procedure to do a full hd backup???
By nothing · Jul 31, 2007in Hacks/Mods💬 3 posts👁️ 1,025 views
Posted Jul 31, 2007 · 19:07 UTC#1
what is the procedure to do an HD backup before doing the bypass?
does it need to be unlocked? and if so do you have to relock it?
is it a simple matter of connecting to a laptop or something and doing a drive image with ghost or acronis?
TIA
Posted Jul 31, 2007 · 21:32 UTC#2
Ok, here comes the hand holding.... :) It's all in the sticky in this section:
http://www.avic411.com/forum/viewtopic.php?t=728
Yes, it's about $50.
No, I would recommend disabling the relocking in case you want to hook it back up again to the PC.
PC not a laptop. The unlock software needs it to be hooked to the secondary master IDE connector (with an adapter). Tough to do that in a laptop. Yes, you can use either of those.
TIA
After following the info in that post above, back it up as you would any other drive. If you like Acronis or Ghost, whatever...
Posted Jul 31, 2007 · 22:35 UTC#3
awesome reply!!!
thanks so much
