Let's try this one more time:
Please just cut and paste. I called crutchfield and they varified that it was valid.
Please post yours as well.
pwgpe-qcph2-z1hk5
pwgpe-qcph2-z1hk5
Here is my referral code
pabc6-85d5r-w4f2z
It should be valid since it has never been use
Fresh one ... have at it:
pp861-1gik1-2004x
Are these valid all the time? Or do they only work once? If so, how do you know they are valid or not?
Here's a fresh one:
p0vtv-92rfh-frb27
Yes. The referral code is assigned to you and never changes. It's always valid. ![]()
It usually takes a few days for the code to go through the system, but you can call them and give them the code and it will work.
Here's another crutchfield code if needed...
pve6f-ciatf-eizkr
Your Crutchfield Referral Code is:
paz4r-u1gdd-acuwe
heres another one
pacpw-dtyce-v4js1
How many referrals are allowed
You may refer no more than 2 new customers within any 30-day period, and no more than 10 customers in any given calendar year, without prior express written authorization from Crutchfield. If you exceed these limits without authorization, neither you nor the new customer may receive the Crutchfield credits.
Hmm... Well I'm no where near 10 referrals! ![]()
Just placed my order, it's a fresh one ![]()
p6rdp-tx6dt-6a0ce heres mines ;p
My referral code:
ps514-0aspb-y4euy
05-31-07 STILL VALID!!!!!!!!!!!! ![]()
Here's a fresh code for all your crutchfield orders.
Code: pgw81-t6x8f-r6g0y
heres my code:
pup21-gsrga-5hauz.
has not been used yet!
Here's another fresh one!
ph9e5-y2xbz-r9uwj
Mine's still valid on the first page. ![]()
im tryna order a bluetooth module from crutchfield but cant figure out where to put these codes in. what am i doing wrong. and what is it that you get by using the codes?
Add to cart, then at the box to the right that says SPECIAL OFFER put the code in. Use mine of course: ps514-0aspb-y4euy
That should do it. ![]()
Also, under the BILLING & SHIPPING section of your order, look under OTHER PAYMENT METHODS at the bottom for CRUTCHFIELD REFERRAL CREDIT. That might do it as well
ps514-0aspb-y4euy ![]()
dude i found it on the billing section but its asking me for a name and zip now. what exactly will i get by using this?
20 bucks off. My name is Michael and my zip is 39565
need last name
PM sent!!! ![]()
