There are lots of threads on this subject, but none that specifically address this particular question that I could find.
In the manual for the Z1 the recommended settings for the background picture size are "2 592 x 1 944 pixels"...
I have noticed that others seem to be using just 592 x 944 pixels. After searching through the sight and seeing other people's work, I noticed that they are using a resolution setting of 1000 x 480 on the ones I have found. It seems that most if not all of those were for the D or N series though. I don't recall which one.
My question is will those resolution settings work in the Z1? Is it really picky, or does it simply not want the resolution set too high. Also, if going by the manual... what do the 2 and the 1 mean in front of the max pixel settings? Normally I wouldn't ask, but there is a space in there and it's throwing me off.
I'm asking because I'm putting together a disc with a bunch of backgrounds I can select from when I feel the need, and I want them all to look just right with no distortion.
Thanks in advance. I should have mine installed in a matter of days now. WooHoo!---- UPDATE, It's INSTALLED!!!! Finally
EDIT: Once I get the resolution settings fixed I will gladly email out the backgrounds I have thrown together. I can't post them because most of them are computer wallpaper designs that I have altered to fit the Z1 screen. I like abstract artsy backgrounds... so that's pretty much what I am putting on my disc.
I have about 8 or 9 made already at a resolution of 500 X 240. I hope I don't have to change them up too much.
Edit 2: I added a screen shot with the backgrounds I altered. Again, I did not make these... I simply altered some wallpapers that I found here and there on the net. If you would like to know exactly which ones came from where... I'll be happy to send you that info...
Edit: 26 Apr 07... Here's a link to my Z1 backgrounds album. I do have a few logos and will try to fit them on for you. I've added a couple of examples of how they might lookwith your logo on it. Just shoot me an email. It doesn't take too long usually.
http://avic411.com/gallery/index.php?cat=15158
Later in the thread you'll find some logos as well.
