I just finished my install of my d3 in my 2004 silverado.
I had many problems doing this, but now that i got it i just wanted to post exactly how i did it.
1.soldered the wire harnesses together
2.i had to cut out a piece of the plastic behind the head unit.
i cut the top portion with a dremmel.
3.i used the gm/suzuki multi installation kit. the piece that u need to use has a piece of plastic through the middle, cut that off with a knife and file it smooth.
4. i connected the reversegear wire. on silverados this is located benieth the steering wheel and behind the knee plate. remove the knee plate with a 7mm socket. you will see a series of wiring harnesses, the one you need is the one on the right(closest to the passenger side)it has three wires going to it, the one you need is the farthest on the left.
5. i connected the vss wire. to get to this you need to remove the dash cluster. pull the harness out from the back of this, and the wire you need is the green and white. there are three green and white wire, the wire that needs to be connected is the wire going to the A4 pin.
Thats basically it. if you need any help let me know
