Alright, so I got the Viper 771XV and it works great except for one problem, the led keeps flashing at me to indicate the last trigger but its doing this as im driving. It says in the manuel that this is suppose to reset when you start the ignition. Any ideas on how to clear this or reset the unit?
Remote start alarm on a hybrid
is ignition connected properly, and if i remember right its going to do that for a certain amount of time (once ignition is on) and then resets after that.
Main igntion wire is not hooked up properly. IF it was it stops flashing as soon as the ignition is turned on.
It's all a matter of finding an installer that actually takes pride in their work.
ill drink to that... the only way to know that an installer did a good job or takes pride is when you get the car back and everything is as if you never gave the car to the installer in the first place
when i do installs for friends i go over the fine details, tell them what dash stuff i will be removing, where i might be mounting things and how, ask them if they have any concerns and so on and so forth... ill even ask them to hang out and help if they want (this is to a degree of course.... 2 can be a crowd when doing installs)
just do what makes you feel comfortable
i for one would gather as much information about it as possible and then as suggested, kinda quiz the guy... i for one often find that doing my homework often leaves the OTHER person feeling stupid and lets me know that maybe that isnt the right person for the task
the comment about the orange loom... that would be a great little quiz item to see if he even knows about it (if its relevant to the install of course... you wouldnt ask a guy about replacing a lifter if he was rotating your tires... but i digress)
good luck dude
