2013 USA/CAN Maps Download
By misterwoofwoof · Mar 08, 2014in Hacks/Mods💬 317 posts👁️ 150,467 views
Page 1 of 13
Posted Mar 08, 2014 · 23:33 UTC#1
Here you go guys! You have waited long enough for this!
This is the 2013 USA/Canada Map update.
Instructions for Z110BT, Z120BT, and X920BT units.
1. Extract the contents of the ZIP file into an SD card that is atleast 4GB.
2. Insert the SD card in your unit and it will ask to update and reboot.
3. Update your Bluetooth firmware in the Bluetooth Settings menu.
4. Enjoy your new maps!
Instructions for Z130BT and X930BT units:
2. Replace the CARDINFO.cif file inside the SD card with this one:CARDINFO.zip
3. Insert the SD card in your unit and it will ask to update and reboot.
4. Update your Bluetooth firmware in the Bluetooth Settings menu.
5. Enjoy your new maps!
Instructions for and X940BT and Z140BH units:
2. Replace the CARDINFO.cif file inside the SD card with this one: CARDINFO.zip
Download: 2013 Update Download (2.3GB)
Donation: You can donate here. Every bit helps!
I'll be happy to help if you have any questions. Donations are appreciated since I had to buy the full version to share with you guys!
- Edited: Fixed the CARDINFO.cif files for X940BT and Z140BH - 03/17/2014
Edited Mar 17, 2014 by misterwoofwoof
Posted Mar 09, 2014 · 23:12 UTC#2
Works great!! Thank you!! I created an account just to say thanks!
Posted Mar 10, 2014 · 00:47 UTC#3
This worked flawlessly. I was running the 2012 maps/4.0 software on a z130. I followed these instructions to the letter, and didnt have a single issue.
Posted Mar 10, 2014 · 01:35 UTC#4
Than
Thanks for posting an update and being the first one to test it with the cardinfo.cif.
Posted Mar 10, 2014 · 03:04 UTC#5
Sounds great!   I have a couple of questions --
* Will this update directly from version 3.00x?   (I have a z130bt running 3.001)
* Does this update include the nag screen removal?  (I implemented the nag screen removal hack last year, but on 3.001)
Thanks.  John
Posted Mar 10, 2014 · 03:35 UTC#6
This should work directly from any version including 3.00x. And no it does not have the nag screen removal. Nothing has been modified except to bypass the password requirement for the update.
Posted Mar 10, 2014 · 04:42 UTC#7
I would like to thank you for uploading the maps, I was able to upgrade my Subaru X9310BT following your instructions without any issue.
Posted Mar 10, 2014 · 21:21 UTC#8
A BIG thanks goes to misterwoofwoof for the download.
I followed the "Instructions for Z110BT, Z120BT, and X920BT units" to upgrade my Z110 that had the 2011 maps previously installed.
I lost VR for map functions but I'm enjoying the slightly new additions to the interface.
No password needed, and all is running SMOOTH!!!!!
Thanks again!!!!!!
Posted Mar 10, 2014 · 21:27 UTC#9
Besides newer maps and (likely) updated POI's, is there any other change in this update? If it's a trade-off between newer maps vs. having the  Nag Screen removal patch, I'll stick with the old CNSD310 (2012) stuff.
It is a major disappointment that the power(s)-that-be decided to delete Pionora's entire thread with the patch instructions. :?:  :?:  :?:  :?:. Really bone-headed. With that thread it might have been possible to derive clues on how to do a similar patch for this update. I remember that the "fix" address differed slightly for the various versions of HU software (1.x, 2.x. 3.x. 4.x ...) but the differences were minor. I have both the patched and un-patched file (Navi.exe) from CNSD-310FM. Doing a binary file comparison, I see the only difference is at hex offset 0xBEE20:
original = 05 00 00 0A
patch    = 00 00 A0 E1
I will look at the new update and see how similar it is to the previous navi app. However, I'm not going to install the update - don't want to burn my bridges - in case it doesnt work.
Update: I verified that the "new Navi.exe is different, so I'd really be guessing about the offset and patch values. Maybe Pionora could take a look at the file to figure the proper patch?
BTW, the new Navi.exe @ 0xBEE20 has: 04 00 A0 E1
Edited Mar 10, 2014 by RonS
Posted Mar 11, 2014 · 14:01 UTC#10
Hello AVIC411!!! I have have been browsing your forums for a couple months now just reading through to see what I can do with my z140 and this is mostly the reason I started looking at this site! I cant wait to update my navi. I mainly came looking to see if there was anything I could do to upgrade to the z150 firmware..but as far as I've read there is no way to do that.. Anyways I did the 4.600 update from Pioneer that upgrades the bluetooth and iPhone 5 compatibility, but did not do the 5.100 update. From what I read though the 5.100 update only adds the app radio mode or something for iPhone 5, but I have an Android and that does nothing for me, so I didn't bother. Do I need to do this though before I upgrade the Maps or anything? Or just follow the instructions in the OP and I'm good to go? Thanks a bunch for any help!!!
Posted Mar 11, 2014 · 16:24 UTC#11
Would this work with the X940BT as well?
Posted Mar 11, 2014 · 17:39 UTC#12
Just follow the instructions and ou should be good to go!
Posted Mar 11, 2014 · 17:39 UTC#13
That is a good question. I havn't tested a X940BT but you can test it for us and post the results!
Posted Mar 12, 2014 · 05:15 UTC#14
Hey guys, so i tried to apply the update to my z140bh and its a no so far. I followed all the instructions in the op but my HU doesn't seem to recognize the SD at all. Ive tried with a 4 gb standard sdhc card(class 4) and nothing. Then I tried with a microsd card(class 2) and still nothing. I extracted the file with winRAR and also extracted the cardinfo file and replaced the one in the original map update. It just doesnt seem to see it. I have my phone's bluetooth turned off and the ipod disconnected..again I already did the 4.600 firmware upgrade from Pioneer which updated the bluetooth to v3.32 and added the iphone 5 combatibility. Any ides to what could be going on? I feel like im missing something small. Id appreciate any and all advice. Thank you.
Posted Mar 12, 2014 · 06:59 UTC#15
Does your head unit recognize an SD card at all? Does it read photos or music from it?
Posted Mar 12, 2014 · 11:30 UTC#16
If you say you updated from the Pioneer update, that means your head unit is reading the SD slot, no?
What is in the top level directory of your card?  I believe it should have three things:
 * FIRMWARE (folder)
 * Update (folder)
 * CARDINFO (file)
... and not:
 * 2012 USA-CANADA MAP UPDATE
-- John
Edited Mar 12, 2014 by JohnK
Posted Mar 12, 2014 · 17:16 UTC#17
Yeah it reads them, i used a microsd card with the adapter to update the bluetooth.
Posted Mar 12, 2014 · 17:57 UTC#18
regarding CARDINFO.cif and which values it needs to ahve in it in order for your unit to recognize an update:
see one of my old posts on this... I'm not entirely sure those are all accurate, but you could experiment..
http://avic411.com/index.php?/topic/35293-challenge-restoring-vr-on-x930bt-and-friends/&do=findComment&comment=257674
all the cardinfo.cif file does is signal your device that there is an update on the sd that it should look at.
Posted Mar 12, 2014 · 18:00 UTC#19
it does work for X940Bt as well
Posted Mar 12, 2014 · 18:07 UTC#20
thank you so much misterwoofwoof!
but sorry for asking
my unit is z110 upgraded to z140,
which one should i do this update?
or Instructions for Z130BT, Z140BT, and X930BT units??
thanks again
Posted Mar 12, 2014 · 18:12 UTC#21
thank you sir, I donated, not much but I really appeciated your help.
Posted Mar 12, 2014 · 19:05 UTC#22
thanks again
You should follow the instructions for Z110BT since that is your hardware model number. So use:
Posted Mar 12, 2014 · 19:06 UTC#23
Thanks for the update! I've updated the original post!
Posted Mar 12, 2014 · 19:44 UTC#24
yea no luck. tried doing it with just the map update files and cardinfo file on the root of the sd card and my HU sees the sdcard but doesnt start the upgrade...ive attached a photo with my service info. Ill give a nice donation on friday to whoever can help me get this figured out. My email is [email protected]. Phone # is 678-577-3706.My name is Chris.
Posted Mar 12, 2014 · 20:23 UTC#25
yeah, i'm not having any luck either
Page 1 of 13
