Hi everyone,
I had an iPhone 4 when i installed my avic z130bt - worked great. I later upgraded to an iPhone 5 (64 GB) running on IOS 6, bought a 30 pin to lightning adaptor and works great again.
I recently bought an iPhone 6 (IOS 8 - 128 GB). I plugged it on to my receiver and got an error message! It posted "USB flash drive was disconnected for device protection. Do not connect this USB flash drive to the unit. To restart USB, restart the unit."
I looked up the operations manual and found that it can be one of two things:
1. the cable is bad
2. the connected usb storage device consumes more than 1A.
The cable isn't bad since the unit still works with my old iPhones. The plug that came with the iPhone mentions that it has a max capacity of 1A so i'm not sure if the issue could be more than what was specified in the manual (i.e. is it an iOS 8 issue, or the unit can't read Higher capacity storage devices greater than 64 gb (just like some sd card readers)?.
Does anybody here have a similar experience with an error message like this and would have a solution? If it's an amperage issue, is there a work around it? I've noticed on other forums in here that when they used their new iPhone 6 with the NEX units it works fine.
Thanks in advance for the help.
