Why pay for it when here's the torrent Link:
http://search.utorrent.com/search.php?q ... ihq%3d&u=1
I'll be seeding the WEST disk for the next few days for anyone that wants it.
Enjoy ![]()
Enjoy ![]()
Enjoy
I have downloaded both the East and West discs, but notice when they're mounted that all but 2 jpg's and one pim are 0 kb (in the BG folder). Has anybody successfully burned these and had all the images show up?
On the original discs, it is the same way. Don't know why. But thats how my original discs came shipped from Pioneer. 0k PIM files.
Thanks. I looked all over for my "stock" disc and can't find it. I didn't want to waste a dual layer if this was bogus.
do you have to use a dual layer burner for these or can you use a regular dvd burner?
I bought the discs from Pioneer as well and also noticed the 0 byte files. They're dummy files intentionally placed by pioneer to discourage burning. I tried making a backup with imgburn and roxio and it crapped out. I tried different drives and one of them even completely ignored the 0 byte files (Samsung SH182M).
what a good torrent program to download it from?
i never done this before...lol so i know sound funny
I converted the torrent file to an ISO image and the background & pim files show their size.
If I want to put my own backgrounds and from previous map DVD's I would put them here in the BG folder, correct?
torrent programs:
azurues
bitcomet
utorrent
the following PIM files are missing from the ISO I made, don't know why.
PIM : PIM2DIN : PIM529 : PIMANIM2 : PIMANIME
On the original torrent they show as files and on the ISO they show as folders.
^^ Can you extract all those PIM folders in the BG and zip them up and send to me? Im going to try and inject them and see if it works for BGs
here is the whole BG folder
BG.part1
BG.part2
hopefully I did it correctly. attached both files to the post.
Yes you did.. And you did take these from a 70mtp disc right?
Has anyone finished downloading these and tried the disks, are they working disks? anyone know what kind of differences are on these disks from the 60 version (aside from the maps - for all your smart @sses). I mean any interface upgrades, iPod namely? Lastly, does the bypass still work on the N1 with these disks (the soldering bypass)
I could not successfully burn the image as is after extraction (Alcohol kept telling me it was not a valid image format). I ended up loading it into UltraISO and saving it with a different name (but still as an mds file). Once I did that I stripped the POI files and resaved it, then burned it onto a DVD-RW, and that worked fine. I've since added my boot image and the BG folder into it both a stripped and full image for testing. I'll be burning the stripped one next to make sure all the images are there (POS, etc) and if so, will burn the full version on a DL disc. As of now I don't know what, if any differences there are other than the maps.
If anyone cared to read any other threads, there are no GUI changes.
is this version better? what are the improvements? thank u!
It changed the GUI on my buddys N2... His settings menu and what not look a little dif
of course it's better LOL Newer maps and approx 1 million more POI's
Got mine burned last night and east disc works great for me!!!! Much appreciated!!!
Ok so I downloaded the torrents now whats step two, and three, and four, etc, for making a cndv-70mtp disk??
You are seeing things
JGRAY, what program did you use to burn the dvd? Did you have to perform any additional steps?
I tried to burn this .MDS image using Alcohol 120% but it tells me I have not enough space. I am using DL DVD so I don't see whats the problem.
Can someone post DETAIL INSTRUCTION on what to do after you download the MAPS.
I ended up updating to the latest version of Alcohol, and everything works fine now.
i noticed new streets (obviosly) on the WEST disc and also noticed that certain areas on the maps (ie. residential, commercial, industrial) show up with different colors. Oh yea, and the bootup screen reads PIONEER 05/07... can't forget about that. hehe
I had to convert the mds file I think(whichever was the bigger of the two files) to an ISO and then burnt it. I used MagicISO and then burned with decrypter. Worked great first try! I think there's an easier way to do it though if someone can enlighten us. I believe it involves the second file somehow but not sure.
I've notice that they f*cked up some slot of the streets on the east disk..On the 50mpt disk t he had all the streets connected but with the 70mpt some streets split when they really dont..I also lost some new streets that were on the other map weird
