AVIC Z1/Z2/Z3 Upgrade to AVIC Z3 w/2009 Maps
By AFMagnum · Aug 20, 2007in Hacks/Mods💬 535 posts👁️ 186,645 views
Page 21 of 22
Posted Mar 29, 2010 · 17:00 UTC#501
Thanks for the reply garrettoomey. I'll just use my Z1 OEM drive for now.
I successfully updated from my Z1 to the Z3 with this thread. I used my Windows 7 Desktop and was pretty simple to upgrade.
The only issue I have sometimes is when I'm driving with my navigation it sometimes doesn't show me on the right street but autocorrects itself after driving for a little bit. Any ideas what would cause that?
Posted Apr 06, 2010 · 06:31 UTC#502
sry if it says somewhere on here, i read the first 6 pages and stopped. i understand this somewhat, but i still have a few questions i was hoping someone could answer for me.
i have a z1 and i did the blutooth update so i could use the 2 wire ground bypass
is my unit capable of doing this update, and is there any other steps i need to do cause its older then the z2 and z3?
i also heard someone say you can update it to be like a z3, does that just mean this with the map updates?
also if i do this, can i remove the stupid nag warning messages that pop up?
thank you
Posted Apr 06, 2010 · 22:04 UTC#503
Yes, you can do this upgrade.
All instructions on the 1st couple of pages. No, you won't be able to remove the nag screen.
Posted Apr 16, 2010 · 12:37 UTC#504
Hi, Does anyone know when and if Pioneer will release 2010 Maps?
Posted Apr 16, 2010 · 14:44 UTC#505
We don't know for sure. Based on their current trend, I would not expect another map update for the Z series until Fall 2010. The 2009 maps were not released until the end of Sept 2009.
Posted Apr 18, 2010 · 03:55 UTC#506
hi, i did the $5 unlock so i lost all data
my partitions were gone, so i remade them, the program was putting the data all i n one partition, so i did it all myself and the z1 i have is not booting. what did i do wrong?
what do i have to do to the partitions to set them up? and how do i get the data in the right spots?
Posted Apr 18, 2010 · 11:16 UTC#507
If you follow the directions and use the correct software (Acronis), you will not have to create the partitions. Acronis will create the 4 partitions, and restore the data in one restore function. You should not have to create any partitions manually.
Posted Apr 18, 2010 · 18:40 UTC#508
im using the acronis, and it made one partion and put the partions into folders on,it when i tried to direct it, and when i had it go to original loctation it put it on my drvie c on my pc.
Posted Apr 19, 2010 · 20:15 UTC#509
You are not using Acronis correctly to RESTORE the image. I use an older version, so maybe someone else with the current version can assist. You may also check the Acronis forums for help. In a nutshell: Select RESTORE from image, select the first file in the image set, select the Avic Z drive as the restore point (deleting any partitions), use defualt settings, go.
Posted Apr 20, 2010 · 08:09 UTC#510
*delete*
Posted Apr 20, 2010 · 13:20 UTC#511
garrettoomey: can you pm me on how to contact you. I live in DFW and need to have my z1 upgrade to z3. thanks
Posted May 10, 2010 · 17:45 UTC#512
Does anyone have a direct link (FTP, Dropbox, etc.) to the file? I have been trying to download the torrent for 4 days. There were originally 3-4 seeders, but they have all dropped off.
Any help is appreciated. If someone has the file and is willing to upload it, I have an ftp site I can give you access to.
Thanks.
Posted May 10, 2010 · 19:45 UTC#513
You can try the torrent again, I'm seeding it right now.
Posted May 10, 2010 · 20:47 UTC#514
Thanks, I see the new seed (and it's fast too :D)
Posted May 10, 2010 · 23:16 UTC#515
My pleasure. Garret and I both seeded this thing for months (as far as I know). There are actually 12 seeds in the swarm right now, I'm surprised that you weren't getting data from any of them...
Right now I'm only uploading to two people at a time so it's splitting the 200kB/s between those. If you think that's fast right now, I'm in the process of buying a house in a Verizon FiOS area, how does 25mb/s upload sound? :twisted:
Anyway, right now I have a 3mb upload speed, I'm not completely sure why my seedbox isn't saturating that so I will investigate and see if I can get the speed bumped a little for you. If it doesn't change in the next hour it should speed up tonight when the peak usage is down.
Posted May 11, 2010 · 00:37 UTC#516
Somebody please HELP! I upgraded from the 310bt to the Z110BT and 8 out of 10 people say i sound muffled. Any suggestions. I have a HTC Hero android os phone.
Posted May 11, 2010 · 03:20 UTC#517
Make a new thread (and make it in the correct forum).
Posted May 11, 2010 · 17:49 UTC#518
Thanks again, I am getting about 200k download now from 2 peers. I have 15mb/s down and 10 up. I will keep seeding for the foreseeable future even once I have the file.
Posted May 12, 2010 · 21:36 UTC#519
Question: Is it possible to update the Z2/Z3 (Z2 upgraded with Z3 HDD) firmware to the latest version (3.100400) without any issues?
I was able to update the gracenote db on my unit without a problem, but since there's an update out there (even though I don't need it) I wanted to apply it...
Yes, I understand that I don't "NEED" it... I just want it! :mrgreen:
Posted May 12, 2010 · 21:48 UTC#520
Is the drive unlocked? If so you should be able to write new maps and everything to it. I know Garret has described the process for keeping music and everything intact during this process as well.
I can't say you won't run into issues but if you've already updated the drive once, should be as easy as pie a second go-around.
Posted May 12, 2010 · 22:15 UTC#521
Yes, drive is unlocked. The reason I ask is because in the firmware upgrade instructions, http://www.pioneerelectronics.com/ephox ... VIC-Z3.pdf , it specifically says not to use this update on Z1's or Z2's because "this firmware update could damage those models"
I'm wondering if a Z2 upgraded to Z3 would still be susceptible to this possible damage...? Or since I'm using a Z3 HDD image, is it ok to apply the Z3 only firmware upgrade?
Posted May 12, 2010 · 22:20 UTC#522
If the drive is already upgraded to a Z3 drive, you have all the firmware updates as well. Don't try to apply firmware that isn't meant for the Z3 specifically.
Posted May 12, 2010 · 22:35 UTC#523
When I look at my 'info' screen, it shows something like 3.100200 as the version, instead of the 3.100400.... But I was able to upgrade the gracenote db successfully...
Guess I'll leave it alone then....thanks for the responses!
Posted May 13, 2010 · 20:25 UTC#524
Damn....sitting at 51% and all the seeds went away....
Posted May 17, 2010 · 10:51 UTC#525
just to be sure... these maps are for america only or also for europe?
Page 21 of 22
