07 Silverado Classic questions
By badz24s · Jun 19, 2007in Vehicle Specific Wiring💬 11 posts👁️ 1,862 views
Posted Jun 19, 2007 · 15:03 UTC#1
I am buying a D3 later this week. What wires will I have to connect it to besides the wires for the factory radio? I have searched, but could not find any lists.
I know that I need a VSS feed, but from what I have read, some people say the green/white wire at the radio is VSS and some say it is not. I will do the bypass, so the mute, parking brake, and ground can all be tied in together, right?
Thanks in advance
Posted Jun 19, 2007 · 18:35 UTC#2
The mute wire should be grounded, but only after you've moved it to the secret pin. The VSS is not behind the radio, it's in pin A4(green/white stripe) behind the cluster. Ill will need to be caught at the convenience center or anywhere else you can find a 12V parking light wire.
Posted Jun 21, 2007 · 14:57 UTC#3
What is the best place to tap into for the illumination?
Posted Jun 22, 2007 · 03:45 UTC#4
So just tap the radios ill wire into any park light wire at the headlight switch??
Posted Jun 22, 2007 · 04:36 UTC#5
you don't even have to go that far I used a dash light wire for my a/c switch.
Posted Jun 22, 2007 · 04:51 UTC#6
Dam. I may have to look into that!!
Posted Jun 22, 2007 · 14:13 UTC#7
You can use any wire that shows 12v when the parking lights are on, but be sure to test it. Make sure it's not a dimmer wire, i.e. changes voltage while manipulating the dimmer switch. A dimmer wire will work fine as long as you leave the dash lights bright, but may not work when the lights are dimmed. I converted all of my dash lights in my Tahoe to blue LED's to match the Z2. At full brightness they will run you out of the truck. Also I know that in some of the vehicles the parking light wire at the headlight switch will not activate when the auto headlight come on. Only when the switch is turned on. I can't stress it enough; test, test, test. A multimeter is just an expensive paper weight if you don't use it.
Posted Jun 22, 2007 · 14:40 UTC#8
Off the top of your head, do you know of a good wire to use at the headlight switch?? I already have the wire run over to it but it is not yet hooked up.
Posted Jun 22, 2007 · 18:36 UTC#10
Brown, I guess no one here likes to use the search button.
http://avic411.com/forum/viewtopic.php? ... ht=classic
Same truck...
Sorry dude. Posted that from work. I dont get alot of time on a computer. So figured id post up and check back later.
Posted Jul 13, 2007 · 20:53 UTC#11
Take a look at this article. This guy goes through the connections for a AVIC-D2 in a 2006 Silverado. I followed them and they worked great for everything. I did need to use another connector for my SWI-PS module though....
http://www.dieselplace.com/forum/showth ... p?t=111759
