WARNING DO NOT UPDATE IF YOU USE USB STORAGE!
By tickerguy · Oct 03, 2014in NEX Series💬 32 posts👁️ 5,879 views
Page 1 of 2
Posted Oct 03, 2014 · 14:12 UTC#1
Where's my 1.02 firmware -- I want it back NOW!
DAMN YOU PIONEER.  DAMN YOU STRAIGHT TO HELL.
Yeah, I'd like CarPlay.  But NOT at the expense of what they did.
If you have a USB-attached storage device (e.g. a SSD) and you update to 1.06 the unit will no longer remember where it was when the car is shut down, and will start playing at the first song on the device when you turn the car back on.
This is a major "screw you" -- they broke the product.
DO NOT UPDATE UNLESS YOU ARE WILLING TO LOSE YOUR USB FUNCTIONALITY!
Posted Oct 03, 2014 · 15:00 UTC#2
Yes this truly does suck and they messed up with this firmware update.
Posted Oct 03, 2014 · 15:23 UTC#3
How about Bluetooth?
Posted Oct 03, 2014 · 15:30 UTC#4
Breaking USB-attached storage functionality in this fashion is utterly outrageous -- it ought to put the company out of the car audio business if they do not fix it IMMEDIATELY.
I will note that there are people threatening to SUE Mazda over this in their stock head unit in the "6" models.
The economic value of my 4000 has been destroyed this morning. I am doing everything I can to make sure everyone knows about this, including sending it out in public where the ~300,000+ monthly readers I have can see it and will never, ever buy another Pioneer product of any sort unless it is immediately (like right damn now, or I gain the ability to restore my older 1.2 firmware) fixed. As soon as I can find a unit that works properly this piece of crap is going on Craigslist and being replaced with something else.
This is utterly unacceptable; either Pioneer didn't care or didn't bother testing the firmware before releasing it.
Worse, since it must be assumed that all CURRENT shipments of the product now have this newer firmware in it you can't buy a new one, or have yours serviced by Pioneer either -- as if that firmware gets loaded on your unit by any means you're screwed.  In turn this renders the warranty void since you cannot evade having this functionality destroyed if you avail yourself of the alleged "warranty" service.
Edited Oct 03, 2014 by tickerguy
Posted Oct 03, 2014 · 15:35 UTC#5
Wow, relax. Wishing a company and their employees out of business is pretty extreme and selfish. Tell that to an employee's kid.
#firstworldproblems
Edited Oct 03, 2014 by superjet
Posted Oct 03, 2014 · 15:40 UTC#6
#firstworldproblems
No problem -- they can refund my money and everyone else so-affected or they can fix it right now -- one zero-cost (to them) option to do so is to release the original firmware files so they can be reloaded.
Pioneer destroyed a significant part of the value of my lawfully-owned product.
Posted Oct 03, 2014 · 16:09 UTC#7
I called about the issue and they said they will let the engineer know about the situation.
Edited Oct 03, 2014 by EricVII
Posted Oct 03, 2014 · 16:54 UTC#8
I called as well -- there is no way to revert to the previous software and they have no timeline on a fix, or even a promise of a fix.
Posted Oct 03, 2014 · 16:55 UTC#9
They really need to get it together or this unit will be sent back to Crutchfield
Posted Oct 03, 2014 · 17:49 UTC#10
Well, I guess we all need to call and let them know.  Of course when I called, I get "we are in training" so call back again.
Posted Oct 03, 2014 · 18:01 UTC#11
Yes everyone call
Posted Oct 03, 2014 · 19:51 UTC#12
Ok, I think we may not have a problem.  I do stress the word "may".
About 2 months ago, I changed my SSD file structure so that I would get Artist/Album/Song order where the songs would start with the 2 digit track #.
I have 12,313 songs.  After Format Read, it would play the first song and it would show 1 of 1113.  I freaked out...I should have 12,313 songs, not 1,113. If I left the USB screen and came back, the available song number would get higher.  It would show 1 of 1213, then 1313, etc..all the way to 12,313.  The process was slow...but eventually it recognized all 12,313.
Shut the car off...and then get back in car and the NEX would do the format read.  Instead of showing 1 of 1113...it would show a higher number.  Each time I shut my car off and get back in, the number would get higher.  Eventually, I would start my car and it would finally show all 12,313 available songs.
Now, during this long processing time...each time I started the car up....it would start with the same song, the first alphabetical song.  No matter what.  No audio resume whatsoever.  But, when the process finally recognized all 12,313 songs at car startup....audio resume worked properly.  I don't have a long commute, so the entire process took a little over 1 week.
Now, I believe the same thing is happening after the firmware update.  I noticed the first time it showed 1,492 songs...now it is over 2,000 songs.  The difference I see now is that available song number increases without having to leave the USB music screen and coming back.
It seems like the unit does a initial format read and then a deeper format read that runs in background that allows you to listen to music while it runs the deeper format read process.
I'm going to keep an eye on this and see if this theory holds true again.  I have some longer road times this weekend, speeding up this process.
So bottom line is that format read process is not complete, and it takes forever...but when its done (depending on how many files you have), audio resume should work.
Posted Oct 03, 2014 · 19:56 UTC#13
No, it goes all the way to 100% on my SSD; it shows the percentage read now on the screen at the top level of the tag/folder display.
When it first loaded it showed the directories but some were grayed out, as it scanned they "lit up" and all became accessible.  This IS different behavior; on the original firmware it would display "Format Read" with the percentage and until it was done you couldn't do anything at all.
It's POSSIBLE the unit is doing something internally and this will "magically start working" but I've taken two 20 minute drives with it playing after it finished indexing everything and the read percentage having long reached 100% and it still didn't properly resume.
Posted Oct 03, 2014 · 20:18 UTC#14
Wow after reading this, I had to see for myself. And sure enough it did not continue where I left the movie. And I just have a 128GB thumb drive connected to USB2. What's even worse is that it won't recognize USB2 if you have your phone connected to USB1.
First was not being able to use Bluetooth audio when plugged in, now this? This is inexcusable. Pioneer just went full retard. I'm seriously thinking about switching to alpine or something else after being a pioneer user for many years.
Posted Oct 04, 2014 · 03:47 UTC#15
I have 480gb ssd, movies start where left off, and music does also. Although, it did this only after several on/off recycles during the first day of use. Now everything is back like it was. I, for one, will not be using CarPlay until there are more apps, that i actually use. The only appradio app i use is dashcommand, and use it on my iPhone 6 screen, in horizontal mode in my proclip mount. Unfortunately, carplay cancels out nav option from avic-u260, the same way AppRadio mode does. You would think, with all the inputs and all, you could choose, carplay mode, nav mode, AppRadio mode via mode switch. After all, all three are made by and supported by Pioneer. It is either/or.
Posted Oct 05, 2014 · 01:13 UTC#16
I have this same problem and it's a huge problem for me.
I have my rear DVD players (in the head rests for the kids) and I use USB1 to play movies for them and now when I turn off the car, it doesn't even remember the same movie!  It goes back to the first movie on the USB drive and starts at the beginning.
Incredibly annoying...
Posted Oct 07, 2014 · 03:08 UTC#17
My unit finally (after more than 12 hours of road time playing music!) started resuming where it was on its own.
There was and is no visible indication of a difference or what it was doing all that time.
And no, that's not acceptable as I dread any attempt to update the content on that drive as it may do the same thing again!  I suspect if I hadn't gone on a literal road trip with several hours of uninterrupted play it would have NEVER finished whatever it was doing.
Posted Oct 07, 2014 · 05:07 UTC#18
It's called indexing your media..  It's building a database.  You think a slow computer can instantly sort through thousands of media files?  No, please be realistic...  All the device needed to do was build it's index because they likely changed the index layout in this new version.
Posted Oct 07, 2014 · 12:23 UTC#19
I have about 40 videos on a USB memory stick and I have the same problem.  I don't have thousands or anywhere even to that.
Also, I believe you are incorrect about how the unit creates the index.  I think when you first insert the USB device (or SD card), it says "Reading... 0%" and it could take a very long time.  It is at that point I believe it's creating an index.  (that's how you can browse by artist name, etc, because of the index created BEFORE you can play anything)
Posted Oct 07, 2014 · 15:34 UTC#20
Correct -- the unit said "Format Read 100%" for a literal dozen hours straight of playing time on the top level music page (which is new; it previously would not start playing until it was done) yet would not resume.
So yeah, it was doing some sort of indexing, but (1) on f/w 1.02 it used to finish indexing on the same disk of the same size in ~20 minutes or so from a "new" format and startup, and from then on was fast (~20 seconds from a cold start), having recognized that it had the same drive connected and (2) now, in 1.06, it requires hours, like more than 10 of them, to do the same thing and gives no status on where it is during that time, having claimed for nearly all of it to have finished since it is showing 100% complete.
While my SSD is large it's not that large -- 70Gb in use, most of it being FLAC files (which are huge compared to MP3s)
Posted Oct 07, 2014 · 16:11 UTC#21
Hmmm, I might try an experiment.
I'm going to try to change the files on my USB stick to force the unit to update it's index and see if it plays better.
I also got a response from Pioneer saying they couldn't replicate the issue and that USB play/resume was working fine for them.
Posted Oct 07, 2014 · 17:23 UTC#22
Good ol' Pioneer.
Posted Oct 07, 2014 · 22:44 UTC#23
Yeah, right -- stick a few files on a USB stick and it finishes quickly.
Now go grab a big stick or a SSD, plug it in full of media, and tell me what happens.
Posted Oct 09, 2014 · 21:55 UTC#24
This is / was and am have, made me really p[issed off, I called the first morning after spending a workshift trying to listen to an audio book, with no audio resume...
They say "we have our engineers " on it, I really really hope they work this out....
my 4000 doesn't have the audio resume issue, just the 1500 dollar nex, and I too asked for my money back, they pretty much broke USB storage...
Posted Oct 10, 2014 · 13:07 UTC#25
I have a240gb SSD full of music and videos. It restarts on the movie i had open just like before. No issue here.
Page 1 of 2
