What does it take to burn a backup of the navigation disc. I have all types of copyright software and a dual layer burner. Do you burn it as a data disc?
Burning Backup Of Navigation Disc
Didnt feel like browing all the different threads? Many people have already mentioned which programs they used and how it is done.
Yea, how many times do we have to go over this?
I went through several threads never found what I was looking for. I will try searching again. Thanks for all the help.........lmao
Just use the disk copy feature in your app.
I used a dual layer +R DVD and copied it with Nero. It worked great.
i have tried everything, and still nothing works. I am a pro at burning movies, ripping videos and much more. I don't see why this is so hard. I did get one disc to work, it is the west but it had no points of intrest or address search..... I bought a 3 pack and will have to get more before I try again.
I was able to do it last night using alcohol 120 and some fuji film 8.5 gig DVD DL + R's.
Nero works perfectly well also!
tell me step by step how you did, and which file you used.
-Downloaded and installed Alcohol 120% free trial
http://www.free-downloads.net/programs/Alcohol_120_
-Launched program DVD COPIER inserted DVD NAV CD
-Copied DVD as image to the Alcohol virtual drive whish took about 25 mins
-Inserted Blank Fuji Film DVD DL + R 8.5 GIG
-Burned disk about 40 mins
I got it to work. It was the HP media I had bought. I carried it back and the only other brand they had was memorex dvd+r DL. I told the store if they didn't work I would bring them back as well due to the fact I know Memorex has known tohave bad media. It worked the first time I tried to burn using Alcohol 120. Thanks for all the help and the software worked great.
Glad to hear it worked for you...and hopefully this thread might help some other people as well.
I used memorex DVD R DL as well. The discs I used were able to write up to 8x speed, so I made sure I set the program to write at the speed instead of MAX and everything works well.
Yeah, from what I've experienced, Memorex makes some of the best CD's and DVD's around.
And also, if time is not a factor, burn the DVD at the lowest speed possible. That reduces the chance of there being a write error or data corruption.
Actually Memorex is known for putting out some of the worst media on the market. Google memorex media problems and see what you come up with. I wouldn't trust memorex with my nav copies.
I guess I'm just lucky then... I've been using their DVD's and CD's for years and have had virtually no bad disks.
I am also burning on Memorex DVD+R DL without any issue
The alcohol 120 software would not write at more than 2.5 It come up with illegal write speed. However it did say it wa trying to write at 8. The software is really good, and the log file works well. I sent it to there tech support and they told me I had mad media the first time I tried.
