Hey Tillitz you help is much appreciated. Yes, I double checked the amplifier and it is 2 ohm stable for 4 channels. Here is the amp specs from Crutchfield. http://www.crutchfield.com/S-nxEKHnENQB ... thunder564.
To summarize my problem here is the situation I have going on...
Equipment:
Pioneer AVIC-D3
Infinity Kappas (2 ohms)
MTX Thunder 564 4 channel amp
Kicker KX600.1 amp
1 10" Kicker L7 sub
3 sets of Stinger Expert Series Interconnects
Vehicle:
2005 Chevy Cobalt SS Supercharged Coupe
Pioneer Factory System Option
Stock Alternator
Optima Yellow Top Battery
This is the 3rd/4th Pioneer HU I have had in this car and all have the similar whine problem. The problem only happens when the engine is running. With the vehicle in accessory mode the sound is crystal cleer with no noise. The noise is so unbareable that I can not even connect my front speakers the sound is so obnoxious. The whine fluctuates with the engine RPM (acoustical taqometer lol). Now, the battery is in the trunk in this vehicle so I am not running power wires from under the hood to the trunk of the vehicle. I have my 3 sets of RCA cables running on one side of the vehicle with the speaker wires and all the other cables run on the opposite side of the car. I have tried multiple things listed on these forums to try and troubleshoot my problems such as - regrounding the HU, grounding the RCA shields, disconnecting the AM/FM antenna and the noise continues through the speakers and gets no better or no worse.
Here is what I thought was kind of odd. I was looking at Crutchfield's tests to try and find the noise and I thought this was kind fo strange. I disconnected the RCA cables from my amp and used a set of spare RCAs for this test - the RCA cables I used as a spare are made by Rockford Fosgate and they are in excellent condtion. On the rear input side of the amp I connected those fosgate cables. I connected the red side on one side of the RCA to the top and the red side of other end of the RCA to the bottom. I wish I could explain this better but essentially it is just creating a big loop to test the RCAs to see if they are picking up noise. Then I turned the engine on and still got the alternator whine through the speakers without the amp even connected through the D3. Keep in mind the RCA cables I am using are just sitting in my hand and they are not run next to any other wires or under the carpet - they are just in my hand. Now when I move the cables even a little in my hand you can hear the whine change tones (louder/ more quiet). These RCAs were like $50 and they were not even close to anything that could cause interference so I don't think it is about the cables being cheap or not. What does this information tell me though? If I get the noise without it being connected to the D3 I am guessing it is a problem with the amp? All of the cable used to connect the amps are 4 ga both power and ground. The cable is also made by Stinger and was not cheap. I have both grounds from both amps going into a distribution block. The cable coming out of the block is also 4 ga wire. I have it grounded to exactly where the battery grounds on the chasis in the trunk (remember the battery is in the trunk). It is sanded down and is a good tight connection. The total length of the ground wires used is way over 18 inches and I'm starting to think this is a problem. So in conclusion can you answer these questions for me?
1.) Do you think the grounding point mentioned is where I should be or should I find somewhere where the battery does not ground to?
2.) Should I run seperate grounds for the amps and not connect them to a dist block? If so, do I gorund them to the same location or seperate them?
3.) What does this test with the RCA cable tell you about the noise? Is this an issue with the grounds on the amps?
4.) Would a ground loop isolator help with the problem I am having?
All help is much appreciated. I know this is a lot of information but I am just trying to give you as much as I can.
