They sell them at Radioshack, its Catalog #: 273-105
I just got one this weekend for about five dollars, so far it seems to be working but i was getting the noise every now and then so its too soon to be sure.
I am confused on what noise were actually talking about. I know with my D3 and Ipod dealy, i get some distortion on certain songs, but i think that's because of the bitrate the song is on, because other songs dont do that.
i'm gonna take a stab here and say that they're talkin about "visual noise"....when there's a video playing off the ipod onto the D3.
No, for a lot of us there is a white noise that can be heard over the ipod cable when playing the ipod. Its only present while playing the ipod. If you have your unit at high volume and pause the ipod you can hear it pretty loud. It comes and goes in intensity as well. Sometimes its very noticeable and sometimes I can hear it over the music. However it completely goes away if you turn the charging feature to the ipod off from the D3. There are several workarounds I have detailed at the beginning of the thread that help alleviate the problem but it doesn't seem to be happening to everyone.
Well that's wierd, i dont have that issue when i have my ipod charging. I did on the other hand have an issue with distortion when playing my ipod. My friend figured out it was my Ipod EQ setting, it was on OFF but for some reason turning it to FLAT fixed it...go figure. ![]()
my 2 cents"ferrites" are gold. i keep everyone i dont need to use and use them up on stupid aux input installs! i do agree that they make great projectiles but still hand for real use
Actually, ferrium is iron. Gold is not a magnetic metal.
Sounds like a bad ground loop. Get yourself a ground loop isolator and put it between the iPod, and the aux port. That should fix the whine noise.
Nail the whine at the source if you can. If the whine changes with the engine revving, then the source might be either a bad condenser on the alternator or non-resistor spark plugs and/or plug wires. Most alternators have the condenser built into the regulator but you can install external ones to help filter the whine even more. Plugs and wires can be brutal, if you're using supa-ninja plugs and phatty-sauce-race wires, then your only solution may be Danish Ferrite Nipples and GL Isolators.
This problem only exist with the iPod source and is not a problem if the charging feature on the D3 is turn off or if the backlight on the iPod is switched to ALWAYS ON so I don't think it is a ground loop but my knowledge on ground loops is limited. There are other people on this forum that have reported he same problem under the same conditions. As for ground loop isolators what do you installers and pros recomend for this situation.
bump!
I have an Avic D3 and I'm having the same problem with noise over the Ipod cable. Just like everyone else, if I turn off the Ipod charging, the noise goes away. After reading this post, I tried taking one of the ferrite beads off of one of my usb cables and putting it on the Ipod. Unfortunately, I didn't notice any difference after doing this. I even wrapped the cable through the ferrite bead twice because I read that improves the effectiveness (also because that was how my usb cable had it setup). I also want to make people aware that I'm only having this noise problem with the 5th generation Ipod video that I have. I also have a 1st generation Ipod nano. The nano, however, does not have the noise issue, even with the charging turned on. So now I'm cofused. I'm not sure if the Ipod video noise is coming from the cable or if it's coming from the Ipod video itself. It seems that if it was coming through the cable, the Ipod nano would have the same problem. I'm curious what ipod version people are using that have this problem. Hopefully someone can come up with a solution to this problem because it really is very annoying.
I had the noise. Set the backlight on the ipod to be constantly on, and noise gone. Sure, this lowers the life expectancy of the backlight, which when it burns out the noise will come back, but by that point somebody may have found a real solution. Because I don't need the backlight if I never look at the ipod's screen.
I'm not sure if there is anything different with my setup, but even when I turn the backlight to "always on" I still have the noise with my 5G Ipod video. The only way I can make it go away is to turn the Ipod charging off.
nice..! now i can work on this...!
OK my avic-d1 had issues when we first installed the ipod adapter.
I installed a power line filter off my old avic N1 harness.
Have not had a issue since.
Also check the volume level and the master level on the ipod.
Are most of you having a issue with windows formatted ipods or mac?
Im a apple guru!!!!!
It is a problem with certain Ipods. I have an old school Ipod, no color screen no video, and I have no noise with the charging on and the back light off. When my wife puts her ipod in, a video ipod, there is white noise in the back ground with the charging on. I think the d3 manual even says something about the noise and to fix it turn the charging off.
I think that he meant 'gold' in the sense that they are really useful. Ferrite is something that is primarily composed of iron, but 'ferrium' is not a word.
Nice (well not really) to know others are having this problem. I'm actually having this issue with a completely different headunit, an Eclipse AVN2210p. I stumbled upon this forum because I am looking to replace the Eclipse with a D3 and wanted to make sure the Pioneer didn't have these ipod issues, but apparently it does.
I'm having what is described as a white noise/interference in the background while the ipod is playing. Very annoying, and it's definitely ipod related, as I don't have this when using the cd player, fm tuner, etc..
I think the issue is related to Ipods that have a harddrive...and the noise is somewhat harddrive related. I can sometimes hear the Ipod boot up. I have multiple ipods, and when I use one of my flash based ipods in the car (my nano, for instance), I have no white noise in the background.
Haven't been able to find a solution yet but I know others have had some success with ground loop isolators.
What is this noise issue?
I have a video ipod and I do not get it.
I am just wondering what it sounds like.
right on...havin this same problem with my f90bt...gonna see if this helps out any...
Well i have a friend whose an electrical engineering student at my college and he said he pulled the newer iPod touch apart and an iPod classic and the way they're wired vs some of the older is far different and most likly the cause of the noise. Newer touches and others have integrated circuits that overlap the dock circuit and therefore can cause static due to overlapping electromagnetism. The old ipods had the circuits seperated father away and have different resistors which probably helps reduce noise.
Im betting that most people that are having this problem are using 5G etc ipods. (since most people seem to be steering away from the newer ipods due to compatibility issues etc)
My ipod classic has never had a problem with any noise. I would bet that the reason that turning off the charge function fixes the problem is probably due to current going into the ipod from the alternator. An old school GL Isolator (like you used to have to use to get the noise out of your old tapedeck/stereo) would probably do the trick.
The new pioneer decks, and the Fseries decks have a ferrite on the usb portion of the deck.
And both of my d3's, I put a ferrite on the cord and I don't have the noise.
has anybody else had success with a ferrite? does it matter where on the cord you put the ferrite?
A ferrite bead never really solved my noise problem.
