new light on d3 bypass
By builderman918 · Aug 18, 2007in Hacks/Mods💬 6 posts👁️ 1,913 views
Posted Aug 18, 2007 · 03:55 UTC#1
so i read on this forum that moving and grounding the mute wire mutes the subwoofer preout...is this true cause i just install my amp and subs and the signal is very muted coming out...i really don't want to loose the bypass since pulling over to plan a route would suck...any ideas
Posted Aug 18, 2007 · 03:58 UTC#2
You don't ground the mute wire, you move it to the un-used pin. Check the how-to.
Posted Aug 18, 2007 · 04:01 UTC#3
um...check out the sticky's you move the mute wire then ground it with the parking brake and radio ground
here you go http://www.avic411.com/forum/viewtopic.php?t=4670
Posted Aug 18, 2007 · 04:16 UTC#4
Bypass has nothing to do with the subwoofer out. Zero
Posted Aug 18, 2007 · 04:20 UTC#5
that is refreshing to hear...do you think it could be a bad rca becuase i know all the connections are right unless the amp or both subs were damaged in shippin
Posted Aug 18, 2007 · 12:25 UTC#6
Be sure you have the amp connected to the rca labeled subwoofer. Also check the subwoofer adjustments under the sound menu.
