CD-BTB200 Bluetooth and Smartphones (Fix Inside)
By ewentworth · Apr 08, 2007in Problems/Troubleshooting💬 5 posts👁️ 1,344 views
Posted Apr 11, 2007 · 18:23 UTC#2
this worked great for me too on my cingular 8125!
Posted Apr 11, 2007 · 20:53 UTC#3
I have the same phone with the software installed. I can connect to the CD-BTB200 now but the auto connect function is still not working.
Posted Apr 12, 2007 · 16:42 UTC#4
what do you mean the auto-connect function?
i know with mine all i do is get in the truck, start it up and as soon as i dial on my phone and hit send it connects with the vehicle..
the only bug i have noticed is that if i get another call and don't answer it the head unit will keep ringing long after the caller has hungup (basically until i hangup my original call)
phonebook transfer works fine, but it seems faster to just dial w/ the 8125.
Posted Apr 12, 2007 · 19:57 UTC#5
Yes, the 8125 will connect to the CD-BTB200. But it will only when you forced it to do "DIRECT" connect or when you called out the first time or when someone called you the first time.
This BT car system is supposed to connect to your BT capable phone once the system is turned on. The is the so called "Auto-Connect". But it just can't with the Cingular 8125.
I also found that with my 8125 if you dial say "12" using the headunit screen, the dial-pad screen will freeze.
Even with the Jetware software, the smartphone, at least the 8125 that I know of is still not totally compatitble with the CD-BTB200 at this point.
