
from Italy isn.t impossible to see your link sumotorrent. then i put in my browser a proxy name from brashov romania and then i see all. but..... when i put link in my torrent not work.
Can you sell me a working micro sd ?
thanks
ok I don't understand what is happened with torrent but you can give me your home address or PO box how you wish and I will send you a dvd with igo primo working including everything ,just copy on a sd card and put in your f550bt
I will send you the dvd in a anvelope like a letter and this will be free of charge I don't need money . can I send you the original RTNavi program but unfortunate when I put it on torrent I lost the maps. I don't know why but it happens so you can't use it because the maps from primo are not good with rtnavi because of licences .Naviextras don't update the maps it only update some pois but whit Mobilenavigator you have all you need except in this moment speedcams .For speedcams and other pois you can go to www. poiplaza.com . you will find everything you wish
if you wish RTNavi program just let me know and I will send you a dvd together with dvd mobilenavigator . everything is free of charge because I just try to help.
I don't make money with this., best regards
rear camera?
do you need istruction for install rear camera?
need line control cable. but i don't have.
to buy it : 40euro
ok from where I can buy the line control cable ? have a link? can you buy it for me? thanks
ok here you link that you search:
please send me your adress. in p.m, i ship you a new micro sd card.
thanks
Hi all,
Pending that reaches you the micro sd I can post the sys running?
I got to the point to make then upload the picture to igo hangs on language pack
initialization error: no language file were found.
where put in content?
language pack?
my sys:
[folders]
;app="\MobileNavigator\"
;speedcam="\MobileNavigator\content\ speedcam"
content="\MobileNavigator\content"
;TTS_LOQ="\MobileNavigator\content\tts_loq_7"
;has_secondary_root=0
sdcardpath="\sdmmc\mobilenavigator"
;buildings="..\..\MobileNavigator\content\building "
;dem="..\..\MobileNavigator\content\dem"
maps="..\..\MobileNavigator\content\map"
;poi="..\..\MobileNavigator\content\poi"
voice="..\..\MobileNavigator\content\voice"
;klmpoi="..\..\MobileNavigator\content\userdata\poi
[interface]
show_exit=1
show_minimize=1
shutdown_time=0
extra_settings=1
show_minimize=0
resolution_dir="800_480"
vga=0
[sound]
csv_voice_enabled=1
[rawdisplay]
highres=0
screen_x=800
screen_y=480
class="landscape"
[roundaboutcam]
enabled=0 ;(1)
centery=20 ;(50)
[camera.roundabout]
enabled=0
centery = 20
[debug]
skip_eula = 1
show_oneway_3d = 1
show_oneway = 1
disable_outlookpoi=1
;topmost=1
reserve_memory=1500000
cache=2048
[gps]
port=7
baud=57600
;background_navigation=1
set_messages=0
[power]
backlight_methods=20
backlight_events=1,2
blight_min = 1
blight_max = 10
backlight_manage_values=1
backlight_reverse = 0
;[homework]
;home="WORK"
;work="HOME"
and this is system.ini in save
[local]
voice_key="italian"
voice_path_hint="\content\voice\Silvia Nua 22-10-2012"
language_lcid="1040"
language_key="italian"
lang_path_hint="\content\languages\Italian.lcf"
[rawdisplay]
class="wide"
[timezone]
index="4"
aa
aa
where i wrong?
from Italy is forbidden to use sumotorrent / the piratebay ecc. i not see your link. i've your torrent link but when i put into my torrent not start. ok?
https://thepiratebay.se/torrent/10719189/iGO_Map_83_HERE_2013.Q4_All_Eupope
tested and works here are maos pois etc
here is primo working on my f550bt
here another one
for ottale you must create a folder (lang) on content folder and there you put the language pack
here another one
k thanks for your quick reply. the piratebay forbidden but i think i've map. for folder lang. only lang or language or languages? and after exact name i put language pack in zip format? exact?
for system.ini modify?
for sys?
thanks
ok primo is the same like igo8 so you just put language pack on folder lang from content,on rar or zip format .no need to modify sys text file
