I installed my AVIC-D3 today after purchasing it from Compuplus.com ($714.94 shipped). They have super fast shipping and I highly recommend them! This install was pretty easy and took less than 2 hours (with watching the Simpsons while wiring the harness).
The Install:
The dash was very easy to uninstall. Unsnap the boot over the shifter and pull boot and plastic cover over the shifter.
Unscrew the 2 screws at the bottom of the heating/cooling panel. Then pull back at the bottom while prying the clips at the top away with a flat tip screw driver.
I was surprised when I saw 5 screws holding the factory radio in. There is so much room in the dash. I did the install without any cuts on my hands.
Next, I did the bypass seen here: http://www.avic411.com/forum/viewtopic.php?t=7998
Then, I used a Scosche SU03B (from Cardomain.com $13 shipped) to connect the AVIC harness to the car.
Next, remove the plastic molding next to the passenger seat under the door. There is a plastic plug in the door jam and a plastic screw near the front of the car where the passengers right foot goes. Pull that out and you will see a bundle of wires. Find the BROWN/YELLOW wire and connect the PINK Reverse light wire.
I then removed the glove box (about a million screws) to get to the ECU (it's not there, it is under the carpet on that side I guess). I searched for the ECU for a minute, gave up and ran the reverse light wire above metal braces for the glove box.
So I started working my way back across the car. I took my gauge pod(stock clock location) off and put the GPS antenna on the dash behind my pod.
I then removed the gauge shroud (2 screws on top) and gauges (3 screws). I pulled the gauges out and unplugged them looking for the GREEN/YELLOW wire. It was on the center harness. I then tapped into it ran the Vehicle Speed Sense (VSS) wire through the dash to my AVIC.
I then took the braces (4 screws) off the stock HU. I took the braces and put them onto my AVIC (only 3 screws lined up). I then plugged the harness into the car and AVIC and screwed it to the dash with the 6 screws that help the stock radio in. I then put the A/C heater control panel back on and the shift boot shroud back on.
Everything works great.
All-in-all I am happy with the unit. I haven't had any time to play with it yet, but it seems like great unit. It really made me realize how bad my stock speakers are (new components on the way). Sorry for the blurry pics.
