2013 USA/CAN Maps Download
By misterwoofwoof · Mar 08, 2014in Hacks/Mods💬 317 posts👁️ 150,467 views
Page 3 of 13
Posted Mar 19, 2014 · 13:09 UTC#51
I noticed that after the update I lost AHA radio and Pandora.  They aren't on the scroll wheel anymore?
I think the direction Pioneer is going w/regard to iPhone integration is toward AppRadio - instead of internal HU apps. This seems to be part of the rushed cluster-fuck they threw together  to support Lightning and the latest iPhone/Touch iOs. Unless your really need that support, I'd recommend staying away from 5.1.  That's why I backed away from 5.1 and came up with my own no-nag patch for 5.0.
Posted Mar 19, 2014 · 13:39 UTC#52
I didn't upgrade to 5.1, I just did the 5.0 map update
Posted Mar 19, 2014 · 14:49 UTC#53
OK, I thought you had installed 5.1. Aha and Pandora both should be there in 5.0. Try a hard reset (disconnect battery for ~ 30 seconds). That sometimes fixes these things.
Also, if you are using a Windows or Android smartphone,  be sure your App Connection is set to BT. And iPhones only work with wired connection. However, I don't think this would make the icons disappear.
Edited Mar 19, 2014 by RonS
Posted Mar 19, 2014 · 15:04 UTC#54
does 5.1 definitevely remove Pandora and Aha radio or have any other good features, beside the 'lightning fix'?
i dont see anywhere that the 5.1 update should remove any apps?
Edited Mar 19, 2014 by mrc00l88
Posted Mar 19, 2014 · 15:15 UTC#55
I saw Aha and Pandora both after the 5.0 portion of the upgrade (z130bt), and after the 5.1 app update.
I'm at 5.1 now, Aha and Pandora are still there ... but I am concerned with what else I might be losing.
Even though I've never used it before ... I just went to the car, plugged my iPhone 4S into the 30pin extension for my USB/Aux cable, and AppRadio popped up, prompting me to download the AppRadio utility app for my iphone, after which it showed me about 20 compatible apps.  I was able to use the touch screen display on my head unit to move around on the desktop screens.  I didn't go any further than that because I don't think I'll use this very often -- maybe when one of the kids with their iPhone wants to hook up to show me stuff.
Is this what 5.0 and 5.1 firmware and apps are all about?
Thanks.  John
Edited Mar 19, 2014 by JohnK
Posted Mar 19, 2014 · 17:38 UTC#56
Worked perfectly on my X920BT, thank you so much!  :-P
Posted Mar 19, 2014 · 17:44 UTC#57
hi RonS
so sorry to bother you, but you have been helping me and others all the way.
I hope you can kindly help me on how to remove the no nag/OK screen please.
my HU is z110 updated to z140 and just updated the 2013 map, it's now 5.0
I read all those posts about successful remove no nag screen ones but I dont know how to edit the # from those posts.
can you please guide me?
thank you so much and I hope I am not bothering by sending you this message.
have a nice day and thank you.
K.J
Posted Mar 19, 2014 · 22:52 UTC#58
hi RonS
K.J
This process requires a certain skill set and level of proficiency - I don't have the time to walk you through every keypress. I will help you understand the general process. You're going to have to dig-out the details in existing threads. Beware - there are lots of ways to screw-up. Always avoid doing something you can't undo. Make working backups of any files you need to edit/delete. I make a /BACKUP folder on my SD and move original copies into there (before deleting) just incase I screw something up.
1. Learn how to copy, paste and delete files using Testmode. There is a Youtube vid that covers many of the nuances - but the Testmode user interface is a POS. Be aware that on the video he incorrectly calls it HackMode - don't install hackmode - it's a disaster waiting to happen.   To run Testmode, put the file Testmode.key in the root of an SD and insert it into  the AVIC. You need to select "File Maintenence". It uses hard buttons to scroll, and select various operations. It is very error - prone so be careful.
2. Now you need to get a copy of NAVI.exe on your PC. You can get it off the HU (in /USER/PRGn/APL) or from the 5.x files you downloaded to do the upgrade. Just to be safe, copy the file somewhere to edit - best not to touch the original.
3. You need a hex editor on your PC. I used (free) HxD. Learn how to use it - practice on something first. Then use it to patch the hex bytes into NAVI.exe as pionara (v5.1) or I (v5.0) describe elsewhere. The offest is the location in the file to begin the patch - replacing the 4 hex numbers already there.
4. Copy your patched NAVI.exe to the SD where you have TestMode.key and insert in the HU - should boot you directly into Testmode.
5. The HU has two sets of application files in /USER (PRG0 and PRG1). If a file called PRG.FLG is present, you need to delete and replace NAVI.exe in /USER/PRG1/APL. Otherwise use /USER/PRG0/APL.
6. Delete NAVI.exe from the directory above. It is best to make a copy of it somewhere on the SD in a different directory than your hacked one.  Note: Testmode will not overwrite a file of the same name.
7. Now copy your hacked NAVI.exe to the HU folder from #5 above. It can take a while.
8 When finished, eject the SD and reboot the HU.
Good luck. Maybe someone with more time will write a full-blown checklist.
UPDATE: I just tried applying pionara's 5.1 patch and managed to bork it.  Got stuck in a reboot loop. Good thing I had a backup :)
Edited Mar 20, 2014 by RonS
Posted Mar 20, 2014 · 00:23 UTC#59
Hello,
I have a AVIC-X710BT you think this will work for it???\
The map update is what I mean.
Thank you
Edited Mar 20, 2014 by EdWRX
Posted Mar 20, 2014 · 07:35 UTC#60
This process requires a certain skill set and level of proficiency - I don't have the time to walk you through every keypress. I will help you understand the general process. You're going to have to dig-out the details in existing threads. Beware - there are lots of ways to screw-up. Always avoid doing something you can't undo. Make working backups of any files you need to delete. I make a /BACKUP folder on my SD and move origian copies into there just incase I screw something up.
1. Learn how to copy, paste and delete files using Testmode. There is a Youtube vid that covers many of the nuances - but the Testmode user interface is a POS. Be aware that on the vidoe he incorrectly calls it HackMode - don't install hackmode - it's a disaster waiting to happen.   To run Testmode, put the file Testmode.key in the root of an SD and insert it into  the AVIC. You need to select "File Maintenence". It uses hard buttons to scroll, and select variou operations. It is very error - prone so be careful.
3. You need a hex editor on your PC. I used (free) HxD. Learn how to use it - practice on something first. Then use it to patch the hex bytes into NAVI.exe as pionara (v5.1) or I (v5.0) describe elsewhere. The offest is the location in the file to begin the patch - replacing the 4 numbers already there.
5. The HU has two sets of application files in /USER (PRG0 and PRG1). If a file called PRG.FLG is present, you need to modify /USER/PRG1/APL. Otherwise /USER/PRG0/APL.
7. Now copy your hacked NAVI.exe to the HU folder from above. It can take a while.
UPDATE: I just tried applying pionara's 5.1 patch and managed to bork it.  Go stuck in a reboot loop. Good thing I had a backup :)
Mate, thank you. :-) Did the 2013 maps update to my Z110BT (which is now a ... I have no ideaBT, hah!). I lost my nag screen hack, but following this:
"At offset BEBFC, change 05 00 00 0A  ->  00 00 A0 E1"
Worked perfectly. Nag screen gone, and I'll stick at 5.0 since your experience with 5.1 was less than great, and I have a 160GB iPod Classic I'd rather keep working!
Thanks again!
Posted Mar 20, 2014 · 12:34 UTC#61
Hello,
Thank you
Posted Mar 21, 2014 · 01:07 UTC#62
Hello,
Thank you
No the AVIC-X710B uses compltly different hardware and software.
Posted Mar 21, 2014 · 01:49 UTC#63
Really hate to pester you all about this but I can't find a definitive answer to the following:
Can a X930BT be upgraded to run 5.1? I'd love to run AppRadio, which it seems that 5.0 can't do.
Thanks again!
Posted Mar 21, 2014 · 06:13 UTC#64
I had the same issue. I use the bluetooth connection with Android on my Galaxy S3. I updated my X940BT to 5.0 without the icons disappearing. When I updated to 5.1 the Pandora and Aha Radio icons disappeared. To get them to show up again, turn off any audio source currently being used, then go to settings, av settings, app connection. Change the app connection from 'ipod' to 'others'. Your icons will now show up again. If the app connection options are grayed out in the av settings screen, that means you have not turned off the audio source yet. These settings cant be changed when an audio source is in use. Since 5.1 firmware is really meant for iPhone lightning cable users, I am guessing they designed it to default to that setting.
Posted Mar 21, 2014 · 06:18 UTC#65
Everyone should donate something to mister woof woof , thanks
Posted Mar 21, 2014 · 13:05 UTC#66
Thanks for the reminder @rock88. Just donated!
Posted Mar 21, 2014 · 17:48 UTC#67
RonS
thank you so much.
this is really advanced for me, I'll have to study it more and sure before I performing this.
But I really apperciate your help
Posted Mar 22, 2014 · 00:02 UTC#68
i updated my Z120BT to 5.0 no problem. can i also update to 5.1?
Posted Mar 22, 2014 · 00:09 UTC#69
Thanks Op, worked with my 130
Posted Mar 22, 2014 · 19:58 UTC#70
Hey all, does anyone know if this update can be applied together with the CNSD-310FM/UC upgrade by replacing the Cardinfo and Verinfo files in this update with the files from that thread?  I searched around and didn't see any info regarding that.  Seems to me that it could be done, but I just want to make sure before I have a chance at making a brick out of my unit.
I have a bone stock, never updated Z110bt, purchased new.
Thanks everyone!
Posted Mar 23, 2014 · 06:34 UTC#71
Thanks everyone!
Yes that should work but why would you want the 2012 maps when you can just install these 2013 maps?
Posted Mar 23, 2014 · 19:58 UTC#72
I cannot for the life of me get this to download onto any of my computers. It takes 2 hours and when It gets to the end it says FAILED??
Posted Mar 23, 2014 · 20:04 UTC#73
safe to assume this will NOT work on X850BT?
Posted Mar 24, 2014 · 01:58 UTC#74
Tried again for the 4th time. The only thing I am getting is a empty zip folder and a PART FILE?
Posted Mar 24, 2014 · 03:21 UTC#75
Downloaded using a download manager program. site is great, downloaded at 2mb/s so it was a quick download, followed the instructions and updated my AVIC-X940BT.
the upgrade took about 20 minutes and after was done everything works perfect.
one thing I notice was it dint have the pandora and aha icons but as soon as I paired my galaxy s4 to the stereo the icons show up. I'm even able to play and control Iheart radio from the stereo.
I just bought this one on craigslist because I was so UNHAPPY with a Kenwood DNX570DH.
looks like a great stereo I always love Pioneer.
Page 3 of 13
