CD-BTB200 & Bluetooth Phone Compatibility Guide
By Itchy · Apr 04, 2007in General💬 311 posts👁️ 131,434 views
Page 2 of 13
Posted Apr 17, 2007 · 13:26 UTC#26
Service Provider: T-Mobile
Phone: Motorola v600/i (I know it's old)
SW Version: n/a
Auto-Connect: Yes (played with this for about 30 min before I figured it out wish I could remember the exact steps I used)
Basic Function: Call from D3, Answer from D3
Phone Book Transfer: Yes (One at a time - anybody know how to do whole book???)
Voice Calling: Yes
Call History Log: Yes
Signal & Battery Strength Indicator: Yes/No
BT Audio Capable: No
Posted Apr 23, 2007 · 16:04 UTC#27
Motorola RAZR V3i (unlocked European version) on Cingular
Motorola V600 on ATT / Cingular
Able to pair and use both phones. Sounds good, seems to work fine EXCEPT: Trying to use voice dial functions on the phones. Voice prompts from the phone have volume so low, it's almost inaudible. Turning up the volume on the AVIC all the way produces barely audible prompts. Same problem with both phones.
I have checked every setting I can find on the phone. Voice prompt volume is perfect with a bluetooth headset, but I guess the BTB200 uses a different profile?
Spoke with Pioneer tech support, they claim it's most likely the phone, but he was going to check with engineering and call me back.
Anyone else see this problem or have it working? Maybe there is a volume setting that I have missed?
Posted Apr 23, 2007 · 16:22 UTC#28
I was previously using a Motorola v600 on T-Mobile and was also getting some very odd behavior...
I did not experience the volume issue... But, when using the v600 the D3 would NOT stay on BT-TEL when I would receive a phone call...
I could make a call fine... But, when I would receive one, the audio source would automatically start playing again when I answered the phone... The other person could hear the music but I could not hear them and they could not hear me talking...
Crutchfield was going to send me a new BT200 unit... However, a friend of mine and I tried everything with a different phone and it worked flawlessly with a different phone...
Definitely had something to do with the v600...
So, I ended up getting a Razor v3 for $25 and all is working great now...
Weird...
Mark
Posted Apr 23, 2007 · 17:17 UTC#29
And your voice dial prompts are loud enough to be heard?
Posted Apr 23, 2007 · 17:24 UTC#30
I have not tried yet... I will let you know...
Mark
Posted Apr 23, 2007 · 17:28 UTC#31
My voice dial prompt is also silent on my LG8300VX phone.
Posted Apr 24, 2007 · 05:58 UTC#32
Service Provider: Cingular
Phone-SW : Palm Treo750
Auto conect: Yes
Basic Function: (Make & Recieve a call tested. Call logs work.)
Phone Book Transfer: Yes. Can push entire phone book.
Voice Calling: Yes.
Signal & Battery Strength Indicator: yes / yes
BT Audio Capable?: Yes
CAVEAT: The Treo does not connect with the CD-BTB200 out of the box. You must download the software from: http://www.jetwaremobile.com and enable all the bluetooth features. If this works for you, the software costs ~$15. Money well spent to enable all the bluetooth features of WM5.
EDIT: Voice dialing tested, call logs tested...
Awesome will calling my distributor tomorow to see if they have one in stock..
thanks
Posted May 04, 2007 · 20:22 UTC#33
can anyone post on an Sam sung SPH-A640. I got it working on my AVIC d3 but i have to connect manually every time i get in the car.
Posted May 04, 2007 · 20:29 UTC#34
Posted May 04, 2007 · 20:45 UTC#35
you should be able to - you need to set your phone to connect or verify the connection by establishing it as a registered connection under "my devices". I have the SGH 519 and it connects almost immedietly. You should see a device listed as "Pioneer BT" - this needs to be set on the phone not on the D3
Posted May 06, 2007 · 00:51 UTC#36
Phone-SW Version: Motorola Ming (A1200)
Autoconnect: Yes - After making the btb the default on the phone
Basic Function: (Make & Recieve a call, Call History, Preset Memory) Yes
Phone Book Transfer: Yes, one at a time
Voice Calling: Not tested
Signal & Battery Strength Indicator: Yes / No
BT Audio Capable?: Not tested
Posted May 07, 2007 · 20:15 UTC#37
Damn//// i don't even have that setting on my phone.
According to my phone, the following are supported by the phone itself
HSP/HPF/DUN/OPP
I have registered the BTB200 on the phone but i says that it only supports
HSP/HPF
clearly it points to some hand-shaking or negotiating issues between the BTB200 and phones
Maybe i should get a Motorola.... :roll:
Posted May 07, 2007 · 20:36 UTC#38
Maybe you should. My Q works flawlessly. It even plays the ringer from the phone when it rings. I am very happy with the Q and ecstatic that the bluetooth functions so well.
Posted May 08, 2007 · 19:59 UTC#39
I Own the VX 8600 by LG and I cannot get any bluetooth features to work. I tried the VX 8700 at the verizon store and i got the same results so I think it is safe to say that they are not compatible.
I did however try the RAZR MAXX and ALL of the Bluetooth functions worked very well. The A2DP is awesome and I could pause fast forward and rewind. I am selling my LG and getting a MAXX.
Damn LG pisses me off.
Posted May 10, 2007 · 02:26 UTC#40
Do you get voice prompts from the D3 with the Q when trying to use voice dialing (eg "Say a command")? Does the caller ID function work properly. My Q works great except for these two functions. Bluetooth audio even works, although you can't control it from the D3.
Posted May 10, 2007 · 02:49 UTC#41
I haven't tried either of those functions. I'll have to get back to you. The caller id works. I'm not sure if it correlates to the phonebook names but it definately shows the incoming number.
Posted May 10, 2007 · 03:01 UTC#42
My unit shows the callers phone number as well but it does not display the names. Anxiously trying to get to the bottom of this.
Posted May 10, 2007 · 17:08 UTC#43
No i do not get Caller ID other than the number calling! no names. Another annoying thing is that when i get a txt message the D3 just rings and rings until you do something about it.
Posted May 12, 2007 · 03:18 UTC#44
This just in...
The Motorola i580 with Nextel service ISN'T WORKING AT ALL!
There is no (caller) audio coming from the stereo speakers whatsoever. The person on the other end can hear me but I can't hear squat.
It rings, connects, dials and all but it's useless if you can't hear the person you called!
I've been searching for a reason for this but can't find anything. It wouldn't surprise me if for some reason the phone is just not fully compatible. I've never been impressed with Motorola phones for Nextel.
Anyone with hints here?
Posted May 12, 2007 · 03:18 UTC#45
I tested mine today and I am getting the name and number on mine.
Posted May 12, 2007 · 15:44 UTC#46
Motorola relased a software update for the phone that fixes this problem. MOL3 is the correct version. You can DL it from here:
http://direct.motorola.com/hellomoto/Mo ... Select.asp
Posted May 17, 2007 · 20:22 UTC#47
Has anyone firgured out how to get the voice dial prompts to come through the system? I have the Samsung SCH-u540 and can get all the other functions to work flawlessly except the voice dialing.
Posted May 22, 2007 · 13:48 UTC#48
Service Provider: Verizon Wireless
Phone-SW Version: Motorola Q
Autoconnect: Yes
Phone Book Transfer: Yes! Both all contacts at once or 1 at a time.
Voice Calling: Yes
BT Audio Capable?: Yes, but no BT audio touchscreen control. Just Audio
Do you have any insight on how you got your motorla Q to sysnc the phone book? Also do you here the voice commands through the radio?
Posted May 22, 2007 · 15:44 UTC#49
Okay the phone book transfers now, but the voice prompts still dont work, anyone found any fixes or workaround for this?
Motorla Q
Posted May 27, 2007 · 00:28 UTC#50
hey guys just wondering if someone could help me, I am trying to connect a pocket pc 6700 to a D3 via BTB 200 the phone will recognize the unit but the unit says NO CONNECTION. has anyone else had this problem or have the ability to help me out. Thank you in advance
Page 2 of 13
