3 hours ago, freddyuk said:
OK I did the Shortfuse hack and this loaded and was confirmed.
Next I inserted the 16GB SD with three files being the Cardinfo above and the update and firmware update files. Nothing happened at all so unit is not reading the SD instruction? I just copied the above files onto my SD. Is there something else I should do as I have no way of opening cif. files on my MAC.
Cardinfo is 33kb Firmware is 2.1mb and Update is 3.62gb !
Did you replace Cardinfo.cif on the SD with the one in my post (that you just quoted)? Since you have an F920bt, you must use that CardInfo.CIF. BTW. it is just a text file so any editor can view/edit it as long as it doesn't do any formatting. Cardinfo.cif must be 300 bytes.
