CD-BTB200 Bluetooth and Smartphones
By JCcool741 · Mar 31, 2007in General💬 138 posts👁️ 60,639 views
Page 1 of 6
Posted Mar 31, 2007 · 23:54 UTC#1
Hey, has anyone been able to get the BTB-200 (or 100) to work with a smartphone running Windows Mobile 5 or happen to know if it will work (I got a Cingular 8525)? I got a BTB200 on order and im not sure if I should even install it yet since I heard people are having troubling getting things to pair.
Posted Apr 01, 2007 · 02:14 UTC#2
I get my btb200 and im wondering how it will work with my blackberry. i will know by tuesday hopefully.
Posted Apr 01, 2007 · 14:23 UTC#3
Here is what I can tell you with regards to my Blackberry 7100i(Nextel). It links with the bluetooth and can be used with the telephone to make and receive calls. But doesn't function correctly with the direct connect. I cannot hear them speaking nor can they hear me. I am not able to push my contacts to the unit either. I contacted Pioneer and they told me they are surprised I can even use the phone function as this model isn't set up to even recognize Smartphones. The newer model BB may be able to push their contacts but the older models were not designed to push data. Hope this helps and good luck. The best thing to do prior to installing it is contact Pioneer and your service provider and see if your capable of the contact push.
Posted Apr 03, 2007 · 01:15 UTC#4
Kind of frustrated...
Just installed the BTB-200 and I can't get my Palm Treo 750 to connect as a BT phone. (For some reason, it connects as a bluetooth audio player just fine.)
Has anyone had any luck at all connecting a Treo (Windows Mobile 5) to the new bluetooth unit?
Posted Apr 03, 2007 · 01:33 UTC#5
Just got the D3 and the BTB200 in. I'm concerned with the fact that so many user are reporting trouble connecting to and using with a smartphone.
I have a blackberry 8100 pearl and i'm going to be sending the bluetooth adapter back if it doesn't perform like i'm expecting.
Posted Apr 03, 2007 · 15:48 UTC#6
I just talked to a Pioneer customer service rep., and he says that Pioneer is working on a "fix" for the Smartphone/PDA interoperability with the CD-BTB200. He wasn't sure how long a fix might take, but his comment was: "Our engineers are aware that this is a problem with Palm and Blackberry devices. We're trying to get a firmware update that should address the fact that those phones don't sync up with our product that well."
Here's hoping the engineers are reading this thread and are working hard for a fix...
Posted Apr 03, 2007 · 15:51 UTC#7
Has anyone tried syncing Nokia E61 or E62 (or any other E-series phones) with BTB200?
I'm having mine installed tomorrow.
Posted Apr 03, 2007 · 17:21 UTC#8
Anyone tried with an 8125 on Windows Mobile 6?
Posted Apr 04, 2007 · 02:36 UTC#9
I second that. Does anyone know if the Cingular 8125 works? How would one upgrade with the firmware update? Would you upgrade the software through the head unit?
Posted Apr 04, 2007 · 02:58 UTC#10
well i was able to not only get my blackberry 8100 to auto connect i got it to transfer my phone numbers over as well. so now when i get in the car it auto connects and im good to go. my phone doesn't stream bt audio it jsut send them across using bt but that didn't seem to work but no worries ht phone is all i care about.
Posted Apr 04, 2007 · 03:03 UTC#11
Has anyone had any luck with a Palm Treo 700w to auto connect with the BTB200?
Posted Apr 04, 2007 · 04:05 UTC#12
My 8525 which runs wm5 didnt work which means the 8125 will not either. My 8525 that has wm6 didnt work either. The A2DP worked though. As for the updates, i was wondering the same thing.
Posted Apr 04, 2007 · 16:01 UTC#13
Heres all my info that i put into the Compatibility guide, remember to make sure you have the newest phone SW also.
Service Provider: T Mobile
Phone: Blackberry 8100 Pearl
SW Version: v4.2.0.64
Auto-Connect: Yes
Basic Function: Yes
Phone Book Transfer: Yes
Voice Calling: Yes
Signal & Battery Strength Indicator: Yes / Yes
BT Audio Capable: No, Phone only transfers audio over BT
BlackBerry Settings
Bluetooth: Enabled
Paired Devices: Pioneer BT unit2
Device Properties
Device Name: Pioneer BT unit2
Trusted: Yes
Encryption: Disabled
Echo Control: Automatic
Bluetooth Options
Device Name: Blackberry 8100
Discoverable: Yes
Allow outgoing calls: Always
Address book transfer: Enabled
LED Connection Indicator: On
Posted Apr 04, 2007 · 17:29 UTC#14
Auto-Connect: Yes
Basic Function: Yes
Voice Calling: Yes
BlackBerry Settings
Bluetooth: Enabled
Device Properties
Trusted: Yes
Bluetooth Options
Discoverable: Yes
AWESOME!!
I have a Blackberry Pearl and my concerns after reading other users smartphone issues was that it wasn't going to work to the Pioneer Bluetooth adapter's fullest capabilities. Glad to hear that nearly all features are functionable on the D3 & BTB200 when pairing with the BB 8100.
Posted Apr 04, 2007 · 17:44 UTC#15
AWESOME!!
Yeah i was initially concerned as well. i had some issues getting it all to come together at first but i solved each issues little by little. at first i had to manually connect but didn't get any features, and pushing the phone book gave me an error , thats why i put out my phone settings to help others set up their phone. it takes a few steps but its well worth it. also don't forget to add your phone onto the auto connect list on the D3 itself.
Posted Apr 04, 2007 · 17:47 UTC#16
how does voice calling work when the d3 doenst have voice command?
are you saying with the btb200 you can say, "call Jack MeHoff" and it wll dial?
Posted Apr 04, 2007 · 18:04 UTC#17
Yes it will, as long as your phone supports voice dial which my blackberry does.
Posted Apr 04, 2007 · 20:41 UTC#18
my verizon lg vx9800 (the V as its called) has voice command where it says, "please say a command" does this work the same way?
Posted Apr 05, 2007 · 01:41 UTC#19
I have a Verizon Palm Treo 700w and it keeps saying Connection Failed on the D3 screen when I go to connect. It finds my phone fine, but when I try and connect it says failed. On my phone it says, "Your Device did not connect with Pioneer BT unit2. The Network connection failed or the passkey is incorrect."
I tried the default key, 0000 and it didnt work. Then i went in the settings and made my own key and it still didnt work. Anyone have any soultions to this?
Posted Apr 05, 2007 · 03:03 UTC#20
similar. instead of it prompting to say a command you press the voice button on the unit then you say the name.
Posted Apr 05, 2007 · 03:53 UTC#21
JUnverrich: As of this time, there is not a fix for Windows Mobile devices. I called Pioneer yesterday, and they say their engineers are working on a fix. The customer service rep said he didn't know how long it would take to release a fix for Treos and other smartphones.
Posted Apr 05, 2007 · 20:55 UTC#22
Wooo...wait a second...does this mean that it does not work with windows smartphones? I thought even the last version did?
Posted Apr 05, 2007 · 21:01 UTC#23
Not according to the Pioneer rep, but folks here may have had a different experience. All I know is my Windows Mobile 5 device gives an error when trying to connect has a handsfree device. The bluetooth audio part connects just fine. There is a difference.
I could live without the bluetooth audio, but I bought the BTB200 for the handsfree function...
Posted Apr 05, 2007 · 21:12 UTC#24
man, i thought i had seen a list where it did work. Maybe this wasd for the previous version? Did that one work with the smartphones? Dam, even the built in UConnect n my two year old Dodge worked with Smartphones for handsfree.
Posted Apr 05, 2007 · 21:12 UTC#25
Page 1 of 6
