Hi all.
I just had the D3 installed in my 2008 F150 pickup. I have read dozens of pages on this forum concerning this one hack, but I still have a couple of questions and comments.
1. No one who has installed this unit AND posted has commented on if the factory mute function works correctly after the hack. Someone asked about that function. The function I am referring to is the ability to hold down the volume knob continuously and after a second or two, the sound mutes. Reply if you know the answer.
2. I would also like to know if, after perofrming this hack, there are any other muting problems. Others have asked this question, but I still have not seen an answer. Problems such as the BT-Tel properly muting audio with an incoming call? Others issues?
3. Should the BT work correctly (with the additional BT module installed) with or without the hack (i.e., as per factory install)? Let me explain....I see no reason that, if one were to not have the parking brake applied in a "by the book" install, the BT menu items/buttons would not be accessible. Well, when I select BT-TEL the screen that pops up afterwards is 100% blank except the clock and tel icon in the upper left. Does not sound correct to me. And yes I do have the BT module installed.
4. A question about the hack: Please pardon my ignorance, but am I correct in saying that the mute wire (in its new slot), and the parking brake wire (in its factory location) both have to be grounded?
5. Can the mute wire, parking brake and unit's main ground wire all be grounded at the same location (or even spliced together to a longer wire and then grounded)?
One last thing.....
6. For the person above who asked about a on/off switch for this bypass. My installer did just that......my unit is not grounded to the parking brake. It is wired to a toggle switch. But, believe it or not......I have no idea where the switch is.....yeah I know....wetawded. I called him up and he told me he installed so many units that he forgot where my hidden button is in my truck. Now I have to drive back to him 45 mins from home (each way) just for him to show me the button. Ridiculous. But I must tay the rest of the install looks great.
Chow for now..sorry for the novel.
