Got my D3, XM, Backup camera installed (bypassed) and everything works just fine. However, I am seeing more problems with the GPS routing. I hope you will share your experience on this since I tend to believe this could be a common issue.
A little background on the D3:
- The automatic learnings on my unit are all about 90+% finished.
- I get full satelite signal almost all the time.
- My vehicle location seems pretty accurate on the map.
- I tested the unit with the same destination from the same original location over and over.
- The "speed limit" for different road type for ETA is set at 30,40,60.
Issues:
1. For the same destination, Google, Yahoo, TomTom will always point to the same route driving through one freeway. However, the D3, not once will use the same route. When the system is set at "SHORT", it always point me to drive around a block to get to the freeway entrance even the freeway entrance is right behind me. When the system is set at "FAST", it will point me to drive through three different freeways, which is longer in distance and speed limit is not any higher.
2. When I deviate from the route that D3 provided, it will be very stubborn trying to get me back to the same freeway entrance even when I am already right in front of the next freeway entrance, which is CLOSER to the destination. What is logic behind it to tell me to turn back in this situation!? How can that be?
3. There is a time it will tell me to get off freeway and then come back again, while I should have kept driving.
I am disappointed on the navigation performance of the D3 if it is supposed to be the way it is. My HP iPaq with TomTom GPS that the D3 replaced is much better than this. It is hard for me to rely on the route guidance the D3 suggested.
Anyone has similar issues/problems?
