Hello. Just curious. I had a professional install my Pioneer DEH-P6800MP in my 2002 Honda Civic and now I just got the AVIC-D3. Do I need a new wire harness or anything? Or since I have a pioneer in my car now, are the wires all the same for the AVIC-D3?
DEH-P6800MP to a AVIC-D3
They are the same as far as power, ground and speaker but you will need to connect the D3's parking brake wire as well as the cell phone mute wire after you relocate it in the blank spot above where it currently resides. These two wires will be connected in with the ground wire from the D3 to the ground wire from your harness you already have for your current head unit. This is assuming you want to do the bypass in order to work the navi and to watch videos while driving. You will also need to find your VSS wire under your dash to the speed sensor wire on the D3 as well as the reverse wire from the D3 to your reverse wire in the car if you are going to have the rear view camera installed.
Does anyone know where I can find the VSS wire and the Reverse wire in a 2002 Honda Civic Lx Sedan? (What Colors are they usally?) Thank you!
