What is the one car you simply dread to do and why? Mine is a Jeep Cheerokee Single din. Because of my big azz hands and trying to get the wires to go down.
K
K
The worse ones are the cars that have had a few radios installed in them already. Trying to figure out the wires, the splices, the poor connections.
However I did a Lamborghini once. A yellow one a few years ago. It was a pain because I had to make a face plate adapter, I couldn't find an accurate wiring diagram and it was tight.
I don't dread any car in particular, kinda like a challenge. The thing I dread is certain customers. Today for instance we had a guy come in that comes by every now and then. Always drunk, always has an attitude problem. He wants us to do a complete rewire and a full system in a 97 500SL. Not a fun car and of course he went on a tirade when I told him 2k in parts/labor not including the product he wanted.
Try a 1979 through 1985 Mustang. Pull the factory radio out of that. Or put a cd player in a 1976 Chevette. Done that. Never again. Ever.
hummer h2s (time consuming, and i do at least one a week), anything jaguar, austin martin (the older positive ground system) and anything that costs more than my house (200k-up)
remember-friends don't let friends install ![]()
Oh, and conversion vans or limos. Yeeaaaccchhh.
anything dealing with a vw beetle. ESPECIALLY A 4 CHANNEL AMP ON A FACTORY SYSTEM!!!!!! ![]()
300 in labor
A double din, i.e. Eclipse 5495 in a Nissan Titan. Metal dash support material has to come out.. what a pain.
Try flushmounting a Z2 in a 97 S-10.
good god...i just say buy a n3
On the H1? You can hide a pair or si 14 Chuck Taylors inside the doghouse on that thing. Not a whole lot of room behind the radio area, but, under the console there is plenty of room. Opened one up once, and a Chinese family jumped out. Honest.
putting a avic into a delsol middle vent slot.
had to remove the dash. remove the side vents, remove the middle vents. tap side vents into the window defrost vent. seal holes.
then the 3 gaping holes on the heater vent system had to be chopped down from a 45 degree angle to then be flush. then seal the hole.
just to make room for the deck to fit in the damn vent slot... not even counting the fabrication of a din mount for the vent.
Why in the hell would you want to do that?
Del-Sol, yick.
Del-Sol, yick.
Yea my thoughts exactly
im with cntry i enjoy a challenge.
ive gotta 99 honda civic next to me here that i did a simple indash, 4 spk, sub and amp 2. problem is the drivers door speaker wire isnt working
to run a wire into the door i had to pull spkr, remove door boot "plug" file down on the plugs hole enought to fit a spkr wire through then run the wire through the door boot. the problem is the boot is behind the fender instead of bieng accesable in the door jamb. a simple speaker install took me about 2 hours cuz i had to remove the front fender!
i hate old nissans cuz the plastic they use is very brittle in the year 2007
i cant list any cars that i hate but i LOVE working on toyota/lexus, chrysler/dodge, and gm vehicles.
Ooooooh, how about putting a non-ISO-mount deck in a late '80's Supra? When ya gotta cut up that rubber dash?
Pass the die grinder. Or as I like to call it the air dremel.
Anyone ever put in a Benzi-Box?
How about a CD player in a 1977 Chevette? How about a Buick Reatta (with the 125v display in the dash)? Ever put a DIN unit in a 1964 Corvette? ...... Shut the f**k up. Been there. Put it this way, I've installed a BRAND-NEW Kenwood KDC-1 in a 1984 Mustang SVO. (Trump Card!)So, shut up.
I hate the H1's. To be as big as they are, there is no space to hide electronics. Also converting my 2001 Tahoe's dash to the 03-06 dash was very time consuming. But I'm very anal about the looks of my truck, so it had to be perfect.
Hey shotgun, I did the same thing in my Suburban. How did you get your climate control section so centered? I need to work on that with mine.
Wake up on the wrong side of the bed or something?
has anyone had the fun of the datsun b-210, 70's luvtruch or the old opel gt. pick one and its garunteed that you wont ever want to do one again.
ooopps, that would be luv truck not luvtruch, must of been too early. also anyone remember the days of having to make your own abs plastic kits
